690 HR console not working - Office Equipment & Supplies
After jump started my ktm 690 enduro 2013 model the tachometer is not working properly
Hi, Jaco if you jumped it off a running automobile you may have fried delicate circuitry the tachometer needed for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
KTM 690 tachometer stopped working
KTM 690 EFI Idiots Guide
KTM 690 Enduro EU 2013 Repair Manual
http://www.partsfish.com/page/oem-parts-for-ktm
KTM 690 Enduro USA 2013 Owner Manual
Mar 07, 2017 | KTM 690 Enduro Motorcycles
SC 690
GAVD I2C
communica-tion
error
690-001: Y
690-002: M
690-003: C
690-004: K
Jul 15, 2014 | Ricoh Aficio 2232C Color Copier
Code to solution problem 690sc
SC 690 - GAVD IC2 communication error.
690-001 :Y
690-002:M
690-003:C
690-004:K
Possible cause:loose connection,defective BCU,defective LD controller board.
Turn the main switch OFF and ON,check the cable connection,replace the laser optics housing unit or replace the BCU board.
Feb 17, 2013 | Ricoh Aficio 2232C Color Copier
My 10yr old model#690 freezer is having trouble maintaining temp and when the compressor shuts off it makes a loud clunk noise. I have check to see that fan is running and have turned unit off for about...
The noise that you are hearing is in the compressor. The motor has rubber mounts that hold the motor inside the compressor. One of these mounts are broke and what you are hearing is the motor hitting against the inside of the compressor. Have you tried cleaning the coils? let me know.
Mar 06, 2011 | Sub-Zero 690 Side by Side Refrigerator
Want turn on getting number 1 and 3 flashing
Your Power Supply has gone bad mate... known problem. You need to swap out the old power supply with a new one or maybe a working one (if you have another system)... the procedure is fairly clearly documented on the Dell Site n no Tags needed for that... :-)
Feb 11, 2009 | Dell Precision Workstation 690 -1KW Dual...
Under counter sub zero ice machine. stoped making ice
Try this! Clean water tube, Check Ice sensor ( small wire (red tip) set to close to ice plate ) To close ,no build up sets off to soon.
Dec 11, 2008 | Sub-Zero 690 Side by Side Refrigerator
21 people viewed this question
jasbo
jasbo
