Question about Toshiba DVR20KB DVD Recorder
Switching between vcr and DVD mode
Gets stuck in VCR mode
  • 239 Answers
SOURCE: Can't get VCR to record
You may have to push the channel buttons on the source and check the video unit until you see whats playing on the main unit once you have a picture comming thru you should be able to record. if not let me know we can figure out some other solutions to get you up and recording.
Posted on Dec 14, 2007
  • 286 Answers
SOURCE: Turning on VCR for 2nd time recording
Have you fixed your problem?
If not, just try pressing the dvd/vcr button, so the vcr becomes the primary device. Now you can press setup and go back into the vcr menu.
Posted on Feb 14, 2008
  • 12 Answers
SOURCE: DVD/VCR Combo Stuck in VCR Mode
i could probably walk this one through chat at idahoredfoxusa@yahoo.com
Posted on Jun 04, 2009
  • 31 Answers
SOURCE: dvd/vcr player
sometimes this is openend by a small rubber belt or a worm mechanism driven by a rubber belt,take off top and see if belt is slipping,
Posted on Jul 19, 2009
  • 76 Answers
SOURCE: I have the Toshiba D-VR4SU VCR/DVD. When I play
try new rca cord
Posted on Jan 01, 2010
No signal to tv when dvd or vcrs is off
Assume no signal u mean no digital tv ?and what looses time and channel?do u recieve tv broadcasts via a box or is it built in?if u can recieve channels via dvd recorder i would assume where ever it gets them from needs to be connected to tv also.u dont say if its hdmi leads.scart or coax rf type.more info please
May 23, 2016 | JVC DR-MV5S DVD Recorder/VCR
DVD/VCR stuck in Progressive scan mode
Hi jjbitt.
I found this in another post. This is what another expert say
"With NO DISK in the DVD player PRESS PLAY, (display will say "no disk" or something similar) then PRESS STOP AND HOLD FOR 5-10 SECS.."
http://www.fixya.com/support/t123076-dvd_vcr_stuck_in_progressive_scan_mode
Let me know if you still have the problem
Jan 12, 2008 | Zenith XBV442 DVD Player/VCR
Why doesn't the open/close button on DVD player of DVD/VCR combo work?
Assuming there is not a forgotten tape stuck in the VCR side, the mode selection logic has gotten all confused. On the VCR side, a tape is grabbed and loaded to be played. There probably is an EJECT button that is enabled for later use. The DVD side is disabled so no buttons work. On the DVD side, the open/close button is enabled (if no VCR-side problem is detected), allowing you to place a DVD in the tray and close it to play. The VCR side is disabled so no buttons work. That's the theory. From your description a sensor on the VCR side may have failed or been damaged, causing the player to keep reverting to VCR and preventing use of the DVD side.
Sep 21, 2015 | Emerson EWD2204 DVD Player/VCR
I have an LG RC797T. I cannot play a vcr tape because it gets stuck in the machine. Can I connect another vcr player to the LG and record to a DVD?
Yes, you can connect another VCR to the LG's video & audio input jacks and record from the external VCR. You may have to select the line input from the menu to activate these inputs.
Oct 26, 2010 | LG RC797T
DVD/VCR Combo - Zenith XBV342 Stuck In Progressive Scan
mi zenith xbv342 solo queda la pantalla azul y dice progressive scan mode como salgo de hay
Jun 14, 2009 | Zenith XBV442 DVD Player/VCR
Jun 04, 2009 | Toshiba SD-V394 DVD Player/VCR
I am stucking with system Menu on progressive mode on Sony RDR-VX530
First of all, confirm connecting cables are correct n OK.
2nd, please confirm VCR is giving output signal or not.
Jul 20, 2008 | Sony RDR-VX530 DVD Recorder/VCR
Emerson ewd2203 video/dvd combo
Do you know why the tape was stuck? How did you get it out? On most vcr's there's a mode switch connected to the mechanics of the vcr. If the mode switch isn't in stop position, the unit will try to get it there and shut off if it can't. Bad belts, bad idler wheel, dirty mode switch, mechanical timing off (maybe due to forcing a stuck tape out?)... all these can cause this.
Geno
Feb 27, 2008 | Emerson EWD2203 DVD Player/VCR
VCR stops, ejects, eats tapes
clean the heads and retime the gears.
Nov 24, 2007 | Symphonic WF802
DVD/VCR Locked
My DVD/VCR Daewoo locked and everytime i pressed a button it just said LOCK! I plugged off the vcr for a few hours and then plugged it back in and pressed the on button. Now im watching the dvd that was stuck inside. Try it, you just never know.
Nov 19, 2007 | Daewoo DVRS04 DVD Recorder/VCR
Toshiba DVR20KB DVD Recorder Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
