Question about Camping, Backpacking & Hiking
Victor sport light 139by
Need battery
My TVS Victor GLX 125 is missing at slow speeds also the VTI indication light is blinking. Why?
Hi, Arun and the usual suspects are:
1. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
2. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Spark plugs in bad condition or partially fouled.
4. Spark plug cables in bad condition and leaking check for spark leakage in the dark.
5. Spark plug gap too close or too wide.
6. Faulty ignition coil, module, and or sensor.
7. Loose, dirty, or corroded ignition module connector at crankcase.
8. Faulty CKP sensor.
9. Intake air leak.
10. Water, dirt, or rust in the fuel system, carburetor and/or filter.
11. Fuel tank vent system plugged or carburetor vent line closed off.
12. Vacuum line from intake manifold to fuel valve is broken, cracked, pinched, or missing.
13. Carburetor controls misadjusted.
14. Damaged carburetor.
15. Incorrect valve timing.
16. Weak or broken valve springs.
17. Damaged intake or exhaust valve.
18. Check for engine trouble codes
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
TVS Victo GLX 125 Long Term Ownership Team BHP
TVS Victor GLX 125 2007
http://www.tvsmotor.com/pdf/Manuals-Scooty-Zest-110.pdf
Shop at TVS Victor glx Parts And Accessories Online Store safexbikes com
http://fullmanuals24.com/brand/tvs
Sep 18, 2016 | Motorcycles
Charge light comes on what does it mean
Hello Victor, A charge light means the alternator is not charging the battery. It could be caused by a loose or broken alternator belt. Or a bad alternator or voltage regulator. I would get it looked at before it leaves you stranded with a dead battery.
Mar 23, 2015 | 1985 Dodge 600
Need smith and wesson manuals for how to resemble a 32 S.&W.CTGE VICTOR
Amazing how one missing letter in your subject title changes the entire meaning of your problem. How to "resemble" (to be like, or similar to) a 32 caliber handgun.
May 15, 2014 | Smith & Wesson Sport & Outdoor - Others
Victor v30ra lcd not working
is this the right battery please check
Operates on one LR44 battery
2 007results for LR44 battery
Apr 23, 2014 | Victor V30RA Scientific Recycled...
Start power cut
try the idle control valve it could be starting to fail.
Jan 20, 2014 | Saab Cars & Trucks
Battery lights
Victor,
How old are those batteries? If you wait, do the LEDs slowly increase in charge time? If the batteries are depleted they will need time to charge... if the batteries are too old, over 3 years, you may need to consider replacing them. Reply or call for pricing.
If you need UPS, Surge, or Power Related help contact Daniel @ Power & Systems Innovations 800.260.2259 or go to our website: www.psihq.com
Sep 10, 2013 | APC SURT8000XLI UPS System
Limited performance
This means a fault has occurred and you will need the dealer to scan the computer for the fault codes.
Jun 01, 2012 | Cars & Trucks
Assembly of lights Smith Victor KT1500u Lighting kit. Help!
How do you assembly the light on the light stand? I have a Smith-Victor Hair light
Jan 28, 2010 | Smith Victor KT1500U Thrifty Iintermediate...
Victor 4 stiff trigger
If it is a coil spring system just remove a couple of coils--carefully.
Sep 05, 2009 | Sport & Outdoor - Others
Camping, Backpacking & Hiking Logo
29 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
