Question about Kenmore Washing Machines
Kenmore 796.41028900 water comes out front
Water pours out the front while running
3 Suggested Answers
  • 12 Answers
SOURCE: i have the kenmore HE2 front loader. when you turn
there is a water inlet on the right side of the detergent filling cup to flush out the dry detergent. take out the fill and it is midway back on the right(little rubber hose) once you locate that take the top panel off and follow the hose, should lead to a silinoid. this is most likely sticking open, or the line is broken and dumping water into the washer cavity instead of in the detergent cup. hope that gets you started in the right direction.
Posted on Jan 28, 2010
  • 389 Answers
SOURCE: kenmore 417.90802990 will not drain
your filter or the pump is blocked clean out should work ok
Posted on Sep 27, 2012
2000 Pontiac sunfire leaks water and overheats. Water pours directly out near the reservoir as soon as I pour it in.
you have to figure out where the leak is first and u cam add water while running just dont do it when car is hot
Feb 20, 2013 | 1999 Pontiac Sunfire
Ice maker not working on Kenmore Model # 106.54563300 Water comes through water dispenser fine Water came pouring out through ice dispenser door so I flipped bar up to turn it off Removed front box held in...
First the arm has to be in the down position. It sounds like you said theres water in the ice maker. If thats the case then it should have frozed. The ice cannot drop unless the ice maker heater comes on. Then the ice maker scoops the ice and drops into the resoviour thingy. If you have ice in the ice maker tray but no ice in the bucket then the ice maker is defective.
Mar 25, 2010 | Kenmore Freezers
My kenmore is leaking water once a day .
You didn't say from where. Usually twice a day your de-ice heating coils come on and melt any ice that has accumulated. this water usually runs down the back of the ref. and collects in a small pan under the ref. Someime ice form around the hole that the water drains down through to go into the small pan. so then when the deicer comes on the water just runs down the bottom of the ref and onto the floor. My Kenmore does the same thing. Remove everything from the bottom of the Freezer look in the back at the bottom see if hole is clogged with ice. Remove ice then pour hot water down hole check occasionally.
Aug 07, 2009 | Kenmore 57029 Side by Side Refrigerator
Leaking water
Your pump is leaking. it is attached to the front of the motor. Very common. Pump retails around $60.
Part number is 3363394
May 19, 2009 | Kenmore Washing Machines
Water pouring out of detergent dispenser drawer
There is a rubber hose that connects dispenser housing to outer tub of washer. Disconnect hose at outer tub and fish out article of clothing that has wedged itself in there cuasing water to back up and pour out of dispenser. In the future use a linen bag for small articles of clothing such as underwear and socks.
Dec 31, 2008 | Kenmore 46462 Front Load Washer
Kenmore elite washer model 20952992 pouring water
We had the same problem. The bleach dispenser tray is located on the drum below the bleach storage pan. The dispenser tray has very small holes that were plugged by rust from the hose clamp that attached the dilution water supply hose to the bleach storage pan. I removed the top of the washing machine to discover the problem, but it may be solved by attaching a flexible tube or small hose to the end of a vacuum cleaner hose and cleaning out the dispenser tray. There is room between the dispenser tray and the storage pan and is located in the front right corner.
Dec 10, 2008 | Kenmore Elite HE4 Electric Dryer
Water Remaining in Gasket Around Door
normal problem all front loads all brands.. leave door open as much as possible.. to clean fill tub with hot water pour in 2 cups chlorine bleach use rag in solution wipe gasket out as good as possible allow washer to run normal cycle ..do as routine when ever odor is first noticed leaving door open will allow most of water to evaporate
Nov 19, 2008 | Kenmore Elite 45986 Front Load Washer
We have a slow water flow the water wont come out fast its just drinpping out
could be a clogged filter to the water pump.
check the filter. it is in the water pump inlet assembly.
unscrew the cover and pull the filter. it could be clogged with dirt and small particles.
tnx 4 using fixya,
drcool
Oct 19, 2008 | Kenmore Elite 45986 Front Load Washer
No water inside
your bottom spray arm has holes where the water shoots through , make sure they are not clogged.Check upper spray arm also, remove any matter that is blocking the openings and run rinse aid through your D/W at all times. Hint : Glass Magic is a D/W product out in Markets ,if you can run that through the D/W your going to save alot of headaches . Please rate this !
Jun 20, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Washing Machines Logo
22 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
