Question about Stihl Garden
Cable broken spark plug wire broken
  • 27 Answers
You will probably need a new coil
Posted on Mar 08, 2015
Engine stopped running, has no spark.
Hi, Ron if you have a CKP sensor it needs compression to send the correct signal to the ICM/ECM, make sure both spark plugs are in heads and use a grounded third plug to check for spark or hold spark plug cable close to spark plug in the head. If still not getting spark the usual suspects are:
1. Fouled spark plugs.
2. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Loose connection at ignition coil or plug between ignition sensor and module.
4. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose.
5. Faulty ignition coil or ignition / electronic module
6. Failed CKP, CMP, or BAS sensor.
7. Faulty ignition switch.
8. Security alarm failing to disarm needs reset
Good luck and have a nice day.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Nov 20, 2015 | Motorcycles
Coil not firing on one side harley road king
Hi Anonymous, on twin cams make sure both spark plugs are in heads and use a grounded third plug to check for spark or hold spark plug cable close to spark plug in head. If still not getting spark the usual suspects are:
2. Battery voltage below 8.7 volts, loose or broken battery cables especially ground cable to frame.
6. Failed CKP, CMP, MAP or BAS sensor.
Good luck
Feb 02, 2014 | Harley Davidson Motorcycles
Bajaj discover 125cc only sparks on one plug. coils and spark,leads are good.
Hi, Carlleroux6 if you have a CKP sensor it needs compression to send the correct signal to the ICM/ECM, make sure both spark plugs are in heads and use a grounded third plug to check for spark or hold spark plug cable close to spark plug in the head. If still not getting spark the usual suspects are:
For more information about your issue, please visit the websites below. Good luck and have a nice day.
How to rule out Spark Plug as your problem
How to Tell if Spark Plug is Bad
Bajaj XCD 125 DTS Si 2008 service manual DOWNLOAD FREE FULLMANUALS COM
Manual Bajaj 125 XCD
Manual Kawasaki Bajaj Wind 125 Documents
Dec 29, 2012 | 2010 Bajaj Discover DTSsi
93 sportster only fires on 1 side of coil
Hi Lowbrowbob, on twin cams make sure both spark plugs are in heads and use a grounded third plug to check for spark or hold spark plug cable close to spark plug in head. If still not getting spark the usual suspects are:
For a prime suspect please visit the website below:
Good luck
Harley Davidson Sportster error codes and how to access them
Oct 06, 2012 | 1993 Harley Davidson XLH Sportster 883...
No spark from coil on 1985 Harley 1340
Hi Anonymous, if you have a CKP sensor it needs compression to send correct signal to the ICM/ECM, make sure both spark plugs are in heads and use a grounded third plug to check for spark or hold spark plug cable close to spark plug in head. If still not getting spark the usual suspects are:
8. Security alarm failing to disarm.
For a prime suspect please visit the website below and good luck.
Harley Davidson Wiring Diagrams and Schematics
Jun 10, 2012 | Harley Davidson XLH Sportster 883...
2009 electra Glide Classic rear cylinder doesn't spark its not the coil or wire
Hi D, if you have a CKP sensor it needs compression to send correct signal to the ICM/ECM, make sure both spark plugs are in heads and use a grounded third plug to check for spark or hold spark plug cable close to spark plug in head. If still not getting spark the usual suspects are:
2. Battery voltage below 8.7 volts, loose or broken battery cables especially "GROUND" cable to frame.
For a prime suspect please visit the website below. Good luck and have nice day. Harley Diagnostic Codes 04 to Present
May 24, 2012 | 2009 Harley Davidson FLHTC Electra Glide...
94 softail 80cubic inch no spark
Hi Don, you may have a faulty cam timing sensor and alot of the following applies to late models, if you have a CKP sensor it needs compression to send correct signal to the ICM/ECM, make sure both spark plugs are in heads and use a grounded third plug to check for spark or hold spark plug cable close to spark plug in head. If still not getting spark the usual suspects are:
2. Battery voltage below 9 volts, loose or broken battery cables especially "GROUND" cable to frame.
May 16, 2012 | Harley Davidson Motorcycles
2000 Harley Sportster 1200S how do I test coil.
Hi Mike, if you have a CKP sensor it needs compression to send correct signal to the ICM/ECM, make sure both spark plugs are in heads and use a grounded third plug to check for spark or hold spark plug cable close to spark plug in head. If still not getting spark the usual suspects are:
Harley Davidson Sportster error codes and how to access them Harley Davidson Wiring Diagrams and Schematics
Apr 20, 2012 | 2000 Harley Davidson XL 1200 S Sportster...
I have no spark on top cylinder of my 97 rs 250,the coil is ok, plug is ok any ideas?
Hi, Anonymous if you have a CKP sensor it needs compression to send the correct signal to the ICM/ECM, make sure both spark plugs are in heads and use a grounded third plug to check for spark or hold spark plug cable close to spark plug in the head. If still not getting spark the usual suspects are:
DOWNLOAD 1997 Aprilia Rs 250
Mar 31, 2012 | Aprilia RS 250 Motorcycles
My x1 has no spark to front cylinder,changed wires,plugs,coil,all check good...scratching my head...think perhaps broken wire...if not then ignition control....
Hi, Aecilak if you have a CKP sensor it needs compression to send the correct signal to the ICM/ECM, make sure both spark plugs are in heads and use a grounded third plug to check for spark or hold spark plug cable close to spark plug in the head. If still not getting spark the usual suspects are:
For more information about your issue and free downloads that you will need please visit the websites below, and for specific information or questions, please feel free to contact me at xlch@mail.com. Good luck and have a nice day.
http://www.buellxb.com/forum/showthread.php?10788-Need-help-no-spark
2000 buell x1 wont crank no spark
http://buellmods.com/content/downloads/manuals/x1lightning/2002_x1_manual.pdf
TWIN Motorcycles Buell parts
http://www.ukbeg.com/pash/2008%20Buell%20XB/99493-08Y.pdf
May 05, 2010 | 2002 Buell X1 lightning
Garden Logo
26 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
