Question about GE Stainless Steel Built In Trash Compactor GCG1580RSS
My GE trash compactor just hums when foot pedal is activated
5 Suggested Answers
SOURCE: GE Profile trash compactor is stuck
This has happened a couple times to me and the fix is fairly simple. The problem is the trash ram is pushing down on the edge of the metal of the trash compartment because the door is partially open. The solution is to back-up the ram the the door will close.
To back-up the ram, you will need to pull the compactor out from under your cabinets and unplug it. Turn the compactor on it's side to expose the bottom. There is a plate on the bottom that covers the motor gears. Remove the plate and turn the large gear counter-clockwise to back-up the ram screws (at least this is how it works on my model works). The gears are a little greasy so you may need to add some after messing with the gears.
Good luck.
Posted on Dec 25, 2008
SOURCE: Trash Compactor Model GCG1500LOBB. the foot
I also found that after 2 years my GE Profile Trash Compactor (purchased in June '07), the pedal was hanging down on the left side. I searched the internet and called GE to no avail.
After a few attempts, I finally solved the problem by removing the screw on the left side and adding a metal "L" bracket, with the bottom of the L flush against the back of the front panel. That way, when you depress the pedal, the screw can't pop out of the metal it's attached to.
Dannys00
Posted on Dec 25, 2009
burdfrenzy
  • 348 Answers
SOURCE: I have a GE trash compactor I have to hold up the
There is a spring that holds up the pedal. It is broken or has come apart. By the pedal in the up position it is a safety switch allowing the compactor to run. You may have to repair this or simply put a small block under the pedal of the unit to run.
I hope my suggestions helps and all the luck to you.
burdfrenzy
http://stores.ebay.com/Pittsburgh-Joes-Pants-Nat
Posted on Dec 23, 2010
Daniel S
  • 4323 Answers
SOURCE: GCG1580LSS trash compactor when I
Hi
The hum sound means that the motor is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Feb 07, 2011
Ge compactor stops after just starting
the running cycle for this type of trash compactor is a max of about 30secs. The fuller the bag is the shorter the cycle. However, if this is not how yours is running try checking to see if there is any trash stuck between the ram and the basket. Or make sure that the foot peddle is still staying in the "up" position.
Feb 27, 2012 | GE Stainless Steel Built In Trash...
I have a GE trash compactor I have to hold up the foot pedal for it to work. When I let it go the compactor stops. thank you
burdfrenzy
Dec 23, 2010 | GE Profile GCG1580LSS 15" Built-In Trash...
GCG1700 willnot compact.When activated it just
There is a motor jam. The mechanism needs to be cleared, perhaps a bone or any other hard material is jamming the mechanism. Do a visual inspection and look for foreign objects (Perhaps a fork?) or something unusual.
Jan 06, 2010 | GE Profile GCG1580LSS 15" Built-In Trash...
Dannys00
Dec 21, 2009 | GE Profile GCG1580LSS 15" Built-In Trash...
Our compactor does not work. It makes a humming noise but will not function.
motor jamed . try removing basket . ( pull out and lift up ) ck for plastic of other things in or around drive and rollers .both sides and in back .. ****
Dec 07, 2009 | GE Profile GCG1580LSS 15" Built-In Trash...
GE trash compactor foot pedal loose
Take a chance and type: "SearsPartsDirect" into the search engine of your computer and when you get that web site, type in your model number off the machine.
If this works, you should get a schematic showing you the parts and part numbers, and maybe even the opportuninty to order the apart you need.
God bless your efforts.
Nov 20, 2017 | GE Profile GCG1700LII 15" Built-In Trash...
Door hard to open
The tracks that the door are on have to be cleaned and lubricated with WD40 or equivalent. This should solve your problem. Hope this helps
Nov 09, 2008 | GE Profile GCG1580LSS 15" Built-In Trash...
Good luck.
Oct 21, 2008 | GE Profile GCG1580LSS 15" Built-In Trash...
HIT FOOT SWITCH AND MOTOR RUNS AND CUTS OFF WITHOUT COMPLETE CYCLE
trouble in ur wire going to the swtich contact ge about this problem looking forward to helping u Shaun
Aug 18, 2008 | GE Profile GCG1580LSS 15" Built-In Trash...
GE Stainless Steel Built In Trash Compactor GCG1580RSS Logo
87 people viewed this question
Top GE Kitchen Appliances - Others Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Sal De
Are you a GE Kitchen Appliances - Other Expert? Answer questions, earn points and help others
