Question about Grinders
How do you change the wheels
Change the wire wheel
2 Suggested Answers
  • 60 Answers
SOURCE: abs light comes on intermitantly.
Intermittent ABS lights could be a wheel sensor but more commonly it is a sign your ABS controller is going bad. Eventually it will come on and stay on. If you have TRACS that will also come on and stay on. Eventually your speedometer will quit working. This site provides a rebuild service which is much cheaper than buying a new ECU. http://home.earthlink.net/~vicrocha/Volvo_Parts/Volvo_ABS_removal.htm
Posted on Oct 20, 2009
ABS light stays on 2008 street glide after putting on a 21 inch DNA
check for broken wire to the sensor rotor at each wheel
check that the inner part of the rim has not worn through the wiring to the sensor.
Jan 03, 2014 | Harley Davidson Motorcycles
No spark
The spark generator that sits close to the fly wheel only needs a mm gap. Make sure that this is the case. If there is a small gap there is possibly a break in the wire or the points under the fly wheel may also be rusty.
Jun 29, 2013 | Garden
2001 nissan pathfinder se wiring diagram
I have a 2001 Nissan pathfinder and had the stereo changed. The original stereo had the feature of the controls on the steering wheel but when the stereo was changed that feature no longer worked. I had brought the car to a shop where they installed that stereo and the controls were not working but I didn't want to bring it back to them. I now have a Sony Stereo in it now and would like to get the controls on the steering wheel working again. Could you please tell me which wires are the ones that connect the steering wheel controls to the stereo.
Mar 04, 2012 | Cars & Trucks
AWD disable and anti-lock light is on after changing a rear coil-spring. I had to disconnect the speed sensor from the wheel hub assy (I did reconnect). Any ideas on fix? It was sugested to repalce...
check wires at plug and follow wiring under plastic casing. had similar problem after changing wheel bearing and found broken wire. spliced wire and lights are off now
Nov 08, 2011 | 2002 Buick Rendezvous
My service traction light is one and my abs light is on
The abs makes the traction control work so fix the ABS first. The most common thing thea haqppens are the wheel speed sensers fail. In the front wheels the speed senser is incorperated into the front wheel bearing. these bearings are well known to fail at about 100 thousand miles and can fail aqs early as 80 thousand miles and most all of them fail before 140. You might notice a roaring sound ( like noisiy treaded tires) You can jack up one front wheel at a time and get in the car as your driving it and put the car in gear and run the car ( not moving but thwe trie is turing and listen for noise. I fht e wheel makes a roaring sound that gets worse as you go faster that wheel bearing is bad. Don't go over about 50 as with one tire on the groung the other that is turning, is going twice that fast or 100 MPH at 50 on the speedometer. Do the same test on the other wheel and if it's quiter or quite just change the noisy one. Once changed you just drive the car and the new wheel speed senmser will be reconized and the ABS light will go out as will the trac off light. If your ready to change both wheel bearings do so as they both have the same miles on them just not nessarily the same potholes and other rough pavement that makes them wear out faster. If thebearings are quite then you need to inspect the wires coming outr of the back of the wheel bearing.. Thjese wires get into troble and get unplugged or break the wire. If you havwe asscess to a scasnner that will address ABS systems it'll point out the ABS problem. Things that happen other than the wheel speed sensers are fuses blown for other reasons. The accumulater motor failure or extreamly cold weather the accumulate motor locks up in cold and blows the fuse. Thwe motors seldom fail but they can and do. Some veicals are nerer serviced and the brake fluild accumulates moisture ( as it's supossed to) and peaple never get the brakeing system seviced and the old brake fluild can freeze in cold weather and start croduing things. The Traction control sysem uses the brakes to control wheel spin by puting on the brake on the spinning wheel. If the system notices a wheel spinning. (Using the wheel speed sensers) So until the ABS is fixed don't try to fix the traction control system as it truly is part of the ABS systyem.
May 18, 2011 | 2004 Chevrolet Monte Carlo
Steering wheel changes
Here is the simple steps to change the old steering wheel and install the new one.
Remove the Original Steering Wheel
1.Read instructions that come with the steering wheel, and gather the following tools: screwdriver, pliers and a puller.
2.Point wheels straight ahead.
3.Disconnect battery or pull horn fuse before removing the old wheel. This prevents the horn from shorting out or blowing during installation.
4.Remove the horn mechanism by doing one or more of the following steps: Press down on the horn cap or ring and turn; remove the emblem cap from its snapped-in position by grabbing it and pulling it toward you or prying it loose; or if the horn ring is secured by screws that are concealed in the rear side of the wheel spokes, use a screwdriver to remove the screws and the ring.
5.Remove horn wire or spring-loaded metal plunger from plastic housing by either pulling straight out on the metal plunger or, on most models, by twisting the plastic sleeve to the left and then pulling out. Cut the wire off the plastic sleeve and keep the sleeve for later use.
6.Remove the shaft-nut retainer clip, if it is present, and keep for later use. Remove the shaft nut, which holds the wheel to the shaft.
7.Mark the shaft at the twelve o'clock position so that you will know where to position the top of the new wheel.
8.Insert a conventional puller into the two tapped holes which appear in the hub of the old wheel and pull off the steering shaft.
9.Remove the original wheel.
Installing the New Steering Wheel
1.Place the small tubular metal sleeve down over the steering shaft.
2.Position hub on splined shaft, making certain that the shaft is properly positioned using the mark you made in step 7. You may have to rotate the plastic horn contact tube slightly to align it with the appropriate hole through the hub.
3.Insert plastic sleeve and spring from step 5 without wire into plastic horn housing. If the plastic sleeve extends above the top bolt surface of the custom hub, cut down the sleeve so that it is 1/8-inch below the top of the hub. Remove sleeve.
4.Insert through the plastic sleeve the wire lead that was supplied in the wheel kit. One end will not pass through the sleeve. This bell-shaped end will go into the horn contact housing. Insert the sleeve and wire into the housing and lock into position.
5.Route wire around the hub from the ten o'clock position to about the two o'clock position to properly align wheel. Position post cover and wheel on hub. Make certain that the wire lead passes through the appropriate holes in the two o'clock position. Using the three shoulder bolts provided, fasten the hub, post cover and wheel together, but do not tighten.
6.Check wheel for proper positioning. If correct, reinstall the shaft nut from step 6 and tighten. Reinstall shaft-nut retainer clip. If the retainer does not fit into the groove on the shaft, tighten the nut until it will fit as originally located.
7.Remove shoulder bolts and reinstall them through the retainer ring with the fiber side toward you. Tighten the shoulder bolts with caution - excess torque will result in damage to the hub. The shaft nut, if correctly tightened, will firmly hold the hub and wheel assembly on the shaft.
8.Connect wire lead to the connector on the retainer ring. Position spring on center nut. Align the dimples of the horn cap with reliefs in fiber material and push into the dimples past the fiber. Turn cap left or right until tight.
9.Reconnect battery or replace fuse.
Sep 09, 2010 | 1991 Honda Accord
The fly wheel had A tooth missing, so i changes th...
OK go to the starter and pull on the smaller red wire. This is a fusible link and can look good while you are pulling id the wire give you will need to repair it remember the wire can be burnt inside of the cover and you will not know it until you pull on it
May 14, 2010 | Cars & Trucks
Changing the front tyre on a renault scenic
There is a wire handle that you use to remove the plastic centre cap then you put the jack at the jacking point. Before the wheel comes off the ground use the wheel brace which is also the jack handle to slighly loosen the wheel nuts. Jack the wheel completely off the ground and remove the wheel nuts and then the wheel
Oct 19, 2009 | 2001 Renault Sportwagon
The horn and cruise control doesn't work,fuses are
sounds like a bad clockspring. located in steering column under steering wheel, operates airbag, horn cruise etc, it make wire connection possible so the wheel can spin, its a roll of flat wires, that unroll and roll up as steering wheel is truned from left to right,wires break after a while.
Oct 02, 2009 | 1995 Ford Thunderbird
Grinders Logo
Top Grinders Experts
DrBogo
Level 1 Expert
Pieter Vleeshouwers
Pieter Vleeshouwers
Tom Chichester
Are you a Grinder Expert? Answer questions, earn points and help others
