Question about Monster Cable HT700 PowerCenter 8-Outlet Surge Protector
How to reset if buzzing - Monster Cable HT700 PowerCenter 8-Outlet Surge Protector
LG washing machine will not spin just makes a click sound an buzzes? any help?
any error codes, make and model no. would help.
some swear that unplugging and waiting a moment and plugging back in will reset. some say, doing same and holding in start button while unplugged for 10 seconds will reset. not sure about those, but pretty easy to try.
Oct 05, 2015 | LG Washing Machines
FMV152KWA microwave buzzes when not running
Missy Uhland Bauman,
I understand that you are hearing a buzzing noise from your microwave, even though the door is shut and and it is not running. I would suggest to give the appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for 3-5 minutes. After the 3-5 minutes, bring power back. If you are still hearing a buzzing sound, I suggest either contacting the manufacturer or your local authorized technician.
-Best Regards-
Jan 10, 2014 | Frigidaire FMT118E1B Microwave Oven
My Plantronics Voyager Legend has a constant buzzing noise, it does not work at all. When I turn it off or on, it does not matter, just a buzzing noise.
I just had this happen to me. Like yours mine just kept buzzing and the on and off switch had no effect. It just kept buzzing.
The way I was able to fix it was to reset the device by holding both the mute button and the call pick up button until the buzzing stopped. It took only 3 seconds to fix and it immediately began to work. When I switched it on the buzzing was gone and it was working again.
I hope this helps anyone as I didn't see and answer to this issue online anywhere and had to figure it out myself. Take care.
Mar 18, 2013 | Plantronics Voyager Legend
Bernina Aurora 450 Sewing Machine
If the buzzing noise is coming from the motor it may be the suppressor on the way out and unfortunately for a Bernina it will be a shop job, if the buzzing is coming from the foot control then you can undo the foot control and take out the suppressor and discard it.
Mar 10, 2010 | Sewing Machines
Zanussi oven timer buzzes at 20.00 then resets to 12.00
Gave up and bought a new timer module for £66 from espares. Timer board has microscopic components so even if you knew what was wrong it wouldn't be fixable.
Sep 22, 2009 | Zanussi ZBF360 Electric Single Oven
"lense error, restart camera"
on the camera bottom by the battery theres is a little niddle size reset button press it wit niddle when camera is on then it will restart to factory setting you can try more then ones pushing it.please leave comment,vote,note.thankyou
Sep 13, 2009 | Canon PowerShot A470 Digital Camera
I have a ruud achiever uaka outdoor central air system, the first time i ran it this summer it tripped the breaker. It stayed on for a good hour as it cooled the house to the desired temp. then it turned...
start components are likely bad causing comp to pull high amps tripping breaker careful resetting the breaker they can explode stand off to the side
you need service all so have preventive maintenance done on the unit
Jun 19, 2009 | Ruud UAKA037 Air Conditioner
Alarm
You can press the four push buttons at same time to reset the watch and then set the time again, it will help you to solve the problem
Thanks
Tsai
Nov 05, 2007 | Freestyle Shark Buzz Wrist Watch
Meat probe button on control pad
there is no real way to reset it you reset it when you turned the breaker off, It sounds like the EOC (electronic oven control) is faulty. I would just keep reset it and keep doing that to bake the turkey how hot will it get before it buzzes? is it showing any error codes?? F1, F2, F3 etc.....
Sep 30, 2007 | Jenn-Air JES9860 Electric Kitchen Range
Monster Cable HT700 PowerCenter 8-Outlet Surge Protector Logo
534 people viewed this question
Top Monster Electronics - Others Experts
Are you a Monster Electronics - Other Expert? Answer questions, earn points and help others
