Question about Canon PIXMA iP4300 InkJet Photo Printer
Not recognise ink jets
Whilst replacing the ink tanks i opened the print head lock leaver now printer won't print. any thoughts
    Genius:
  • 1,601 Answers
I have tried replacing all ink cartridges with brand new ones but it keeps saying Error U052 ? I am not really sure why it won't recognize the ink cartridges especially because they are from Canon
The error code indicated, the print head is defective, so it will not get solve by replacing any number of cartridges. Just follow the steps below to reseat the print head, if that does not help, then replace the print head.
  1. Confirm that the printer is powered on and press the <Open> button. (The paper output tray will open.)
    *MP800R shown
  2. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
    Note: When the scanning unit (printer cover) is opened more than ten minutes, the print head moves to the right side. If this occurs, close the scanning unit (printer cover), and open it again.
  3. Open the inner cover.
  4. Remove the ink tanks by pressing the tab of each tank.
    Caution: Handle the ink tanks with care so that your clothes and surrounding area do not get soiled. Make sure to remove the ink tanks one by one.
  5. Raise the print head lock lever.
  6. Tilt the print head slightly towards the front of the machine and lift out gently.
    Caution: Do not touch the print head nozzles <1> , electrical contacts <2>, or ink supply ports <3>. Doing so may cause printing problems.
  7. Place the print head in the print head holder and lower the print head lock lever carefully until you hear a click.
  8. Insert ink tanks into the print head.
  9. Press the mark <PUSH> on the ink tank firmly until you hear a click.
  10. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    <7> The ink tanks are installed properly.
    <8> The ink tanks are not installed properly.
    Note: Click for Ink Tank Lamp indications.
  11. Close the inner cover and the scanning unit (printer cover).
    Caution: When closing the scanning unit (printer cover), be careful not to jam fingers.
    N
    ote: The next printing begins, the print head cleaning will begin automatically.
You can check the status of each ink tank according to the way its lamp flashes.
- On: The printer is ready to print.
- Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
- Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
- Off: An error has occurred and the printer is not ready to print.
Aug 28, 2012 | Canon PIXMA MP530 All-In-One InkJet...
I have an hp psc 1215 all-in-one. My black cartridge won't print. It recognises if I swap it out for a new one, and goes through all the motions. It registers the correct ink levels. The cradle...
The problem is not with the ink-cartridges. You've proved that, by swapping BLACK cartridges.
The problem is that the ink-jets that spray the BLACK ink onto the paper are clogged.
Thus, no BLACK ink reaches the paper.
Open the HP Printing Assistant, and open Utilities, and run a few "print-head-cleaning" cycles, to try to unclog the print-head.
Jul 19, 2011 | HP PSC 1215 All-In-One InkJet Printer
Canon MX850 Original problem was error 6A00 which I resolved from on line help by cleaning the track the print head travels on. In doing so, I released the print head lock lever and removed the 5 ink...
Sometimes releasing this lock leaver causes the far side of the print head mechanism to sit out, moving the contacts ever so slightly. Release the leaver again, using a bright torch make sure the cradles are sitting correctly and the circuit board that has the contacts for the cartridges on it has not moved. this leaver holds the entire assembly together and if it is not positioned correctly, it wont work correctly!!
Regards GM
Apr 05, 2011 | Canon PIXMA MX850 Multifunction Printer
How can I remove the Canon iP3000 ink jet printed heads for cleaning?
heres the support site for that printer http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=257&modelid=10238 - downloads and drivers tab - has all the software and user manuals - the FAQ tab has a section on cleaning the printhead using software - also a link to removing the printhead
The FAQ has full images and step by step instructions Remove the print head iP3000
  1. Confirm that the printer is powered on.
  2. Open the paper output tray and top cover.
  3. Note: Gently open the paper output tray while holding it.
  4. After confirming that the print head holder has moved to the center, open the inner cover. Remove all ink tanks.
  5. Raise the print head lock lever and remove the print head.
  6. Re-seat the print head into the print head holder and lower the print head lock lever until a click is heard.
  7. Insert the appropriate ink tank into the slot at the right end and push down on the PUSH mark on top of the ink tank until a click is heard. Install the other ink tanks in the same manner.
  8. Close the inner cover and top cover.
  9. Note: Check that each ink tank is installed in the correct position.
Apr 10, 2010 | Office Equipment & Supplies
5 orange flashes
5 time orange flash indicate Cartridge Error or Print Head Error.
1) Reseat the Print Head
  • Confirm that the printer is powered on.
  • Open the paper output tray and top cover. Gently open the paper output tray while holding it.
  • After confirming that the print head holder has moved to the center, open the inner cover.
  • Remove all ink tanks.
  • Raise the print head lock lever and remove the print head.
  • Re-seat the print head into the print head holder and lower the print head lock lever until a click is heard.
  • Insert the appropriate ink tank into the slot at the right end and push down on the PUSH mark on top of the ink tank until a click is heard. Install the other ink tanks in the same manner.
  • Close the inner cover and top cover. Check that each ink tank is installed in the correct position.
2) Reseat the Printer
  • Turn the printer off with the Power button.
  • Disconnect the data cable from the printer
  • Unplug the printer's power cord for approx. 10 minutes, and then plug it back in.
  • Turn the printer back on.
Else either your device require service or print head may need to replace.
Good luck...don't forget to rate the solution
Feb 25, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
How do you remove used ink cartridge?the printer is out of black ink
Removing the Print Head / Ink Tanks Instructions to properly remove the print head or ink tanks. Remove the ink tanks before proceeding to remove the print head.
Remove the Ink Tanks
  2. Pull open the paper output tray.
  3. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
  4. Open the inner cover.
  5. Remove the ink tanks by pressing the tab of each tank.
Click to return to the top.
  1. Raise the print head lock lever.
  2. Tilt the print head slightly towards the front of the machine and lift out gently.
Feb 08, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Service error 5600 appeared when the printer stop
Dear budg,
Error code 5600 in S200 is No Print head Error indicator. In this case, the print head of the printer is faulty so that the printer cannot detect the print head. About the print out, please check if there is enough ink in ink tank to print. If there is enough ink to print, means this bad print out caused by the faulty print head. It seems that you to replace the print head.
Regards,
Dec 02, 2008 | Canon S200X Ink-Jet InkJet Printer
A big PGBK ink cartridge problem
Call - 1-800-828-4040
Verify they are installed correctly.
Remove the print head or ink tanks properly following the procedure below.
1. Confirm that the printer is powered on and open the top cover. The print head moves to the replacement position.
Note: When the top cover is opened more than ten minutes, the print head moves to the right side. If this occurs, close the top cover, and open it again.
2. Open the paper output tray and pull down the inner cover.
3. Remove the ink tanks by pressing the tab of each tank.
Note: Handle the ink tanks with care so that your clothes and surrounding area do not get soiled. When replacing multiple ink tanks, make sure to replace one by one.
ip4200_ink_remove.gif4. When removing the print head, raise the print head lock lever first.
raisephlocklever.gif To reinstall the Print Head and Ink Tanks
1. Place the print head in the holder and lower the print head lock lever carefully until you hear a click.
putinphnlockit.gif2. Insert ink tanks into the print head.
Press the mark 'PUSH' on the ink tank firmly until you hear a click.
3. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
<1> The ink tanks are installed properly.
<2> The ink tanks are not installed properly.
Note: <Ink Tank Lamp> You can check the status of each ink tank according to the way its lamp flashes.
4. Put back the inner cover and close the top cover.
Note: When starting printing next time, the print head cleaning launches automatically.
During the print head cleaning, the Power lamp flashes green. Do not do other operations until the flashes stops.
James Mac
Sep 10, 2008 | Canon PIXMA IP5200 InkJet Photo Printer
Getting error 681 "more thn one magenta tank instaleld" on MP530
Install the Print Head and Ink Tanks MP530 / MP800 / MP800R / MP830
Install the Print Head and Ink Tanks Instructions to install the print head and ink tanks.
Follow the instructions below for Installing the Print Head and Installing the Ink Tanks.
  2. Pull out the print head from its package, then remove the orange protective cap from it.
  3. Place the print head in the print head holder and lower the print head lock lever carefully until you hear a click.
  1. Unpack the ink tank and pull the orange tape off completely in the direction of the arrow and remove the film.
    Note: Tear the orange tape carefully along the dotted line. If the orange tape remains, printing problems may occur.
    <4> Tape is completely removed.
    <5> Tape remains.
  2. Remove the orange protective cap located on the bottom of the ink tank by twisting as shown in the diagram.
    Caution: Do not touch the ink tank contact <6>. Doing so may cause printing problems. Do not squeeze the side of ink tanks as this may cause the ink to leak out. Do not reattach the protective cap once you have removed it.
  3. Insert ink tanks into the print head.
    Note: Press the mark <PUSH> on the ink tank firmly until you hear a click.
  4. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
  5. Close the inner cover and the scanning unit (printer cover).
    N
Jan 22, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA  iP4300 InkJet Photo Printer Logo
old marine
old marine
