Question about Fellowes Manufacturing Powershred PS-77Cs Shredder
PS-773c overheats with use - Fellowes Manufacturing Powershred PS-77Cs Shredder
Overload overheat
Here is a link to the manual for a Fellowes PS60 Shredder.
Maybe it will help you in resolving some of your problems.
https://app.box.com/s/q3r8jlatlfskvgyh5ne6
Fellowes Shredder PS60
Oct 14, 2013 | Fellowes Powershred PS-60 Shredder
Ps 3 overheats
Try getting an air can or blow into the fan to getting any dust out of the system causing it to overheat also make sure your fan is not against anything and can get good airflow
Aug 08, 2013 | Sony Playstation 3 (PS3) Console
Am using a microsoft multimedia keyboard 1.0A and some of my keyboards just wont work
Keep the Keyboard Below the Table lamp, or Heat with hairdryer for few minites, do not overheat, touchable warm. If still not working then you have to replace the Keyboard. best of luck.
Jan 28, 2011 | Microsoft Natural MultiMedia Keyboard...
Too wide screen
change the resolution in one that fits better ..To change it try to right click on desktop choose properties..and in the window that opens choose setings ..you will have a slide button for resolution ..change them into one with equilibration between the width and length ..for example if it is a 1280 /768 ...set one to 1.24 on 768 ..will be almost 3/4 ..
May 22, 2010 | Dell E773C 17" CRT Monitor
No steam coming out
Is the red overheat warning ligth on? if so, press the reset button, that should reset the thermostat and make it work again.
Mar 13, 2010 | Homedics PS-200 Iron with Auto Shut-off
I am working with Dimension 2400 with monitor 773c blank or no display, drivers load after safeboot, but I am not sure what to do from there, nothing happens when I push enter, but the monitor works with a...
Refresh Rate, the reason why it works in safe mode and not normal mode is because in safe mode the system only loads the most basic and reliable drivers and sets the screen resolution and rate to their default values. In safe mode right-click on the desktop and go to properties, go over to the tab Settings and click Advanced. You should see another tab that says Monitor, there you can change your Hz, change it to something like 60hz to be on the safe side.
Jan 27, 2010 | Dell Dimension 2400 PC Desktop
Cooling fan comes on alot. even after driving for 30 mins de-mister air is still cold. PS. fan will always come in the first 10 mins.of driving.
do you have air conditionning and in defrost its normal for the fan to go on let me know if our car overheat thanks pierre
Aug 17, 2008 | Toyota Yaris Cars & Trucks
Tower Will not turn on.
Blinking yellow/amber light indicates PS not operating within specs. You can look at replacing the PS but might need to find out if something else caused the PS problem, such as other components caused the PS to overheat, etc. Were you having any problems with any of the drives? Strange noises etc?
Aug 04, 2008 | Dell XPS 200 PC Desktop
Electrolux EOG7330 gas cooker - electric timer fails?
Pull off bottom knob of oven shine torch down at 45degrees u will see a red plate turn off power suply and use a small screwdriver to push the plate turn power back on job done.PS Check all vents are clear to stop it over heating good luck.
Jul 18, 2008 | Electrolux EOG7330WN Gas Double Oven
Fellowes Manufacturing Powershred  PS-77Cs Shredder Logo
Top Fellowes Manufacturing Office Equipment & Supplies Experts
Andrew Taylor
Andrew Taylor
 Bob Buchholz
Bob Buchholz
Are you a Fellowes Manufacturing Office Equipment and Supply Expert? Answer questions, earn points and help others
