Question about Sewing Machines
Necchi 535fa Stop motion knob won t reconnect.. Needle does ont go up and down
  • 323 Answers
SOURCE: Stop Motion Knob
Dear Jim,
I'm sure you have a pair of Channel lock pliers around.Place a fairly thick piece of fabric around the inner knob to keep from scratching it. Grasp it with the pliers while holding the handwheel and turn it to the left. IF you can't hold the wheel to keep it from slipping, place a screwdriver or something else under the needle set screw area, turn the wheel until the set screw is resting against the set screw and then turn the inner knob with the pliers.
sewman7
Posted on Sep 03, 2008
  • 3 Answers
SOURCE: Handwheel on Sewing machine no longer moves needle.
Actually you should have a "set screw" in the hand wheel. The set screw is usally locked down tight to keep the hand wheel from spinning freely. I f you can run the machine slowly and hold the hand wheel in one place but the machine continues running, then you do need to replace the "set screw". If you replace it you will find that you can offset some of the machines vibration by where you lock the wheel down. Trial and error is the only way to achive this adjustment, kind of like balancing the tires on your car.
Posted on Feb 13, 2009
Australian S
  • 46 Answers
SOURCE: I just replaced the belts on my Necchi 535FA, but
If the belts are not tight enough they will slip, they should all be fairly tight but not like a piano string if you know what I mean.
As you do not describe what the machine is doing wrong I can not really say any more at present, except make sure there is no oil on the belts and the machine has no tight spots when you turn it over by hand.
Posted on Jul 07, 2009
RickE1
  • 202 Answers
SOURCE: I've got a Necchi 535FA with a bobbin thread that doesn't hook.
Sounds to me like you may have put the needle in backwards. The flat side should be to the back.
Rick
Posted on Aug 29, 2009
  • 980 Answers
SOURCE: took stop motion knob off how do the pieces go
You should have a three pronged washer, put that on first anyway round, then put the stop motion wheel on and tighten fineger tight, tighten the small screw that should be on the stop motion wheel and tighten a bit more, if it does not tighten up take the stop motion wheel off and put the three pronged washer in a different position.
Posted on Jul 18, 2010
I have a Necchi 3101FA. I am trying to figure out how to release the stop motion knob so that the needle won't run while I am trying to thread the bobbin. Does anyone have any idea?
the hand wheel is a 2 part device hold the outer wheel and release the inner part by turning it toward you . wen done winding bobbin retighten the wheels together .
Aug 26, 2015 | Necchi 3101 Mechanical Sewing Machine
I need a manual on a necchi 535fa
Try this web site:
http://www.sewingpartsonline.com/needle-threader-singer-503277.aspx
Jun 11, 2015 | Necchi Sewing Machines
I dropped the feed dogs on my Necchi 535FA to free motion quilt, but the material won't move. What else do I need to do?
MAKE SURE THE DOGS HAVE BEEN DROPPED. YOU NEED TO ALSO HAVE A PRESSURE FOOT THAT IS ROUND; ABOUT A DIME SIZE. ADJUST THE PRESSURE ON THE FOOT. IF YOU'RE WAITING FOR THE MACHINE TO MOVE THE MATERIAL IT ISN'T GOING TO HAPPEN. THAT IS WHERE YOU COME IN. MOVE IT WHERE YOU WANT IT. I HOPE THIS IS HELPFUL.
Oct 31, 2014 | Sewing Machines
Will a NECCHI 535FA sew denim jean material okay?
Use a heavy needle and a product called jean-a-majig from Joann fabrics and you will be fine, just make sure you use the correct needle as this is key
Aug 21, 2010 | Necchi 3101 Mechanical Sewing Machine
Threading the bobbin- Necchi 535FA
Hi - I have a 510 Necchi sewing machine - how do a fill the bobbin?
May 04, 2010 | Necchi Sewing Machines
Rick
Aug 24, 2009 | Necchi Sewing Machines
Sewing Machines Logo
32 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
