Question about Bose Wave Radio / Cd With Remote model Awrcc1 With Ipod / Mp3 Connect Cable
Radio keeps turning itself on at night
Radio turns itself on at night
Why and how does my GPX radio turn on by itself?
assuming that he radio is part of a clock,and not in a vehicle , it will be the alarm setting that is not turned off or not set properly
Dec 21, 2016 | Cars & Trucks
All alarms are off radio turns itself on at night
Either the radio has all of a sudden developed a poltergeist or you have an incorrect setting some where. Check out your manual
Sep 27, 2016 | Audio Players & Recorders
Why does my 800 keep going off, then back on again, but itself ?
Try a cleaner/lubricant contact spray. Available @ Radio Shack. Pull out and spray into it, re attach knob and turn in off a number of times. Turn all the way. If problem persist your radio may have a loose wire or solder.
Jan 28, 2015 | Grundig Satellit 800 AM/FM/SW Radio
Radio Station Keeps Changing Automatically
hi there is a option in the settings to automatically search for the station if frequency changes try turning it off to see if that helps
Mar 23, 2014 | 2006 Hyundai Accent
My seat ibiza radio keeps turning itself on and running the battery down
Simple solution for anyone! Had the same problem with radio turning itself on in my Seat Ibiza Stella 1.4 2000. Here's what you do..
. Remove front panel
. Disconnect tape player and open it
. Clean the mother board paths(bottom side) with some chemical liquid not to strong(i used sticker remover) from black dirt. You can scratch between paths with a needle for better effect.
. Put all back together
. Problem solved.
It was driving me mad but now it's working when I want it to :)
Jan 08, 2012 | Cars & Trucks
Grundig s350, installed new batteries and radio keeps shutting off by itself
When you press the Power/Sleep button the radio turns on and displays a number 90, or some other numbers. This is the play time that the radio will stay on then turns itself off. It could be that yours is configured with a sleep timer set to 01 minute, 10 or 15. You need to set the timer for a longer period. Thus we turn it on by pressing the Power/Sleep button, read the timer length then press again. Keep making short presses: The timer will cycle through all preset sleep timer durations. Select the length you want.
Jun 19, 2011 | Grundig S350 AM/FM/SW Radio
Computer turns itself on
if you can get into bios check and see if there is any type of alarm or auto on set up. If not or if its not that big of a deal just use the switch on the back of the power supply at night. Make sure you shut down your computer before switching this. It will definately keep the computer from turning on by itself.
Dec 30, 2008 | Dell Inspiron E1505 Notebook
Sporadic sound
we threw away our box and cant set the time?
Nov 29, 2007 | Homedics SS-4000 Clock Radio
Bose Wave Radio / Cd With Remote model Awrcc1 With Ipod / Mp3 Connect Cable Logo
22 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
