Question about HP LaserJet 9040n Printer
Flaws at top of each page when printing
Our HP Laserjet 9040n is about a year old and has been marking each page when printing with marks at the top of each page ( always five sqiggle-like marks about 5mm grey markings) at consistant distant apart on everypage.  I have done a cleaning page and we have taken out the rollers and given them a wipe but nothing has changed. It is consistant and prints these marks on every print out whcih we make.
Please help- this is very annoying since I work in a design environment and we need 'clean' print offs.
  • Joon Oct 19, 2007
    Thank you for the suggestion. I've done all of the above but still have the marks. the marks look like a squiggle ( all exactly the same mark in five consecutive places only at the top of the page) Looks like a up and down, arrow shaped marking).
  • HP Master
  • 1,113 Answers
Replace toner cartridge drum is scratched
(Possibly by staple going threw machine if that what each of the five marks look like, all those removed staples always seem to end up in printers)
You can pull it out (I think right top cover opens and cartridge pulls up and to the right)  then .. turn it over and gently pull back cover see drum has same marks as you see on paper, you can gently rotate drum by using gear on edge do not force it only turns easy one way, Do not touch drum surface very delicate and sensitive. Normal disposable item buy a New cartridge here is HP part number for your model  HP C8543X (HP 43X) Toner Cart.
Posted on Oct 19, 2007
  • Soulvisitor
    Soulvisitor Oct 19, 2007
    If you have already put in a new print cartridge then we need to eliminate the problem being a scratch on upper fuser roller.
    You can do this by purposefuly jaming the machine, with a little patience and timing, try to do a print and stop machine (open top cover)  when paper has passed the cartridge but not finished fusing, that means before hot bit on left end
    Remove cart and look at printed but not fused document, is mark present before fuser?
    Fuser roller wear is normal and can be fitted by yourself, life is meant to be 300 000 but 250000 is more true.
    You can remove fuser to inspect rollers left side door, remove duplex option if installed then two blue or green tabs down low inside left opening at front and back, fuser is hot be warned, pulls up and left.
    You might also want to try printing to face up tray instead of face down to see if turnaround guide is being nasty
    Does it do marks when using other trays and also the manual bypass?
  • Soulvisitor
    Also just thinking of your arrow description, check transfer roller guide plate for damage, thats under cart, a black rolller sits in base of machine running it's width, near roller from memory ther is a row of metal points that brush underside of paper to applie a charge, are they bent, dont touck roller with fingers, is also a common wear item, you can purchase a maintence kit for these that install easy with instructions that includes all feed rollers, transfer roller and fuser. Can get via hp or aftermarket suppliers think its a 350 000 Maintenence kit about 300 aus$
Why doesn't it print on LABELS at the top of the page?
I share a link please visit and follow step by step instruction.
I hope solved your issues.
HP Printer Support
May 30, 2014 | HP LaserJet 1020 Printer
Hp p3005n trouble
Repetitive flaws in the printout can indicate problems with the fusing assembly, charging roller, image drum, paper feed rollers, or other parts. The key is to measure how far apart each print defect is as measured from the top of the page to the bottom. For example, if the distance between the first defect and the next is 3.75 inches, the problem is the image drum. You can find a list of the measurements at:
HP Support document HP Support Center
May 14, 2014 | HP LaserJet 4 plus Printer
HP 6050 leaving black marks of the back of prints
you need to print clean page two or three times to clean printer path for toner , then check the last page you if there other black market , tell me , what black market looks like , hope that helped you
Mohamed Hejazi
Afaqnama Libya
Feb 25, 2013 | Office Equipment & Supplies
Hi i am unable to get the page counts on my Hp laserjet 3005dn printer
Press MENU
Press down arrow, look for INFORMATION, Press Check Mark
Press down arrow, highlight PRINT CONFIGURATION, Press check mark
I believe you will find "engine cycles". That will put you very close to actual page count
Jan 20, 2011 | HP LaserJet P3005dn Printer
HP LaserJet 1100A unwanted toner marks on face of print
check this link,
either fuser or print drum. to verify , start print job, open door before finnished and see if marks appear before or after fuser. Before paper gets to fuser toner ink will smudge.
Feb 15, 2009 | HP LaserJet 1100a Printer
HP LASERJET 9040n not r4esponding
ok man in system how many printer are installed if u have two printer intalled u have to set ur laser pariner as a defolt printer then after try to print in your network ur laser printer is a defolt printer so try it
Feb 26, 2008 | HP LaserJet 9040n Printer
Laserjet 2300d
Probally fuser needs replacing, they come out easy it is a the hot bit at rear, these just click out after removing rear door, upper heat roller will be marked if this is causing your problem
Another way to tell if it is crtridge or fuser (tt is one of these two) is to stop a print half way by opening cover when paper is halfway threw insides of printer (timeing, timeing). Then pull out cart see paper under it that is printed but not yet fused (rubs off) if no mark present then it gets on paper when it goes threw fuser, if mark is present then it is the cart.
Oct 20, 2007 | HP LaserJet 2300d Printer
HP LaserJet 9040n Printer Logo
109 people viewed this question
Ben Johnson
