Question about LG LDE3017ST
Touchpad from center to oven controls wont work
The screen shows F-3 KEY ERROR
What does eroor E6 Mean
The E6-F2 error code indicates a problem with the touchpad or the electronic oven control. E6-F2 specifically means the cancel key drive line is open. You can't cancel this error code, but sometimes removing the power from the oven and reconnecting it will cure it.This is usually a fault in the touchpad, but can also be caused by the electronic oven control. To test the oven you would need to remove the control panel and disconnect the ribbon connector from the touchpad to the oven control at the oven control. Clean the end of the ribbon and reconnect it. This will sometimes correct the problem by curing a weak connection. If the error code comes back you should replace the control panel which contains the touchpad. 8300427- black
8300428- white
8300516- biscuit
The part number for the electronic oven control is 8302319.
Apr 29, 2014 | Heating & Cooling
Je1540wv002
follow this steps and fix it use the VOM 4f0e2859-427b-40e9-9e89-e7e7bb5bc8da.gif. God bless you
1. Door is not closed (some models).
2. You waited to long (open and close door to wake it up).
3. Controller is confused (pull plug for a minute or two to reset).
4. Defective interlock switches.
5. Faulty controller or its power supply.
6. Touchpad or controller board contaminated by overenthusiastic cleaning.
7. Defective/damaged touchpad.
Jun 11, 2013 | GE JE1460 Microwave Oven
GE JVM1440SH001 f3 error
see the commentaries and repair:
F3--Shorted key panel(touch pad), will occur if a shorted key panel is detected continuously over 60 seconds.
test the following:
Jul 31, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
Oven is beeping and showing f1
Hello Charlie,
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced
GENE
Nov 06, 2011 | Neff B1421 Electric Single Oven
Touchpad does not work
This is a common touchpad error which we regularly repair for customers nationwide for $39.95 one year guarantee.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Apr 28, 2010 | Whirlpool GH6177XPS Microwave Oven
How can i be sure that the f7 error in my ge built in over requires a key pad replacement.
Hello, I assume since you are asking about the touchpad you had an error code or the appliance just stopped working. The way to be sure the touchpad is at fault is to switch the power off and then remove the ribbon/wire harness from the touchpad to the EOC (Electronic oven control). turn the power back on. Leave for 24 hours if the error comes back it's going to be the EOC if the error does not come back then you have a bad touchpad. Hope this helps, If you have any other questions or concerns please feel free to comment again and thanks for using fixya! Good Luck. Mike
Jul 20, 2009 | Sharp R90GC Electric Single Oven
Error code F7
your problem is with the EOC (Electronic oven control) or touch pad if it is seperate from the control...if the touch pad is seperate...unplug range - access the control panel - remove the wiring/tape wire from touchpad to EOC...plug range back in...leave over night...if f7 code comes back it's the EOC...if the error code clears it's the touchpad...replace the part with the problem...if touchpad built into EOC replace the EOC. Hope this helps...if you have any other questions please feel free to comment again.
Jul 06, 2009 | GE Ovens
Error code E2 F2
As you are aware the technical manual for your range doesn't show an error code of E2 F2 but all of the F2 codes pertain to the touchpad of the range.
Can you clear the E2 F3 by pressing the cancel button? If not, shut off the power to the range for a few minutes and see if the error code goes away. If the error code remains You should unplug the range from the wall and remove the back panel for the control area. Disconnect the ribbon between the touchpad and the electronic control, clean the end of it and reconnect it.
If this doesn't repair the problem you will need to replace the touchpad on the range. The parts diagram lists two touchpads, they are part numbers 8273575- bisque, and 8272702- white.
E2 relates to an overheating condition. Quite possibly related to your touchpad issue. I'd try cleaning the contacts and if that doesn't work...Up to you at that point!
Good luck
Jun 01, 2009 | Kenmore 71414 / 71419 / 71410 / 71412 Gas...
Touch pad on/off utility
Disabling or enabling the TouchPad The TouchPad is enabled by default. To change the enable/ disable the TouchPad setting: 1 Click Start, Control Panel. The Control Panel window appears. 2 Click Printers and Other Hardware. 3 Click Mouse Properties. The Mouse Properties window appears . 4 Click the TouchPAD ON/OFF tab. The TouchPad ON/OFF tab appears. 5 Select Disable or Enable, whichever is appropriate. 6 Click Apply.
7 Click OK. The Mouse Properties window closes. 8 Close the Printers and Other Hardware window . 9 Close the Control Panel window.
Nov 11, 2007 | Toshiba Qosmio G25-AV513 Notebook
LG LDE3017ST Logo
13 people viewed this question
Top LG Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Steven Clarke
Steven Clarke
Are you a LG Kitchen Range Expert? Answer questions, earn points and help others
