Question about Miele Novotronic T220 Electric Dryer
Enter diagnostic mode
Dryer running but not hesting the air. Smell of burning.
Electric lift stopped 2/3 way up. There was also a burning smell. Won't work at all. Is there a manual overide?
Hello;
My name is Peter. I am a retired field service appliance technician.
There is no manual override on your dryer. Which is a good thing.
You do not want to run your dryer at this point.
The burning smell is burning lint. Your dryer is plugged up with lint. This is a dangerous situation. You could burn down your home.
Your dryer will not run because the dryer fan will shut down if the air flow is obstructed.
You have a hot air exhaust manifold where the hot air goes into a round bottom inlet up to a expanded hot air distribution headed into the dryer. This is usually plugged up.
This may also have caused the fuse to blow, a operating switch or high temperature limit switch to fail.
Go into the following website and put in your model number. You will get diagrams and component part numbers. Your model number is located on a label either on the face of the dryer when you open the door or on the side of the door.
Water Filters Lawn Garden Appliance Parts
Mar 10, 2016 | Dryers
When dryer running there is a burning smell
Clean the lint trap and make sure you have good fan operation. Check your outside vent for good air flow. Could your burning smell be electrical wiring? Does it smell like plastic burning or lint burning?
These are things one needs to know in order to locate the trouble.
Feb 03, 2016 | Whirlpool GEW9250 Electric Dryer
Smell gas when dryer running. no smell when dryer stopps.
your not getting enough air to gas mixture to burn the gas completely,you will see an orangish/yellowish flame if the air mix is too low,access the burner tube and adjust the air throttle on the tube entry end till its a clean blue flame
Jun 18, 2010 | Frigidaire FAQG7077K Gas Dryer
When drying clothes in my gas dryer, you can smell gas upon opening the door. If the dryer is not running, you do not smell a gas odor. Sometimes our clothes also have a gas smell.This just started a week...
Hi, from what you describe, it sounds like you may have incomplete combustion, which would leave a residual odor while burning. Check your vent, on the outside where the flap opens and the exhaust leaves the building. Anything blocking that vent may cause an air flow problem. If you have good air flow when the dryer is running, the problem is going to be at the gas valve/burner and may need a professional. In my town, the gas company will come out and check problems like this for no charge, they don't replace parts but are good at troubleshooting. Best of luck.
Jan 17, 2010 | Estate TGDS740JQ Gas Dryer
Wont spin cycle at full speed
Burning smell is a slipping belt. These are tricky to get apart and diagnose but find the reason the belt is slipping and replacing it will solve your problem. Could be clutch, bearing or gearcase related.
Eric
Dec 11, 2009 | Kenmore 98702 Stacked Washer/Dryer
Fisher & Paykel Dryer model ED56 constant beep
Diagnostic Mode
Entering the Diagnostic Mode
(a) Turn the power supply to the dryer on.
(b) Press and hold the Auto Dry down button, then press the Power
button.
The dryer is now in level 0 of the diagnostic mode. After initial entry into the
diagnostic mode, the Start/Pause button operates the dryer as normal. Press
the Auto Dry up or down buttons to scroll through the fault levels.
There are several levels of diagnostics, most of which are used in
development and production. These levels may bring on various LEDs, but
the level of use for the service technician is that of the last fault.
Last Fault
To enter the last fault diagnostics, enter the diagnostic mode as described
above, then press the Auto Dry up button three times. The last fault will be
displayed on the drying progress LEDs.
The manual is here
Sep 08, 2009 | Dryers
My Fisher paykel dryer does not heat
Thermostat Cutout – Manual Reset (Electrical)
Type SPST 30 Amps/240 Volts AC
Trip Temperature 212°F (100°C)
Diagnostic Mode
button.
Last Fault
Conductivity Contact Impedance Check
To enter the conductivity contact impedance check, enter the diagnostic mode
as described above, then press the Auto Dry up button five times. In this
mode, touching damp clothes or fingers across the conductivity contacts will
cause the LED display to change. If the contacts, or the harness to them,
have gone open circuit, no change will occur in the LED display. This is a
useful method of checking the integrity of the sensor circuits.
To exit the diagnostic mode, press any cycle button.
Entering the Data Download Mode
button. This enters the diagnostic mode.
(c) Press the Regular button.
Encoded data is transmitted serially out the red Auto LED, and is be captured
by an optical download pen attached to a PC where “Smart Tool” software
interprets the data to aid servicing.
To exit, press the Regular button.
Entering the Showroom Mode
(b) Press and hold the Air Dry button, then press the Power button.
The LEDs will flash in a random sequence.
To exit, turn off the power supply to the dryer at the wall.
Tell me what sort of faults codes you can come up with and I will tell you what it means but in the meantime reset the limit and clean out the lint problem, open the stopped up vent. That dryer has to breath or that safety will kick out again. I have the manual
Sep 05, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Whirlpool electric dryer runs only when holding start switch
if you've replaced the board replace the relay to right of bd the one with 2 blue wires to ck before replacing just switch relays the other one with red wires controls the heat
Oct 25, 2008 | Whirlpool LER4634J Electric Dryer
EZ3612 - spins for couple of times then stops with burning smell and mode light blinking 13 times
Per the service manual, if the mode light blinks 13 times, there's a bad dryer sensor or thermostat. I'm not sure if that related to your problem but it's a start.
Doug
Feb 24, 2008 | Equator EZ 3612 CEE Front Load...
Dryer burning smell
Have you painted or stained in your house or apartment recently? The smell gets everywhere, dryer, stove, heating unit. I recently primed with Kilz and the clothes from my dryer smelled burned. When I called for service, it was the first question the service person asked and said they made a lot of useless trips only to find nothing wrong with the appliance. That was my case. I had to rewash clothes and let the dryer run with towels for a while
Jan 22, 2008 | Dryers
Miele Novotronic T220 Electric Dryer Logo
54 people viewed this question
Top Miele Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Are you a Miele Dryer Expert? Answer questions, earn points and help others
