Question about TalkSwitch TS-480i
Talkswitch 450i extension status unregistered
We have a Talkswitch system at our office. My Talkswitch 480i now seems to has lost its brains. When I power it down now, it does not seem to talk to the switch to obtain its configuration. It always...
The problem would seem like the phone is not finding the TalkSwitch system, or the configuration file for the phone does not exist. There are usually only 3 things that can cause this issue to occur:
1. Verify that the IP address for the TFTP Server, this must be your current public IP address. This can be found in the phone's menu under Networking -> TFTP Server -> Primary TFTP Server
2. Ensure that port 69 is open in the firewall at the TalkSwitch's side. Run the TS firewall test to confirm that it passes.
3. Confirm that you have the correct MAC address entered in for the Extension in the TalkSwitch software
Jan 05, 2011 | TalkSwitch TS-480i
How do I access my voice mail remotely? (talkswitch ts200)
Call into the system and when the attendant picks up dial **+(mailbox number or extension number)
Aug 03, 2009 | TalkSwitch TS-200 Phone
Caller ID dOESN'T wORK
Log into your TalkSwitch Management Software.
Go to Telephone Lines.
Under each incoming line make sure that Caller ID is checked.
Click File> Save
Hopefully this will fix it for you.
Jul 06, 2009 | TalkSwitch CT.TS001.124001.US...
External caller ID does not display on either line talkswitch 284
Click File> Save
Jun 18, 2009 | TalkSwitch CT.TS001.124001.US...
Talkswitch 480 VS no longer shows caller ID Simply "out of area".Can this be repaired?
Call Talkswitch, they will offer a swap for another system and bill you $500 to do so. This happened to me twice. First swap was $250. A year later it is now $500. I was told this increase was due the end of the system life and a shortage on parts. My system is just about 4 years old. My next system will have telephone line surge supperssors inline with the telephone lines.
May 29, 2009 | TalkSwitch 480vs Phone
Talkswitch caller ID from outside calls not working
Click File> Save
May 06, 2009 | TalkSwitch CT.TS001.124001.US...
TalkSwitch 48 disconnects call after transfer
You are using the wrong option for transfer -- the one you are using is a conference which requires the person transferring the call to stay on the line. You need the option which permits a blind transfer or announced transfer. This issue is specifically discussed in the manual.
Feb 09, 2009 | TalkSwitch CT.TS001.124001.US...
Answering machine not working
Open your TalkSwitch Management Software.
Go to Local Extensions/Fax
Select the extension you are using for the fax.
Click on additional settings under the activate extensions section
On the direct Line Access Tab put a check mark in the check box for "Use Direct Line Access on:" Select your Hunt Group or the number you have to dial to get an outside line.
This will force this extension to not have to dial 9 or whatever number to get an outside line for dialing out.
Jan 25, 2009 | TalkSwitch CT.TS001.124001.US...
Somethings wrong!
Sorry to have to ask all these questions, but they are necessary to try to help figure out what is going on. I need to know what TalkSwitch system model you are using and what version of software it is running. A system serial number is required if I need to contact my distributor. If you could provide the current configuration file on the system, that may help as well.
I am an authorized TalkSwitch Partner and will try to assist you.
Sep 28, 2007 | TalkSwitch TS-400 Phone
TalkSwitch TS-480i Logo
124 people viewed this question
Top TalkSwitch Computers & Internet Experts
David Payne
David Payne
Are you a TalkSwitch Computer and Internet Expert? Answer questions, earn points and help others
