Question about Kitchen Appliances - Others
Where can i obtain service manual foe whirlpool trash compactor
5 Suggested Answers
SOURCE: Trash Compactor Removal
I noticed that my compactor attached to the countertop above it at the front, but that it is also possible to do the same at the back. Can you get access under the cabinet at the back of the compactor and check it out?
Posted on Aug 19, 2008
SOURCE: Trash Compactor Model GCG1500LOBB. the foot
I also found that after 2 years my GE Profile Trash Compactor (purchased in June '07), the pedal was hanging down on the left side. I searched the internet and called GE to no avail.
After a few attempts, I finally solved the problem by removing the screw on the left side and adding a metal "L" bracket, with the bottom of the L flush against the back of the front panel. That way, when you depress the pedal, the screw can't pop out of the metal it's attached to.
Dannys00
Posted on Dec 25, 2009
burdfrenzy
  • 348 Answers
SOURCE: I have a GE trash compactor I have to hold up the
There is a spring that holds up the pedal. It is broken or has come apart. By the pedal in the up position it is a safety switch allowing the compactor to run. You may have to repair this or simply put a small block under the pedal of the unit to run.
I hope my suggestions helps and all the luck to you.
burdfrenzy
http://stores.ebay.com/Pittsburgh-Joes-Pants-Nat
Posted on Dec 23, 2010
jcameo7270
  • 675 Answers
SOURCE: Does 15" trash compactor need
If the current rating on the name plate is 15A or better, I would have it on it's own breaker
Posted on Dec 27, 2010
Service manual for a terex tc 550 compactor
how old it that
may have to contact Terex themselves
http://www.terex.com/construction/en/products/loaders/index.htm
not any e manual type copies
no ideas why it isnt on the Terex repair/service manual site
http://automanual.co/cars/terex-Repair-Manual.htm
May 17, 2016 | Kitchen Appliances - Others
Ge profile trash comapctor loud banging noice
You have something wrapped on the compactor screw assembly (The assembly is a threaded rod about 24 inches long and 3/4 inch in diameter. ). Most likely it is plastic bag or some other plastic. Pull the entire compactor out (remove the hold down screws first). Then look for the obstruction on the screw assembly, cut it off and try while not in the compactor hole to make sure it works.
Jun 18, 2014 | GE Profile GCG1580LSS 15" Built-In Trash...
How to remove whirlpool trash compacter
Hi Larry, you can download the installation manual from the link below which should also have some instructions for removing the compactor. We hope this helps!
http://bit.ly/112Lu7q
Jan 02, 2014 | Whirlpool 800 Series Undercounter Trash...
Whirlpool Trash Compactor, Model No. GX900QPPS2 will not compact trash. It will only make a humming noise
drive gear broke on motor shaft,drive kit #882699should fix you.appilance parts pros.com is a good place to get it.
Oct 08, 2013 | Kitchen Appliances - Others
Kitchenaid compactor KUCS03FTSS makes banging sound at end of cycle
I bought a Kitchen Aid trash compactor the end of Sept/2008. By July/2010 I have spent $528 on having it fixed! It only cost $623 new so I called Whirlpool customer satisfaction line where after waiting 15 minutes was told that "With all due respsect mam, Whirlpool owes you nothing" Then " as a courtesy" they offered me 50% off an $80 part that I still need to pay $60 in labor to install! So,that would be an additional $100 on an appliance that has been trouble from the get go...I have had numerous compactors before this brand and have never had any trouble...Do NOT buy anything made by Whirlpool as they have apparently, a NO customer satisfaction policy.
May 17, 2010 | GE Profile GCG1580LSS 15" Built-In Trash...
Whirlpool Compactor: starts making banging noises....
it sounds like there is something in the motor or a gear is getting ready to go out i suggest calling ge if it under waranty
Nov 15, 2008 | GE Profile GCG1580LSS 15" Built-In Trash...
Kitchen Appliances - Others Logo
64 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
