Question about Liebherr Refrigerators
Water collecting at bottom of larder fridge under baskets
SOURCE: Water collecting in bottom of fridge
NO SOLUTION!!!!
a ?
how do i stop it?
Posted on Jun 16, 2009
woodchuck789
  • 4070 Answers
SOURCE: water/condesation collecting at the bottom of my fridge
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Jul 09, 2009
woodchuck789
  • 4070 Answers
SOURCE: water collecting in bottom of ariston fridge
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Posted on Sep 04, 2009
beamerguy740
  • 65 Answers
SOURCE: water in bottom of fridge
Probably has ice frozen under freezer tray or drain tube may be blocked by ice diverting water through freezer to fridge vents.
Posted on Sep 11, 2009
  • 323 Answers
SOURCE: water is not draining away throguh the hole near
the drain is probably frozen, unplug unit and defrost manually, use a hair dryer to melt the ice around the drain , be careful not to melt any of the plastic
Posted on Nov 07, 2009
RF261BEAESP
Check the pipe that drains the water from the avaperator (the thing that gets cold inside on the fridge)
periodically your fridge will defrost and the water should drip through a tube and collect at the rear of the fridge
If the pipe is blocked the water collects inside at the bottom ( under the crisper)
Apr 15, 2014 | Samsung RF261BEAESP 25.5 cu. ft. French...
ARL100/B-K/1 Larder fridge collects water at the bottom under the two detachable trays. Could you please tell me what is .
Your auto defrost drain line is clogged.You will need to locate it and clean it out. Try to trace the water back to where it is coming from. Also you may try pulling the refrig out from the wall to check.Hope you found this helpful and thanks for using Fix ya
Jun 23, 2011 | Whirlpool Refrigerators
SMELL COMING FROM LARDER FRIDGE,FOUND THE PROBLEM AT BACK WHITE TRAY ON TOP OF MOTOR A BUILD UP OF SLIME , FINDING A PROBLEM TO CLEAN TRAY,
This is the defrost water that collects on the collection tray - white tray on top of motor. Normally over a period of time the water evaporates off but if there is collection of dirt it can smell. So you need to PULL out the tray - use a screw driver to release the lock and the tray will come out which can be cleaned using a water jet and detergent.
Apr 06, 2011 | Refrigerators
Water collecting in the container.
It does sound like it might be the recent excess of humidity we've been having. Once dryer weather comes, see if it's still happening. It does take a while for cold water to evaporate from just the heat of the fan blowing over the compressor.
Only other thing i can think of is, it's defrosting more often than it should be, meaning you may have a bad defrost timer. It should only be defrosting once a day. But I'd give it time before ripping it apart.
Jul 16, 2010 | Whirlpool Refrigerators
Water in bottom of fridge
Sep 11, 2009 | Refrigerators
Collecting water at bottom of frig inside under drawers.
begin by removing the grill on the front at floor level. look under there and you will see the evaporation pan. next pull the fridge out from the wall so you can get behind it. there you will see the tube. to unclog it you will have to disconnect it at the top and force hot water into it using a turkey baster.
Aug 22, 2009 | Refrigerators
Larder section of fridge not functioning
check the drain that is inside of the freezer compartment at the bottom. you may have to disssasemble the covers to get to it. if its clogged the water turns to ice real quick and blocks air to the refrigerator
Dec 29, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Overflowing drip pan under the fridge
for reallybsq
problem could be door seals not sealing completely and hence excessive ice formed on evaporator and excess water when it melts. however, i have found this problem many times with large larder fridges and really found no cure.
for guest.
towards the bottom of the back wall, there is a gulley with a drain hole in the middle. this drain is blocked. clear it with something flexible and make sure water flows away freely
Sep 06, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
I have a larder fridge that seems to collect too much water in the tray at the back, it seems to be temperamental with cooling. It only works part time. How affected are they by not being completely level?...
this water should be evaporated by the motor heat.however, i have found with larger larder fridges of several makes that too much water is formed for it all to go.
worth while checking the door seals as well as if seal is leaking, more ice forms on the evaporator and hence more water
Aug 31, 2008 | Frigidaire Refrigerators
Refrigerators Logo
24 people viewed this question
Top Liebherr Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
