Question about Toastmaster TLWTOB6 Lightwave Toaster Oven with Convection Cooking
Bulb replacement - Toastmaster TLWTOB6 Lightwave Toaster Oven with Convection Cooking
Unusual screw head
take picture of it w/ phone or camera or anything u have thats digital. Take to lowes, or depot, or somewhere possibly that sells tools and ask sales person.
Aug 02, 2012 | Toaster Ovens
Hamilton Beach 31197 blower not working
There is no fuse. This is not an easy repair. I replaced mine which had an open winding. HB tried to make this unit so it could NOT be repaired, but of course it can be if you want to spend the time. The motor is part of a metal duct assy which also holds the rotisserie motor. It is RIVETED to the interior wall of the oven. The fan motor is a DUAL shaft C-Frame shaded pole 120 VAC ~ 3000 RPM ~ .5 amp motor which is not very common. The thermo on all these units is also inaccurate as the "sensor" is simply a metal plate screwed to the top right area of the oven interior. When I replaced my fan I also put in a new REAL oven thermo with a 12" sensing bulb which I mounted inside the oven as it should be. It took some searching to find these two parts. I have all the instructions and can post images if you want to tackle this. I did because the oven is large and the replacement model (31100 for $69 at Wal-Mart) has 1.5" less height and it uses the SAME parts with the same design flaw for the thermo. The retail cost on the parts for this job are ~$160, but I got mine for $15 total. I paid $48 for this oven years ago at Sams.
Apr 14, 2012 | Hamilton Beach 31197 120 Watts Toaster...
My Hamilton Beach Toaster Oven Model 31197s will not heat. It appears that the temperature control element is broken. Where can I get a replacement part.
I trashed the toaster oven. Apparently even if you know how to fix something you can't get the parts. If you need to take apart an appliance to fix it, you can rest assured you cannot get a replacement part. This is our throw away society.
Dec 18, 2009 | Hamilton Beach 31197 120 Watts Toaster...
Panasonic NBG100-P Toaster Oven Element not working
you cant , the elements are welded to metal straps that connect them , not made to repair
Jan 22, 2009 | Toaster Ovens
Bulbs for infrared toaster oven
Blue Devil,
The bulbs are available from the Panasonic parts store (Google), however I called Panasonic service and they could not explain to me how to take the toaster apart or tell me how much the repair would be. I partially disassembled the toaster and still could not figure out how to replace the bulb. Sorry. Good luck.
Todd
Aug 22, 2008 | Panasonic NB-G100P 1300 Watts Toaster Oven...
Panasonic Infrared Bulb Replacement
Ordered a Heater, part #ABA83-148-0U from www.partstore.com - per the advice on this website.
May 09, 2008 | Panasonic NB-G100P 1300 Watts Toaster Oven...
Infrared bulbs Panasonic NB-G100P
Many parts are available from Panasonic's website for this model. Do a search for NB-G100P then click the displayed link. from that page, you should see a link at the bottom of the page for parts.
http://www2.panasonic.com/consumer-electronics/support/Home-Appliances/Kitchen-Appliances/Toaster-Ovens/model.NB-G100P
Stan
Nov 04, 2007 | Panasonic NB-G100P 1300 Watts Toaster Oven...
Halogen light heater
I have same problem Took whole unit apart found upper bulb is connected with wire that goes through out. You hve to physically take bulb out through side without electronic panel wire is connected on panel sid with actual plug. but ended up cutting wire other side. Bulb is not like regular bulb you will have to hard wire one side of it. bulb is unseperable from wire. Still looking for replacement bulb. I sure miss my toaster I believe it will probably be chaper for me to buy new toaster vs replace bulb. The bulb is nothing like I have seen before.
Nov 03, 2007 | Toastmaster TLWTOB6 Lightwave Toaster Oven...
Light and oven does not turn on.
:-) Same here, in the middle of cooking the toaster just died. O' well, i am a tech! i opened the unit and diagnosed the problem. the unit has a non-resettable high limit thermostat that blows open when reaching high temperature. the problem is that when it happened, the oven wasn't even hot and was only on for a bout five (5) minutes. From my experience, it is due to a design defect. from all i have seen so far, it doesn't seem that the company cares about its reputation or customers... what can you expect from the French?!
Oct 29, 2007 | DeLonghi EO1238 Toaster Oven with...
Toastmaster TLWTOB6 Lightwave Toaster Oven with Convection Cooking Logo
47 people viewed this question
Top Toastmaster Toaster Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dennis Boxerman
Are you a Toastmaster Toaster Oven Expert? Answer questions, earn points and help others
