Question about Sony Grand WEGA KDP-65WS550 65" Rear Projection HDTV
Wont turn on
Need help on removing the D Board to replace IC8002 and IC8005
2 Suggested Answers
Slinteriors
  • 8617 Answers
SOURCE: Part Numbers for Q8013, Q8014, R8051, IC8005
Q8013 & Q8014 are both 2SK3568 sony Part# 6-550-882-01R8051 is 0.1 1/2 watt fusible resistor sony Part # 1-216-837-11 and IC8005 is a TL1431CZ-AP sony Part # 8-759-586-17 you should be able to get those parts through www.tvrepairworld.com
Posted on Dec 12, 2012
I turn on the tv , sound but no picture and after a few seconds it turns off and flashlight blinks on front panel 10 times and after a pause repeats blinking
Had the exact same problem on a KDP-65WS550.
I replaced IC8002 (MCZ3001DA) and IC8005 (TL1431CZ) on the "D" board and this resolved the problem. Total cost including parts and shipping was around $35.00.
Jan 12, 2011 | Sony Grand WEGA KDP-57WS550 57" Rear...
No picture ,standby flash 10 times and tv turns off
10 times standby flashing indicates problem of High Voltage Protection and need to check following parts in Sony KP-51WS520 rear projection tv.
Q8014 or Q8013 have shorted replace along with R8051 on D Board
IC8005 is damaged (D Board)
Hope these info will help you. If you have no experience of electronics stuff repair then local tv repairman is an option to get help.
Thanks.
Nov 27, 2010 | Sony KP-51WS520 51" Rear Projection...
My tv turn red and blink 13 time
Hi ,
I had same problem my TV. Replaced IC8002 on the 'D' board.
This is what we did:
1.Bought 2 x MCZ3001D from WES components in Ashfield Sydney Australia for $11.20 (each).
2.Friend had an 18 pin machine spun socket (not the crappy ones on EBAY).
3.Took back off TV
4.Put the 'D' board in service position
5.Noted which way IC8002 chip sat (Where position 1 is), also noted which 2 legs are not soldered.
6.Cut the black plastic that was covering this chip underneath (where D board screws into) as this is easier than removing the 'D' board.
7.De-soldered the IC8002 chip with a proper de-soldering iron. These are expensive though.
8.Soldered in the 18 pin socket.
9. Set the chip into the socket.
10.Tested TV, worked fine.
11. Put it all back together, plugged in Tivo, DVD etc etc etc and all bloody good stuff.
12. I now also have a spare MCZ3001D which is taped to the back of the TV for future replacement, which is now easier since its now in a socket.
Aug 12, 2009 | Sony KDL-40XBR4 40 in. LCD HDTV
Sony kdp65ws550 wont turn on
hi
it is the problem of cathode ray tube,,or jungle ic in D-board,,replace it..
your problem will be solved thank u..//please rate it
Jul 04, 2009 | Sony Grand WEGA KDP-65WS550 65" Rear...
Kv-34hs420 Standby light blinks 6 times. Power supply issues?
Replace IC6501 and IC8002 at same time, both have same number and located parallel on DZ board. Part number is as follows..
670581001 MCZ3001DB
Available in Part Store.
Jun 26, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
SONY KP-FX432m91 PROJECTION TV 10 BLINKS OF STBY LT
tyoe in google bar understanding sony blinking codes.
Feb 14, 2009 | Sony KP-57WS500 57" Rear Projection...
WILL NOT STAY TURN ON
Its bit complicated problem. Service manual states HV Protection as 10 times blinks.
You need to replace D Board or if you know basic electronics and familiar with TV repair, then check followings..
• Q8014 or Q8013 have shorted replace
• IC8005 is damaged (D Board
Hope this info will help you out.
Jan 28, 2009 | Sony Grand WEGA KDP-57WS655 57" Rear...
Convergence issues
The full downloadable service manual located Here! will have a list of all parts.
Below are a few remedies for convergence:
Subject
Poor convergence, IC8002
Symptoms / Customer Description
Customer hear a popping noise.
[Primary Symptom Code: 1436 ]
Solution
Found IC8002, IC8003, and fuse PS8006 defective on the D Board.
If you need repair assistance, go HERE!
Nov 05, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Sony blinks 6 times wont turn on...is it worth fixing
replace on the D board
IC6501
IC8002
C6510
C8027
C6532
C8037
Hope this fixes you, if not then alot of other might get theirs fixed. please leave your feedback!
this fix cam from sony tech just 5 minutes ago.
FIxes problems with tv not turning on when cold, very hard to turn on. or people that have to unplug and plug in again to get it to come on. I usually dont give info like this for free as I'm a head tech.
good luck
Jun 26, 2008 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Model kdp65ws550
High voltage protection. Either transistor Q8014 04 Q 8013 is shorted along with R8051 on the D board or IC 8005 is defective on the D board. Let me know if you need more assistance
Apr 22, 2008 | Sony Grand WEGA KDP-65WS550 65" Rear...
Sony Grand WEGA KDP-65WS550 65" Rear Projection HDTV Logo
11 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
