Question about Apple MacBook Pro Notebook
Sleeping mode problem
My macbook pro does not come back from sleeping mode
4 Suggested Answers
  • 18 Answers
SOURCE: My MacBook Pro fails to start up. The display
There are several different possible causes so if you have your manual it will tell you how to go through some of the resets. From what your describing it sounds as if the graphics chip is one of those possibilities. Nvidia had some questionable chips used in some of the 2007 model MBP's so if your MBP falls in this category you need to call Apple as they extended the warranty for these models to 3 years. There are some home remedies for this issue but I would definitely go through Apple as the graphics chip is part of the logic board as a lot can go wrong and there is no graphics card to just change out. If this doesn't apply to you then your back to the resets which you can get a list for all of these on the Apple website.
Posted on Nov 06, 2010
Macs R We
  • 481 Answers
SOURCE: How do you turn off DOS mode on a 13" MacBook Pro?
Is this a trick question? There is no "DOS mode" on a MacBook Pro.
Do you have WIndows installed as part of Boot Camp, and your machine is booting into Windows? To boot back into the Mac, either use the Boot Camp control panel in Windows, or hold down the Option key after you hear the startup chime and select the OS X partition to boot from.
Posted on Dec 02, 2010
  • 739 Answers
SOURCE: My MacBook pro was in sleep mode, and when I
Press the power button while counting to 10. then let go. Count to 10 again and press the power button as normal.
What happens?
Posted on Apr 09, 2012
Restart appears on start up
Resetting the PRAM may do the trick:
You reset the PRAM by rebooting a Mac and then immediately hold down the Command+Option+P+R keys, you will then hear the Mac reboot sound again, signifying your PRAM has been reset. You must hit the key combination before the grey screen appears otherwise it won't work.
you've tried rebooting, you've reset the PRAM, you've done it all, but your Mac is still behaving strangely. What next? In certain circumstances, resetting your Mac's System Management Controller (SMC) can be a solution. This is sometimes necessary to restore normal lower level system functionality to your Mac.
Here's how to reset the SMC on any type of Mac (and any version of OS X) and the type of problems that it may resolve.
When & Why Reset SMC on a Mac? Some Common Hardware Reasons
Typically it's power and hardware related issues that can be helped or resolved by resetting a Mac SMC, particularly if you're having these types of problems:
* Issues with your Mac's cooling fans and fan management: fans run constantly at high speed, fans run high despite low CPU usage and adequate ventilation, fans not working at all, etc
* Power management and battery problems: Mac isn't turning on, sleep isn't working, random shutdowns and reboots, battery isn't charging, Mac won't wake from sleep etc
* Light problems and improper lighting management: battery indicator lights aren't working, display backlighting isn't adjusting to ambient light changes, keyboard backlights not working, etc
* Video and external displays not working: display brightness functionality not working properly, target video mode isn't working properly, external display isn't working, etc
* General performance and functionality problems: abnormally sluggish behavior despite no CPU or disk usage, external ports not working, airport & bluetooth aren't showing up, external devices are not being found, etc
So now that you've concluded you need to reset your SMC (Note that the SMC is on Intel Mac's only), here's how to do it on MacBook's, MacBook Pro's, iMac's, Mac Mini's, and Mac Pro's. Notice that the reset instructions are different for MacBook and MacBook Pro's if you have an internal or detachable battery.
Reset SMC of a MacBook Air, MacBook Pro Retina, or MacBook Pro's with an internal non-removable battery
This is how to reset SMC on most modern Mac laptops:
Shutdown your MacBook Air / MacBook Pro
Connect the power adapter to your Mac
On the MacBook/Pro's keyboard, hold down the Shift+Control+Option keys and the Power button at the same time
Release all keys and the power button at the same time
Boot your Mac as usual
Here's the key sequence to hold down:
Reset the SMC of a MacBook Air or Retina MacBook Pro
Do keep in mind that by resetting the SMC you will lose power specific settings, like the time it takes to sleep a Mac and other customizations to power settings. No big deal, but if you have made many changes to your hardware behavior you will want to adjust stuff like sleep behavior again.
Reset SMC of an iMac, Mac Pro, Mac Mini
Resetting SMC is different for non-portable Macs:
Shut down your Mac
Disconnect the power cord
Press and hold the Mac's power button for 5 seconds
Release the button
Reattach the power cables and boot the Mac as usual
Reset the SMC of a MacBook or MacBook Pro's with detachable batteries
mac reset the smc Older MacBook laptops with a removable battery can reset SMC with the following approach:
Shutdown the MacBook/Pro and remove the battery
Disconnect the power adapter, hold the Power Key for 10 seconds
Release the power key and reconnect your battery and power adapter
Turn your Mac on
Let boot as usual
Hopefully that will clear up your problems, if not it might be worth a visit to the Apple Store or a certified repair center.
Happy New Year,
Kerry
Jan 26, 2014 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Macbook pro dark screen
Close the lid, attach an external monitor, reopen lid.
Your display should now show on that monitr. If it is, your display on the MacBook Pro may be bad. I would try resetting the PRAM and the SMC before going to an Apple store. The SMC controls the MacBook's power founcts (see below)
Shut down your Mac
Release the button
Turn your Mac on
Let boot as usual
Happy New Year,
Kerry
Jan 12, 2014 | Apple Computers & Internet
Keyboard Backlit not coming on at all
Set your backlighting in
Apple menu
System Preferences
Keyboard.
otherwise try:
Resetting the SMC on any type of Mac (and any version of OS X) and the type of problems that it may resolve.
Shut down your Mac
Release the button
Turn your Mac on
Let boot as usual
Happy New Year,
Kerry
Jul 08, 2012 | Apple MacBook Air
Macbook pro going into automatic sleep mode
Go into system preferences, click on desktop/screensaver and adjust sleep times.
Mar 12, 2011 | Apple MacBook Power Inverter Car Adapter
Hi i have an apple display connected to my macbook
Unplug the display from your macbook, and restart your macbook, when it's fully restarted and you are logged in, plug the display back in, then check to see if it is detected. Macbooks don't like to be put to sleep (shutting the lid) with a display connected, this causes issues with display detection. So always unplug your display and wait about 5 seconds before closing the lid on your macbook, and when you open the lid, wait another 5 seconds before plugging in your display. The only time it is acceptable to leave the display plugged in when you close the lid is when you plan to use the macbook in clamshell mode, this is done by plugging in and configuring your display, shutting the lid, and then "waking" the macbook from sleep mode with an external mouse (wired or wireless will work). That will start the macbook using the external display as the main display, without even turning on the macbook built-in display. Never connect or disconnect an external display when your macbook is off or in sleep mode. Have a nice day.
Jun 26, 2010 | Apple Cinema Display Flat Panel Monitor...
My Macbook Pro is not starting, it seems it goes
Try starting up in Safe Mode by holding down the shift key. That will be a start to get you into the System Preferences, find your Power Saver preferences and turn Sleep off.
Hope this helps!
Dec 28, 2009 | Apple MacBook Power Inverter Car Adapter
Macbook goes to sleep and doesn't wake up unless I do a hard reboot.
I have seen this caused by having a mouse plugged into mine. I have removed the mouse and touch the touchpad and it has come up from sleep.
That very well may not be your problem.
Here is the procedure that is recommend from Apple to help with the not waking from sleep problem. I included both methods as it is not clear which macbook you have. I also included the link to the article at the bottom.
The System Management Controller is an integrated circuit (computer chip) that is on the logic board of the computer. As the name implies, it is responsible for power management of the computer. It controls backlighting, hard disk spin down, sleep and wake, some charging aspects, trackpad control, and some input/output as it relates to the computer sleeping.
Over time, the settings in the System Management Controller may become unusable, which can result in operational anomalies with the computer. Examples include not turning on, not waking from sleep, not charging the battery, or not recognizing the AC Adapter, among others.
MacBook (13 inch, Late 2008), MacBook Pro (15-inch, Early 2008), and MacBook Pro (17-inch, Early 2008)
  1. If the computer is on, turn it off.
  2. Disconnect the AC adapter and remove the computer's battery.
  3. Press and hold the power button for 5 seconds and then release the button.
  4. Reconnect the battery and AC Adapter.
  5. Press the power button to restart the computer
Note: Starting with MacBook Pro (Late 2008) and MacBook (Late 2008) models, you may instead use the reset method for MacBook Air (below) to reset the SMC. All earlier models of MacBook and MacBook Pro must use the method described above, which involves removing the battery.
MacBook Air and MacBook Pro (Late 2008 and later)
  1. If the computer is on, turn it off by choosing Shutdown from the Apple () menu.
  2. Connect the power adapter to a working power source.
  3. On the built-in keyboard, press (left) Shift-Control-Option along with the power button once.
  4. Wait 5 seconds and press the power button to start the computer.
Note: You must use the keys on the left side of the built-in keyboard.
Here is the link to the article at the Apple support site.
http://support.apple.com/kb/HT1411
Aug 28, 2009 | Office Equipment & Supplies
My mac laptop doesn't wake up from standby/sleep
Check out these possible solutions:
http://www.christopher-chan.com/blog/index.php?/archives/588-Macbook-Pro-wake-from-sleep-problem.html
Jul 10, 2009 | Apple MacBook Pro 17 Notebook
Hp L1706 Monitor Keeps Going Into Sleep Mode
I have an hp media center that runs windows xp with service pack 3 and my monitor is an hpL1706 monitor and was running fine now it says no input and goes into sleep mode how do I fix it?
Apr 10, 2009 | HP Pavilion F1523 15" LCD Monitor
Macbook pro sleep problem
Reset PMU and P-Ram.
http://docs.info.apple.com/article.html?artnum=2238
http://docs.info.apple.com/article.html?artnum=14449
Apr 17, 2008 | Apple MacBook Pro Laptop Computer with...
Apple MacBook Pro Notebook Logo
43 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
