Question about Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine
Wont drain after cleaning - Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine
    Problem Solver:
  • 39 Answers
Remove the drain tube in the sump. be careful not to loose the o ring at the bottom.
Posted on May 10, 2014
Drain is clear but ice stilll forming in bottom of freezer
Use a steamer to blast the drain clear... sometimes you need to install what is called a heat probe that feeds into the drain tube to keep it from freezing over... Help Me Find My Model Number RepairClinic com
Oct 04, 2016 | Freezers
Fix-ya
Find the water drain hole/pipe and clean it thoroughly with a pipe cleaner or other softish flexible rod. That should allow the water to drain away. Make sure back of the unit is clear and clean so water drains and evaporates off properly.
Jul 31, 2014 | Fisher Paykel ActiveSmart Fridge - 17 cu....
Where is the drain plug on the Amana upright freezer? How do I get to it to check for clog and clean out?
The best thing for you to do is unplug the machine and let the ice completely thaw. After that you gain access to the top of the drain you'll have to remove the back wall and the drain hole is under the evaperator. From behind the machine you should be able to see the bottom half of the drain. it sometimes has a rubber piece on it that resembles a duck bill. It that is indeed there remove it because that would be the source of the problem.
Apr 23, 2012 | Amana Freezers
How do I remove the drain pan to clean it. My freezer is frost free frigidaire upright. The defrost timer went out and some of the food defrosted and drained into the pan and on the floor. There is some...
On older freezers/refrigerators the drip pan could easily be removed. On newer models its now part of the base frame and their is no way to remove it. Dam shame if ya ask me since it was recommended noraml to remove and clean drain pan every couple months, but hey ain't modern technology great hehehehe
Gene
Aug 01, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Drain keeps freezing
The problem may be the freezer drain heater has failed, locate the drain inside of the freezer compartment and check to see if it is warm, if not you may need to replace the heater.
Jun 30, 2010 | Woods Upright Freezer MU07W
Drain hole at rear keeps icing up. Fridge normal temperature is +4 degrees C
try a couple of drops of clorine bleach to clean out drain first,could be just moss in drain...
Mar 06, 2010 | Freezers
We need help cleaning our Hoshizaki ice machine. Our boss does not know how to clean it and he told us to figure it out. That's where you come in.
k well that will depend im not really an expert on it but i did clean 2 freezers so im thinking that theyd be pretty much the same...hope i can help. first of take all the ice out of the machine. since it looks nice and new im thinking that the put thought of cleaning into making it.so i think theres a drain in there. not sure how clean you want it just take a scrub pad and soap(if you find the drain) the rinse it out. not sure y you would want to clean it though.
Jan 28, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Very thick ice collects in bottom of freezer
the drain pipe you cleaned out has a p-trap that holds water. after awhile this trap will build up sludge and possibly freeze up. i recomend defrosting the drain pan again and try some way to forcfully flush hot water thru the drain. I use a turkey baster filled with water to do this. if the drain continues to freeze you may need to install a heat trap to keep drain from freezing.
a heat trap is just a piece of 10-12 guage solid copper wire with about 3 inches in the drain and the other end wrapped around the defrost heater which is the BLACK rod attached to the bottom of the evaporator coil in the freezer compartment. if you need any further assistance just let me know Peyton
Jan 27, 2009 | Bosch Freezers
Belling be810
Hi the problem is with a clogged drain hose that's why all the water. to unclog turn off fridge. pull away from the wall . remove back panel. clean all vents . locate drain tube, by the drain tray. clean out the drain . thanks the appliance doc
Oct 06, 2008 | Belling Freezers
Maytag Frostfree Freezer ice at bottom
hi thanks for the question .The drain tube is clogged up. Pull fridge away from wall, remove back panel, clean all coils. let thaw 24 hrs. find drain tube by drain tray clean tube to freezer thanks the appliance doc
Sep 28, 2008 | Freezers
Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine Logo
73 people viewed this question
Top Hoshizaki Freezers Experts
Dennis Boxerman
Dan Webster
Dan Webster
Are you a Hoshizaki Freezer Expert? Answer questions, earn points and help others
