No remote for lxi tv wanting to switch to video mode
Benimur
  • 6966 Answers
SOURCE: SWITCHING FROM TV MODE TO VIDEO MODE
Hi, If the AV button is not in your remote, then perhaps it is part of the Ch up/down buttons - meaning right after your last programmed Channel would be AV before the first program Channel. Although I have yet to come across such a case, I have worked on units/remotes that have this feature of the AV included in the channel memory. Good luck and kind regards.
Posted on Aug 20, 2007
Benimur
  • 6966 Answers
SOURCE: RE; Remote control TV/AV button doesn't work LXI series
Hi, Based on your post/description: 1. the TV is stuck to A/V; 2. you have two video sources - VHS & DVD (assuming both are external and both have A/V outputs with the VCR also with inputs); 3. you want to use either VHS & DVD, one at a time. You can do it the old fashion way, remove yellow, red, white RCA connectors from DVD and plug them at the outputs of the VHS when you want to use the VCR; or Connect the A/V outputs of the DVD to the inputs of the VCR, connect the outputs of the VCR to the A/V inputs of the LXI TV. Hopes this give you an idea. Post back how things are or should you need further information. Good luck and kind regards.
Posted on Aug 24, 2007
aprmaejun
  • 97 Answers
SOURCE: RCA RCR311W Universal Remote Code for LXI TV
From what I can tell, it could be any of these codes:
1000
1006
1048
1049
1062
1072
1073
1100
1109
1130
1162
1181
1203
1212
1233
I used this website:
http://tv.rca.com/RCATV/NewTV/Templates/GenericSupport.aspx?NRMODE=Published&NRORIGINALURL=%2fen-us%2ftechnicalsupport%2ehtml&NRNODEGUID=%7bCDBA69CE-8CEA-435A-8F62-C5E6DBE1ACF6%7d&NRCACHEHINT=NoModifyGuest#
Posted on Jun 12, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: old Sylvania model #6420FB lost remote how to switch to av mode
Unless the TV has a front-panel menu button and allows you to switch modes from there, you are out of luck. There are two possibilities. One is to try another replacement remote. If you get a universal remote made by the TV manufacturer (Magnavox), it may have buttons that will work. The other option is to purchase an RF converter, which will cost around $15. This will take the video/audio signals from the game and convert it to a channel 3 or 4 signal you can then tune in on the TV. The picture won't be quite as bright and clear as with direct AV input, but it will do the trick.
Posted on Jan 12, 2009
  • 5 Answers
SOURCE: video mode
my TV remote broked and i want to know how can i change Emerson EWF2004to video without the remote so i can watch movies
Posted on Feb 07, 2009
MY REMOTE WON'T PROGRAM TO LXI TV
1) tigh the springs contacts batteries with pliers for better contacts
2) open the remote control and clean the keypads from oxide, dust, etc, with alcohol, or contacts spry
Otherwise you must go to the repair shop TV for fix it.
God bless you
Jun 21, 2012 | Televison & Video
How do you switch to video mode with no remote
hi,
you cant.
your going to have to get a mid priced universal with extended features. read the packaging. thrift stores sometimes have a bag wall with old remotes so if you have someone who goes to the thrift store sometimes tell them to start looking for either a vcr or tv remote that says emerson on it for you. directv and dish network universals have video input buttons, if you have eith of those providers go to their website, download or find the chapter where it shows how to set up your viseo input. it is shut off by default..
jm
Apr 14, 2011 | Emerson EWF2004 20" TV
Don't have a remote control for this lxi projection television purchased at garage sale, not getting channels, can only view movies
hi, doesn`t have tv/video button on front of set ? LXI is a sears trademark, bring complete model number to any sears repair center and they can get you a remote for it, gl, video-tek
Jun 04, 2009 | Televison & Video
Need the remote code for a phillips dvd player
These are the codes printed in the owners manual for your dvd/vcr player.If they do not work you will have to contact Emerson and ask them for help getting the code. The contact number should have come with the instructions for the remote. Just give them the model number of you remote and the units model number and they should be able to help you. I hope this information helps you with your problem. Switch the input selector on your TV to an appropriate external input channel (usually near channel 0).
Press a button on the TV’s original remote control that selects an external input channel until the DVD
recorder’s picture appears. Check your TV owner’s manual for details.
Admiral
Curtis Mathis
GE
Hitachi
JVC
Kenwood
LXI-Series
Magnavox
AUX
LINE1, LINE2, 00, 90, 91, 92, 93
INPUT, TV/VCR, 00, 90, 91, 92, 93
INPUT, AUX
VIDEO, VIDEO 1, VIDEO 2, VIDEO 3
AUX
00
AUX CHANNEL
Input Mode Names for Common TV Brands (Example)
Panasonic
RCA
Samsung
Sanyo
Sharp
Sony
Toshiba
Zenith
TV/VIDEO
TV/VIDEO
VIDEO
00
VIDEO1, VIDEO2, VIDEO3
TV/GAME
00
Apr 25, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Rc24
1. Turn on the TV or component. Insert a tape or disk if
applicable.
2. Slide the MODE switch to the TV, AV1 or AV2 position,
as desired.
3. Press and hold the MUTE and SELECT keys at the same
time until the green light under the selected switch
position flashes twice, then release both keys.
4. Enter 9-9-1 followed by one of the following fourdigits
5. Press PWR, or other functions (e.g. PLAY for VCR) you
want to use.
6. Point the remote at the TV or component and press
CHAN+. Repeatedly press CHAN+ until the TV or
component turns off.
NOTE: Every time CHAN+ is pressed the remote
advances to the next code and power is transmitted
to the component.
7. Use the CHAN- key to step back a code.
8. When the TV or component turns off, stop pressing
the CHAN+ key. Then, press and release the SELECT
Nov 08, 2008 | Directv RC24 Remote Control
No remote on LXI series TV
I PURCHASE FROM A TV FROM A SALE AND I CAN'T HOOK UP THE DVD PLAYER AND I DON'T HAVE A REMOTE. THE OPT ARE CABLE AND AIR AND NOTHING WORKS WHEN I SWITCH IT OVER LIKE MY OTHER TV HELP.
Jul 31, 2008 | Rio Go Video DDV9475 Dual Deck VCR
Remote
moz-screenshot-3.jpghere are the codes for for LXI for a document from Zenith.
117,502,506,512,601,719,807
Hope thats helps
Jan 01, 2008 | Zenith ZEN450 Remote Control
Video mode
Oct 29, 2007 | Emerson EWF2004 20" TV
Lxi television
I am looking for how to change my tv into video mode without the remote and found an answer for your problems....
http://www.howtomendit.com/answers.php?id=4239
Aug 30, 2007 | Televison & Video
Aug 23, 2007 | Rio Go Video DDV9475 Dual Deck VCR
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
Electro Med Services...
