Question about Jenn-Air Kitchen Ranges
SU130 cleaning oven vent
The air vent on oven is all yellow-cannot clean(plastic)
That is common on GE...usually after about 10 years. How old is yours?
May 20, 2010 | GE Spectra JBP78 Electric Kitchen Range
I cleaned over with self clean and it blows the thermostate. Is this normal on Kitchen aid wall mount ovens?
if u have unproper vent specs on unit it will blow. read instellation spect for proper vent specs
Feb 12, 2010 | KitchenAid Architect Series KEBC177KSS...
Do I need to vent to the outside?
Hello, No you don't need to vent outdoors, and YES all you need is a electrical supply. **I will add however, allow for an air cushion around the unit when it's installed in the wall as well as a vent or small gap with maybe a custom grill at the top. One of the most common service calls I get for self clean built in ovens is reseting or replacing safety thermostat's. Hope that helps Good Luck :)
Nov 01, 2009 | Ovens
Oven is installed not outside vented. There is
It could be that the filter elements are clogged and need to be cleaned. Remove then from the underside of the micro hood and clean them using a good quality cleaner, such as Simple Green. Clean and allow to air dry before reinstalling.
While the filter elements are out, you can check for obstructions and run the fan to see if it is better without the filters installed.
If there is no noticeable increase in the air flow, it is possible that the exhaust vent baffle was not installed correctly, when the mircrowave was first installed.
Hope you found this Very Helpful and best regards!
Aug 18, 2009 | GE Advantium 120 Convection/Microwave Oven
Frigidaire double oven - stove top oven had a spill. The spill went through the bottom oven's door vents and is now in between the glass and I cannot get to it to clean. How can I get this glass clean?
I had a similar problem with a spill running into the vent and between the glass. I had to take the door apart clean it and then put it back together. It sounds hard, but it was just a few screws and a little time.
Jun 27, 2009 | Kitchen Ranges
Cleaning between double glass oven door
Without disassembling the door, you can't. the glass is sandwiched between two rather rugged metalized gaskets to create an air pocket (or vent space) to keep the outside glass cooler than the inside.
Feb 04, 2009 | Ovens
Cleaning vent
two screws on top will release the vent to remove.
Sep 08, 2008 | GE Advantium 120 Convection/Microwave Oven
Cleaning the vent
One trick is to put a Pyrex bowl of water and let that boil for a few minutes or so. This gives the water vapors a chance to collect and exhaust dirt and dust from the vent passage way.
Worldvet
May 25, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Cleaning the air vents
clean the air vents??? building up with dust lint and such??? the vaccuum os good try using a baby bottle brush or an old toothbrush to get al trough the grooves
Mar 18, 2008 | Dacor Epicure 30" Double Wall Oven,...
Kitchen Ranges Logo
14 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
