Horizontal lines tv - Televison & Video
Zenith 50 Inch Plasma TV has black horizontal lines
Generally black horizontal lines are from the panel being bad, you could try a new Tcon board but I doubt it will help
Feb 07, 2018 | Zenith Televison & Video
Two horizontal lines appeared near bottom of screen
You can spend $300 to $500 fixing this or just do the best thing most cost effective thing and replace the TV.
Aug 23, 2016 | Sharp Aquos Televison & Video
My 42 in phillips LCD flat seen has a black horizontal line toward the bottom how can I fix this.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI'm experiencing thin black lines from the top of the screen to the bottom. ... by babes808gpa / January 15, 2010 1:42 AM PST ... lines are about 1/4 inch apart from top to bottom of screen. starts on the right and about a 1/3 of the way toward the ...have the exact same problem, my lcd tv has multiple lines are horizontal it ...
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the ...
? 3:05
https://www.youtube.com/watch?v=KiqJuMiEiak
Jun 8, 2013 - Uploaded by Sameh Moustafa
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the picture SOLVED .... I just have one black line ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Dec 20, 2015 | Televison & Video
2 days ago, a narrow black horizontal line appeared in the middle of the screen.
CNETJun 11, 2015 - I'm experiencing thin black lines from the top of the screen to the bottom. ... my lcd tv has multiple lines are horizontal it starts from the right and fades too the left, ... Samsung LN55a950 - Horizontal lines on right side - Forums - CNET
Jun 11, 2015
Samsung 52" LCD TV black lines - Forums - CNET - CNET.com
Jun 10, 2015
More results from www.cnet.com
Plasma TV Repair Horizontal Lines - How to Diagnose ...
? 2:49
https://www.youtube.com/watch?v=h4XWCxUsSVU
Sep 2, 2014 - Uploaded by ShopJimmy.com
I have thin horizontal black lines on the top and bottom areas of my TV. .... Hi, I have a 2011 64-inch 3D Samsung PN64D8000 Plasma TV.
how to fix horizontal or vertical lines on lcd tv - YouTube
? 4:52
https://www.youtube.com/watch?v=k2QpYJp6MU8
Apr 12, 2014 - Uploaded by cr4zyw3ld3r
Hi my LG 47ln5700 tv set has thin greyish black horizontal lineson one side of the .... I hope this works good with Samsung LCD as well....
Dec 19, 2015 | Samsung HP-R5072 50 in. Plasma HDTV
Horizontal lines samsung lcd tv, then more horizontal lines, then complete static out, TV restartes itself. after a 5 minutes or so, it seems fine.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 04, 2015 | Samsung Televison & Video
My Ultravision TV is now having horizontal lines. Do not know if it has a horizontal hold button hidden somewhere or is the TV going out? Can I fix it myself. Large screen
Can you try and see if it is your source that has the lines or the actuall TV that has the horizontal lines.
What is your source? Direct TV, Cable TV or even off air Digital TV.
If you remove your source do you still get the horizontal lines? If you do then what colors are they? Seems if when you remove your source input and you still have these H-lines then you have issues with your individual LCD palets. Especially if they are just Green, Red or Blue?
Nov 07, 2014 | Hitachi UltraVision CineForm 55VG825 55"...
Hi.. Mine is a sansui tv and I bought it 3 years back. Now it is showing a horizontal line on the screen. Sound is fine but I can't see the picture, I just see one white horizontal line on tv...
The problem is vertical failure. Vertical output section to your TV ahs the fault. You ahve to check the vertcial output circuit for any component failure or loose solderings.
May 11, 2012 | SansuiS3275 TV
CRT TV picture keeps getting horizontal line & loud cracking nois
the horizontal section is near collapse, the lines indicate a sort or leak. Soon, the set will go black. Shut off as repair will be cheaper now! Needs professional repair as High voltage section is dangerous.. Unplug to be safe!
Mar 13, 2009 | Toshiba CF27F30 TV
SAMSUNG LCD TV horizontal lines
causing of horizontal lines is leaky or defective capacitors. check big value capacitors around the board at Horizontal area. check the filter capacitor as well. good luck
Mar 21, 2008 | Samsung LE26R73BDX 26 in. HD-Ready LCD...
Televison & Video Logo
199 people viewed this question
Top Televison & Video Experts
