Question about Lanier Office Equipment & Supplies
Lf312 pfax machine pcu
ECM code - how do you clear or change settings
3 Suggested Answers
jaylex
  • 417 Answers
SOURCE: PCU?
Hi the you will be able to purchase the PCU (Photo Conductor Unit) it is customer changeable so type in the following in google there you will be able to find a store that sells them.
Photoconductor unit for ricoh 3310
Thanks J
Posted on Jan 28, 2008
  • 903 Answers
SOURCE: how to clear the pcu code
The printer is set to display the "replace PCU" message after a set number of copies. The only way to clear the message is to replace the color PCU that the message mentions.
Posted on Jun 05, 2010
How do i fix the error message set pcu correctly on my ricoh aficio sp c811dn
Turn the machine off. Open the access door and remove the cyan photoconductor unit. Check the contact pins are straight and undamaged. Gently reinsert the unit. Turn the power back on. If the machine still does not recognise the pcu is inserted it is probably damaged and needs replacing. How many copies/prints has your machine done?
Nov 05, 2015 | Ricoh Aficio SP C811DN Laser Printer
HP error code 363, what does this mean?
I went online and found the HP8600 user manual and this is their solution to the error code 363 that you reported, which I copied off their site. Hope this works for you:
  • Turn Error Correction Mode (ECM) off, if you encounter the same error repeatedly. Click this link HP All-in-One and Fax Products for more information on enabling or disabling ECM.
    beaac3qsmgaaaaaelftksuqmcc
    NOTE: Error codes that apply specifically to ECM have ECM listed next to them.
Error Code: 356, 357, 358, 359, 360, 361, 362 ECM, 363 ECM, 364 ECM, 365 ECM, 366 ECM
Definitions
  • The remote user pressed the Stop key, causing the session to be terminated.
  • The remote machine encountered a system problem such as no paper or a paper jam. This prevented the fax from receiving any more pages, and caused it to terminate the session prematurely.
  • The call-waiting service can cause this error. The click, heard for an incoming call, is actually a momentary disconnect of the line.
  • The remote machine encountered an incompatible feature causing it to terminate the session.
Solutions
  • Configure the remote machine for document reception by clearing any paper jams, loading sufficient paper, and clearing any other error messages.
  • Configure the local fax machine to use a slower reception speed.
  • Enable or disable the ECM setting.
May 27, 2014 | HP LaserJet 3050 All-In-One Printer
How to change memory transmission settings for lanier lf312
Sharp fax UX-84/ FO-90 probleme: sortie des papier ne fonctionne pas
Jan 23, 2013 | Office Equipment & Supplies
How to clear the pcu code
Apr 17, 2010 | Ricoh Aficio CL2000N Laser Printer
Afficio 450 or gestetner 3245 calibration
Dev. Change Process
1. Check that Dev. unit has the lastest seals.
2. replace dev. material.
3. Dump dev.
4. add new dev. material.
5. Hand rotate the dev. unit 10 times.
6. reinstall the dev. unit into machine.
7. cover the toner inlet opening with a piece of paper
8. insert PCU unit.
9. turn the machine on.
10. When machine reaches ready -- enter SP modes and perform SP-2801 (2 times)
11. open the right cover of the machine. Cheat the right cover switch. Examine the drum as it rotates. Afew bands of toner and the ID pattern will be developed on the drum. The drum should be clean -- a slight dusting on the drum is OK.
12. Perform SP-3001 -- ID sensor initial setting.
13. ** Important** remove the PCU unit. Empty the toner from the PCU by sliding the shutter on the bottom of the PCU to the side and tapping the PCU.
14. reinstall the PCU.
15. Run test copies.
Pls rate -- thank you
Mar 02, 2009 | Ricoh Aficio 450 Copier
Change developer for Aficio 1018
Open the front and right covers and remove the toner bottle holder unit.
Pull out the Photoconductor unit(PCU) with your thumb pressing on the latch on the left side of the PCU.
Separate the top part from(drum) the bottom part(developer unit), by removing the front piece 1 screw and rear piece 2 screws and 1 coupling(pull out).
Now remove 1 front screw, 2 rear screws and other 2 top rear screws to separate the top and bottom parts of the dev. unit.
Then place your finger under the front-side and rear-side flaps and push out so that the flaps pops off the peg.
Set the coupling removed, back to the shaft and turn the coupling to remove the developer from the roller.
Turn upside down the lower part of the dev. unit to remove all the developer by turning its gears.
Load new developer evenly in the openings of the lower dev. unit and pay attention not to spill developer on the gears.
Reassemble the whole PCU properly.
Reinstall back the PCU and toner unit and close the front and right covers.
Switch on the machine, enter SP mode- Clear key, 107, hold and press Stop key.
Enter SP 2-214 and execute to reinitialize the TD sensor.
Switch off and on the machine.
Good luck and please rate me, thanks.
Oct 29, 2008 | Ricoh Aficio 1018D Copier
Time to change PCU
You just have to press the "yes" button. Watch the display. It says "Change PCU Y/N"
Mar 26, 2008 | Office Equipment & Supplies
RICOH PHOTOCONDUCTOR UNIT CLEAR CODE????
Actually, there isn't one! But, you can get rid of the message. Press clear modes, 1,0,7, and then press and hold clear stop. Choose copy sp. Scroll to 5, (mode) then scroll to PCU alarm setting. There are 2 options. Display will shut the message off. If it is a 1, make it 0, or vice versa. Interval, will set the count. You can make it an 80, and that will give you 20000 more prints. Personally, I would change the PCU really soon, other wise you will pay for it in toner.
Mar 17, 2008 | Ricoh Aficio 2022 All-In-One Laser Printer
The PCU Reset procedure needed
switch the machine off at the switch hold down online and escape while switching on the switch , hold the buttons till you see service mode on screen , you need to go to engine , then drum , there you will find the setting to reset the pcu , or under data log is a function pm counter clear if it is giving you replace pcu on the screen
Nov 01, 2007 | Ricoh Aficio AP3800C Laser Printer
27 people viewed this question
Top Lanier Office Equipment & Supplies Experts
Adorjani Laszlo
Anthony Karuku
George Mclaughlin
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
