Question about Fellowes Manufacturing Powershred PS-77Cs Shredder
PS-773c overheats after shredding less than 50 pages
My shredder just runs want shred paper cost to much to ship it to Royal company
unless it is a office size that can shred many pages and staples at once ,just junk it and get a new one
most cost less that the paper to wrap in in for transport.
Jul 01, 2015 | Royal Office Equipment & Supplies
Omnitech wont shred papers.
Sounds like its jammed? Have a really close look for staples, paperclips etc stuck in the drive gears or blades
May 19, 2015 | Office Equipment & Supplies
Omnitech shredder ot-nxc10pa
You must first unplug it and look inside the shredding blades, especially around the spot usually near the center, where there is a pressure button. When paper hits it, it starts shredding. Chances are some pieces of paper have jammed just over it stopping paper from hitting it and switching it on. I have had to use long tweezers to work the jammed bits out... Once clear it will work again. Also using shredder oil every 50 sheets through will help it cut easier , and jam less frequently. Do not put too many sheets through together in a bunch. No staples...
Aug 23, 2014 | Office Equipment & Supplies
I have an Ativia 6000 shredder. The red light comes on and the shredder stops, after only shredding a few papers..why?
If place too many pages in the shredder the motor will be overworked and it will overheat and shut down until it has cooled down. Try shredding fewer pages at a time.
Jul 03, 2012 | Computers & Internet
The shredder overheats. The most we can shred are
Have you put any shredder oil or a shredder oil sheet through the machine.
Shredders need oiling to keep the cutters free
Free cutters mean clean cuts and less friction
Jan 14, 2010 | Intimus 502 Shredder
My Fellowes ps-40 will not shred. The motor is
you have some shredded gears. i don't think fellows has replacement parts for their personal shredder line.
Nov 15, 2009 | Fellowes 3011001 Shredder
Shredder will not start when paper is inserted. switch is on auto. This happened after a long session of shredding
Two possible problems;
  1. Teeth underneath lid are jammed; sometimes (especially after a long session) although the papers go through, debris builds up and can get caught in the teeth; to clear unplug and with tweezers or a tina flathead screwdriver, pull out shreds of paper still caught
  2. Motor is overheated; once cool, try it again (move switch to reverse to see if motor is still working). If motor is working, see Step 1 for a jam; some jams can be cleared by running it in reverse. Royal doesn't recommend "long" shredding sessions. My unit recommends sessions of 20 pages or less. If you try to overwork the shredder, it will overheat and in some cases, fry the motor.
I hope this helps answer your problem. Best of luck!
Greg
Nov 12, 2009 | Royal 10X Shredder
PS-70-2 not working
Make sure the pull-out wastebasket is all the way in. Also, make sure the basket is less than half full. A paper jam could also cause this symptom.
Jan 22, 2008 | Fellowes P70CM Shredder
Fellowes Manufacturing Powershred  PS-77Cs Shredder Logo
42 people viewed this question
Top Fellowes Manufacturing Office Equipment & Supplies Experts
Andrew Taylor
Andrew Taylor
 Bob Buchholz
Bob Buchholz
Are you a Fellowes Manufacturing Office Equipment and Supply Expert? Answer questions, earn points and help others
