Question about Samsung CLP 300 Laser Printer
Replaced toner cartridge - print is very faint
I have replaced the toner cartridge twice and the print is very faint with the brand new cartridge. I thought the first one was defective, so I returned it, but the same thing happened the second time. What am I doing wrong?
    Scholar:
  • 72 Answers
You have to wiggle the toner cassette gently back and forth in a horizontal position like ten cycles before installing the cartridge in the printer. Otherwise the toner will not feed properly.
Also make sure to clean the scanner window and clean the corona wire at every toner change to prevent problems, check out the instruction manual on how to do this.
Posted on May 21, 2009
Printed copies have ghost images on them. I have never had this problem before., It looks like the image printed twice - once fine and then faint horizontal lines, sometimes some of the previously printed...
1) try doing a full clean from within the menu on the printer, or within the computer software
2) You need to perform a half test. Put a sheet of paper on the manual feeder and do a config page from the information menu on the printer. When the back edge of the paper enters the printer, quickly open the toner door to stop the printing. Now remove the toner cartridge and look at the image below. If the defect is present, then the toner cartridge is the problem 99% of the time. There is a slight possibility that during the conditioning stage of the print process the drum of the toner is not being fully discharged so when the next stage takes places part of the previous image gets put on the toner cartridge again. Very rare. If the defect is not present then the fuser has an issue.
May 04, 2011 | HP LaserJet 2420 Printer
16 toner low
A laser printer needs toner to print, when this runs out the printer will print either blank or very faint images.
You need to replace the toner cartridge with a new one or a re-manufactured toner cartridges. Re-manufactured toner cartridges are cheaper than new toner cartridges for your model printer.
You can get a few more prints out of your toner cartridge by removing the toner cartridge from the printer and giving it a few horizontal shakes then place it back into the printer.
Feb 03, 2011 | HP LaserJet 4 plus Printer
Samsung 4300 tonner exahust message
Feb 03, 2011 | Office Equipment & Supplies
Black printing very faint or not at all, cleaning print head makes little difference Brand new Cartridge
Sometimes it will print faint black even if there is a new black cartridge, because the color cartridge needs to be replaced as well.
Make sure that the cartridges are genuine Kodak cartridges, as well, for maximum performance and reliability.
Cleaning heads can use up a lot of ink, by the way.
Jan 13, 2011 | Kodak ESP 5 Printer
Konica-Minolta 2400W is printing very faint. All 4 toner cartridges were recently replaced, and then the drum was replaced. About 50 pages have been printed and it is still very faint. The glass has been...
That could be a problem with either the fusor wire or just need to reset the darkness setting or you didn't gently shake the cartridge (or the toner was exposed to high humidity).
The fusor wire may not be getting hot enough to get all of the toner to stick to the paper and you get the faint page. The fusor assembly is wirth about $240 so you want to make sure if it might be covered by warranty and check the replacement price for the printer. The replacement price might be close to that and you would end up with a new printer with warranty.
Oct 24, 2009 | Konica Minolta magicolor 2430 DL Laser...
Clp 300 printer is giving very light print in black.. all faint prints.. instead of changing toner powder.. and replacing it with new.. still the problem is same. .where exactly is the problem plllz let me...
It sounds like the developer blade in the black toner needs to be cleaned. It is located in the imaging unit. You can either open up the imaging unit and clean it yourself if you are handy. I have a document that describes how to do this otherwise you need to buy a new imaging unit.
Dec 18, 2008 | Samsung CLP 300 Laser Printer
Printing is faded and too light
more important than all that nonsense is:
is it faint when you do an internal report or make a copy?
if only on copies it is the film on the underside of the glass.
if on prints and copies it is the drum.
Oct 23, 2008 | Dell 1600n All-In-One Laser Printer
Brother Intellifax 2800 Faint Print
did you remember to remove the pull tab to allow the new toner to be utilized? it's either that or you just have a defective toner cartridge which if you replace will take care of the issue. If you have used canned air to blow out your machine it is possible that the toner dust has been blown into the laser housing and fogging up the mirrors that it uses but that's kinda a last resort check...
May 07, 2008 | Brother IntelliFAX 2800 Laser Fax
Brother 5140 faint print
I had the same problem and I just fixed it.
It turns out that the toner cartridge I was using was not an authentic brother cartridge. It was an Office Max knockoff.
I replaced the knockoff with an original BROTHER toner cartridge and BAM! Right back in business.
What tricked us for so long was that the knockoff worked for two weeks before it conked out, so while we were looking for the problem, we kept saying to ourselves, "No, it COULDN'T be the toner cartridge. It's practically brand new."
Hope this helps.
Dec 27, 2007 | Brother Office Equipment & Supplies
Samsung CLP 300 Laser Printer Logo
219 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
