Question about Adesso Imouse S100 Bluetooth Mini Mouse
Connection requires a passcode
Where can I find the Adesso Imouse S100 Bluetooth Mini Mouse passcode
Is there a mouse that works with the kindle fire 5th generation? Bluetooth maybe?
Jodi, Yes, you can pair it with Bluetooth mouse and possibly through mini port. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Connect to Bluetooth
Kindle Fire Wireless mouse and keyboard on ICS
Using Qwerty Keyboard Mice and other USB device on Amazon Fire 2015 via...
Can you connect both bluetooth mouse and keyboard to Kindle HD Fire 6
May 03, 2016 | Tablets & eReaders
How do you use the "send" button while using the keyboard
No idea which program you are talking about, but I would try Ctrl-S for starters...
Nov 24, 2014 | Adesso WKB-1000BW Bluetooth Mini Keyboard...
How can i activate pre-installed webcam in my dell inspiron mini 1012
Step 1: First connect the bluetooth device to USB port on your computer and check that it is detecting on your computer or not.
Step 2: Now insert the bluetooth software driver CD to your system that will auto start after few seconds then follow instruction to finish bluetooth software installation.
Step 3: Now go to 'start -> Devices and Printers' and click 'Add a device' from top of the window.
Step 4: Now your Windows 7 system will search the bluetooth device which connected to your system.
Step 5: Click the bluetooth device you want to install from the list and then click the 'Next' button and wait for windows to configure the bluetooth device. If prompted to enter a passcode, enter the default code listed in the bluetooth device manual. In many cases, the default passcode will be '0000'.
Now the bluetooth device has successfully installed and ready to use.
Note: If you bluetooth device was not listed in the search results from Step 4, make the device discoverable. Access your Bluetooth-enabled device's settings page, and turn on the device's 'Listen' or 'Discoverable' function to allow you computer to find it.
Feel free to get Dell technical assistance anytime at http://www.vtechsquad.com/dell-support/
Apr 10, 2012 | Dell Inspiron Mini 1012 Netbook...
How do you pair a jawbone to a samsung t259 phone?
To set up Bluetooth on your phone
1. Go to Menu, select Connect or Connections or Connectivity:
Note! If the above steps do not work, please consult the user manual.
2. Bluetooth - Select On to enable Bluetooth.
3. My telephone's visibility - Select Shown to all if you want your device to be found by other Bluetooth devices. If you select Hidden, your device cannot be found by other devices.
4. My Bluetooth name - Define a name for your device. After you have activated your Bluetooth service and changed My phone's visibility to Shown to all, your phone and this name can be seen by other Bluetooth device users.
Sending data via Bluetooth
If your phone supports the Bluetooth 1.1 specification or earlier, you can only have one Bluetooth connection running on your phone at any one time.
1. Select or open the file you wish to send. For example, to send a photo to another device, open the Gallery application.
2. Select the file you wish to send, then select Options > Send > via Bluetooth.
3. The phone starts to search for devices within range.
Devices using Bluetooth technology that are within range will appear on the display. You should see a device icon, the device's name, the device type, or a short name. (A paired device is one where a Bluetooth connection already exists between your phone and the other device.)
• To interrupt the search, press Stop. The device list freezes and you can start to form a connection to one of the devices already found.
If you have searched for devices earlier, a list of the devices that were found previously is shown first. To start a new search, select More devices. If you switch off the phone, the list of devices is cleared and the device search needs to be started again before sending data.
4. Scroll to the device you want to connect with and press Select. The item you are sending is copied to Outbox and the note Connecting is shown.
5. Pairing (if this is not required by the other device, proceed to step 6.)
• If the other device requires pairing before data can be transmitted, a tone sounds and you are asked to enter a passcode. • Create your own passcode (1-16 characters long, numeric) and agree with the owner of the other device to use the same code. This passcode is used only once and you do not have to memorise it. • After pairing, the device is saved to the Paired devices view.
6. When the connection has been successfully established, the note Sending data is shown. Data received via Bluetooth can be found in the Inbox folder in Messaging. Tip: Pairing is a means of authentication. The users of the devices using Bluetooth technology should agree together what the passcode is, and use the same passcode for both devices in order to pair them. Devices that do not have a user interface have a preset passcode.
Checking the status of the Bluetooth connection
• When the Bluetooth icon is shown in standby mode, Bluetooth is active.
• When the Bluetooth icon is blinking, your phone is trying to connect to the other device. • When the Bluetooth icon is shown continuously, the Bluetooth connection is active.
Receiving data via Bluetooth
When you receive data via Bluetooth, a message alert tone is played and you are asked if you want to accept the message. If you accept, the item is placed in the Inbox folder in Messaging.
Disconnecting Bluetooth
A Bluetooth connection is disconnected automatically after sending or receiving data.
Jun 15, 2011 | Cell Phones
Can't figure out how to install batteries in s100 mouse
It isn't easy to figure out how to open the bsttery compartment as there are no clues in the manual or on the outside of the mouse. The cover is the entire top side of the mouse behind the buttons, After many false starts, I found that if I get a thumb nail in the crack behind a button near the center and pull (push) straight back, it will pop off. Either side works.
May 09, 2011 | Adesso Computers & Internet
Lost my book need passcode my phone is asking for passcode to install
Well you can use 0000 it's the default passcode of your bluetooth headset. Most of the bluetooth headset use 0000 as default passcode.
Good Luck!!
Thanks for using FixYa!!
Jun 19, 2010 | Anycom CC3103 PAROS-10 MINI BT 2.0 HEADSET...
Imouse is connected but not working
info you provided is scarce so sounds like you might need a driver for your mouse or a driver for your ps2 or a driver for your usb or a new mouse
Mar 27, 2010 | Dell U0636 Mouse
Dell wireless mouse and keyboard-no instructions
Most Bluetooth keyboards and mice are just Plug-n-Play and does not require any driver installation. You need to isolate the problem, please follow the steps below:
1. Make sure that the wireless adapter of your wireless KB and mouse is properly connected to the USB port of the computer.
2. Make sure that the USB ports of your computer are working.
3. Use fresh batteries for the KB and mouse.
4. After connecting the wireless dongle to the computer, turn on your KB and mouse (there should be an ON/OFF switch underneath).
5. Briefly press the connect button on the wireless dongle and then hold down the connect button underneath the mouse for five seconds and then release it.
6. Do the same steps for the KB.
Have a good day!
Jun 27, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Adesso Imouse S100 Bluetooth Mini Mouse Logo
103 people viewed this question
Top Adesso Computers & Internet Experts
Chris Benedict
Level 1 Expert
ray gallant
Dougie
Are you an Adesso Computer and Internet Expert? Answer questions, earn points and help others
