Question about Dell 1600n All-In-One Laser Printer
Dell 1600N MF Laser Printer- Blank vertical strip on all prints
There is a blank vertical strip on all print jobs, copies, etc. Basically a strip that where nothing prints. It is always in the same place on the page.
  • rhg1975 May 21, 2009
    No recent paper jams that I can remember and it is a brand new toner cartridge.
  • Frank Zhang
    Frank Zhang May 11, 2010
    have you met any paper jam reently? how long the photo drum used?
  • 191 Answers
You need do follow steps:
1) take out the cartridge find a cover there is the drum inside, the drum you can see the color on the drum surface
2) check out and clean any pieces of paper or dirty waste toner stuck there, because there is a waste toner cleaner on the drum surface which is like a long rubbon strip (something like that) you can spin anyway a little to clean.
3) if you check out any different color (vertical round drum), that is the drum surface worn or scratched. you can see the worn area show light color than normal area.
so you need change it better. 4) if the color all very same and still not fix, you need check again something stuck the drum surface near cleaner rubbon.
hope help you fix it, please take a rating let me know how much helped you thanks! keep in touch your question please.
Posted on May 21, 2009
  • 1 more comment
  • Frank Zhang
    Frank Zhang May 22, 2009
    please take a rating if the solution helped you thanks! keep in touch your comment.
  • Frank Zhang
    Frank Zhang May 24, 2009
  • Frank Zhang
    Frank Zhang May 30, 2009
Printing jobs are coming out blank
Does this happen if you make a copy? Or print any internal form meter count sheet demo page etc.
Mar 14, 2014 | Konica Minolta bizhub C250 All-In-One...
Why when i print, three or four sheets come through the printer at the same time?
This is usually cause when you have more pages on your document which are blank. Check your document before printing in the preview section.
Regards
Obehi
Dec 03, 2013 | Dell 1600n All-In-One Laser Printer
Dell 3100cn printer leaves a blank strip
The following table should help
Contamination in the laser path - 1. Clean the laser path. (Remove the laser/scanner assembly and clean the lens.) 2. Replace the laser/scanner assembly
Defective fuser - Replace the fuser assembly.
Lack of toner or faulty toner cartridge - Redistribute the toner in the toner cartridge. If the problem continues, replace the toner cartridge.
Dirty Corona Wire - Clean the Corona Wire.
Defective Drum - Mostly applies to B&W printers. Clean the drum or replace the drum.
Sep 20, 2009 | Dell 3100cn Laser Printer
Canon imageclass MF 6550
Try printing a test page. Is it also blank? If so, you should check your ink system (cartridges full, etc.)
Apr 21, 2008 | Canon imageCLASS MF5550 All-In-One Laser...
DELL 1600N
If it makes verticle lines only when using the document feeder it is most likely a dirty glass strip over the scanner light bar. If it makes verticle lines in all modes (printing, flat bed scanning/copying, receiving faxes) it could be the fuser or a dirty glass over the laser where ever the laser images to a drum roller (usually a larger green roller). It is possible that this green drum roller is inside the toner - if so - replacing the toner cartridge could fix it. Maybe you could try an old used toner to see of the problem changes - if so - it is very likely that a new toner would fix your print quality issue.
Jan 09, 2008 | Dell 1600n All-In-One Laser Printer
Printer Problem
Clean the small glass strip on the left side of the scanner. There is probably some dirt there and will only show up when using the ADF.
Nov 15, 2007 | Dell 1600n All-In-One Laser Printer
Printer vertical lines
Looks like mark on drum.. Change the toner cartrige .. If the printer is older, could be that the exit rollers are worn out..
Dell 1600n and vertucal line while scanning
Any difference between using the document feeder and just the flat bed?
Nov 05, 2007 | Dell 1600n All-In-One Laser Printer
Dell 1600n All-In-One Laser Printer Logo
291 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
