Samsung washing machine wf550bobkwq shows 4e - Washing Machines
5 Suggested Answers
SOURCE: washing machine
Hey 4E error comes in case
1. No proper water supply
2. The Outlet pipe sould be at AT LEAST 60 CM to max 90 CM HEIGHT ie to the height of the washing machine, try putting the outlet pipe to the holder at the back of the machine.
rohityadav79@gmail.cm
Posted on Feb 03, 2008
SOURCE: Samsung Washing machine fault
I have foud a solution 4E error for my Samsung WD7101CKW. Water that comes inside washer is splitted in splitter with valves. One of these valves has a red label on it - this is a valve with restrictor of flow inside. This restrictor is used to limit flow speed mainly for testing purposes of pressure/water level sensor. Because of that restrictor (red cap with two holes of 0,5 mm diameter) blocked flow too much, after some time washer controller thinks that water has too low pressure.
Unplug washer, disassemble hoses from valves, disassemble valves from the washer (screwdriver needed), drill both holes in red restrictor to 1 mm (use 1 mm drill or just big needle). Assemble in reverse. Will work :)
Greetings - Thomas
Posted on Apr 17, 2008
  • 13 Answers
SOURCE: Washer keeps displaying '4E' Lack of water error
If you have pulled out and cleaned the filter at the back of the machine where the hose connects then I would check that your pump is not running during the cycle and also make sure your drain line is at least half way above your drum at its highest point, If its too low then it will drain off even if the pump is not running.
Posted on Apr 11, 2009
blueextc3221
  • 15935 Answers
SOURCE: 4E code keeps apearing
When error message 4E is displayed, you should clean the water hose mesh filter. To do this:
1. Turn off the water source to the washing machine.
2. Unscrew the hose from the back of the washing machine.
3. With a pair of pliers, gently pull out the mesh filter from the end of the hose and rinse it under water until clean. Also clean the inside and outside of the threaded connector.
4. Push the filter back into place.
5. Screw the hose back onto the washing machine.
6. Turn on the faucet and make sure the connections are watertight.
Also, please check the following:
• Make sure the source water faucet is turned on.
• Check the water pressure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 13, 2010
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    I have a samsung smart wash B1245S 6kg . when i set it on for a quick 30 min wash it will fill with water for about 10 mins . Then it will cut out and 4E will flash up on the digital display
    Display shows 4E.
    Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the preset water level after 10 Minutes or more at the time of initial water supply. The error status can be cleared by turning the POWER switch OFF and back ON.
    Dec 17, 2010 | Samsung Washing Machines
    Washing machine stops and flashes 4E
    1. WATER SUPPLY ERROR – Display shows 4E.
    Feb 23, 2010 | Washing Machines
    4E showing on Samsung Washing Machine
    Apr 06, 2009 | Samsung WF337AAL Front Load Washer
    4e code
    I just checked the Samsung website - you can download the manuals if you've lost them (website below). Not sure what washing machine you have but a 4E on model J1043 (which is the machine I have) says to check the following:
    i_1.gif Make sure the source water faucet is turned on.
    i_1.gif Check the water pressure.
    http://downloadcenter.samsung.com/content/EM/200701/20070109165927703/EN/J1043-01986D_sub7_eng_050708.htm
    Hope this helps.
    Dec 26, 2008 | Samsung WF337AA Front Load Washer
    Washing Machines Logo
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
