Question about Z-Line Televison & Video
How to put Jaguar 3 in 1 Flat Panel Television Mount together
2 Suggested Answers
tvtek
  • 1284 Answers
SOURCE: where do you put the mount bracets
There should be at least 4 unused holes on the back of the TV where the mouting hardware would be attached to. Please take a moment to rate my answer. Thanks..
Posted on Nov 24, 2009
Akai L832DDFD wall mount
I swiveled my standard mount a little, and only 3 of the 4 screws fit, but this has worked for the past several years.
Oct 03, 2013 | Akai LCT2721AD 27 in. LCD Television
Zenith flat screen stand cant mount it on back
What exactly are you trying to mount it to? if you are trying to wall mount it make sure the mounting kit lists your television as cooperating. Some universal kits only use certain configurations as there is no standard between televisions as to where the screw mounts are on the box, this may cause you to need a specific kit.
Jan 21, 2013 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Need instructions
Flat Panel TV WallMounting Instructions
Currenttrends Flat Panel LCD and Plasma HDTV's are making TV's thinner, lighter andmore powerful. Superior high definition viewing, affordable pricing with addedspace and energy savings are only just a few practical reasons for purchasing anew HDTV. With newer thinner designs, LCD and Plasma HDTV's are ideal for wallmounting. Wall mounting your television frees up space and adds a new elementof aesthetic appeal to your home theater. Positioning Before getting into any hardware mounting,find the best possible position to mount your television. Because wall mountingan HDTV is more of a permanent solution, careful planning is needed whenintegrating the television into your home design.
Furniture placement, overall themes, viewing angles, and the best audiopositioning are all factors that will help determine the placement of the LCDor Plasma TV.
Once you have decided the general positioning of the wall mount installation,cut out a piece of cardboard or wrapping paper in proportion the of theflat panel television. Next, approximate the placement by taping the piece ofcardboard or wrapping paper to the wall where the TV will be placed and mark itwith a pencil.
Preparing the TV Removethe stand from the television and lay the TV on its face. Locate the fourmounting holes on the back of the television and remove the bolts. Next, removethe mounting arms or mounting plate from the wall mount packaging.
To attach mounting arms, line up the arms vertically and parallel to each otherusing the mounting holes on the back of the television. Make sure that they arein perfect alignment and bolt the arms using the bolts and washer supplied withthe wall mount.
If you are using a mounting plate, simply line up the holes with the mountingholes on the television. Secure the mounting plate with the bolts and washersincluded with your wall mount.
Preparing the Wall Locatethe studs closest to the desired position using a stud finder and mark themwith a pencil. Remove the wall mount from the package. Line up the wall mountup to the studs within the center of the marked position you determinedearlier. If it is not perfectly centered, wall mounts can be adjustedhorizontally at a later time.
Using a level, line up the wall mount and mark the positioning of where hebolts will go. Drill holes into the stud about 1" deep, drill bit depends on the of bolts supplied with the wall mount. Bolt the wall mountto the wall with bolts and washers, but don't tighten down the boltscompletely. Adjust the position of the wall mount left or right to center it toyour desired position. When you are done, tighten the bolts the rest of theway. Mounting the Television Attachingthe television to the wall mount takes two people. Simply lift the televisionand hook it to the wall mount. At this point you can further adjust thepositioning horizontally to center it perfectly. Once the desired position isacquired, tighten down the screws that attach the mounting arms or plate to thewall mount.
mike_alozie.jpgWallMounted LCD
Apr 21, 2011 | Televison & Video
How does the tv mount?
1- remove the wall plate from the arm.
2- fix the front plate to the back of your television.
3- mark the position of the holes and drill
4- put wall plugs into holes.
5- secure the wall plate to the wall
6-attach the arm to the wall plate.
7-hang the screen on the arm (i recommend having someone help) and secure it in place
Mar 05, 2011 | OmniMount "OmniMount 23" to 42" 4in1 Flat...
I want to take take the stand off so that I may mount it on a wall....how do you do this? Is there a preferred wall mount also?
The best thing to do - is to read owner's manual first.
Normally there is 4 or more screws on the bottom middle part of rear cover that are holding stand and TV together.
Wall mount choice depend on your budget. It have to be rated for weight of your TV set. There should be 4 bigger size bolts on the back of your TV especially for wall mounting purpose. Again - owner's manual have more detailed explanations of all of the above.
Regards.
Russ.
Apr 04, 2010 | Gateway GTW-P42M303 42 in. Plasma...
Can I wall mount my LCT2721AD ?
absolutely, you will probably want a flat, low profile mount. if you go to Amazon.com they have the mount for your tv on sale for $39.99 right now. Hope this helps you out. Thank you.
Mar 31, 2010 | Akai LCT2721AD 27 in. LCD Television
Tv didnt come with screws....
The size is #8-40 X 3/4". This is a specialty screw, so you're screwed
Apr 10, 2009 | Insignia IS-LCDTV32 32 in. Television
Just bought a insignia ns ltdvd26-09 will it mount to wall
I took 8 screws out from back of set just above stand, the bracket fell off.
Be sure to put the screws back in
Feb 08, 2009 | Insignia LCDTV26 26 in. Television
Wall mount Akai LCT 3285TA flat panel TV
You have to get correct wall mount for this model tv.
Sep 28, 2008 | Akai LCT3285TA 32 in. LCD Television
Televison & Video Logo
18 people viewed this question
Top Z-Line Televison & Video Experts
Are you a Z-Line Televison and Video Expert? Answer questions, earn points and help others
