Question about Mtd 46" Dozer Blade, Fits All & Yard - Man Lawn & Garden
I have a Yard Man lawn tractor w/ 46" width. A spring came loose and two belts jumped off their pulleys. I put the deck belt back on and reconnected the spring. However, I cannot get the drive belt back on. It has two guides to keep it from coming off and a can't get the belt through the narrow opening between the guides and the pulley. I 'm not sure what to loosen to open the gap.
  • alexprod May 21, 2009
    The guides are thick tabs that are part of larger brackets. I think they may break is I am even able to get that much force in that tight space.
    Brigadier General:
  • 8,619 Answers
Hi!
There is a long rod on the left side on the deck. That is like a belt tensioner. Just move it and you can easily place the belt on the drive. To place the belt on the drive put the belt on pully and replace the rod back in it's position.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Posted on May 21, 2009
  • 11,896 Answers
You can either pry it with bar or flathead and re-tighten with pliers afterwards. You can pull off the pulley if necessary. Pulling it off may be easier to manuver.
How do you replace drive belt on a 19 hp yardman 46 cut
Lisa, You could try to Google search your make and model# manual.
Check the attached links manual,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
46 Deck Belt Pulley Routing Riding Mower
Replace Your Lawn Tractor Deck Belt
MTD YARD MACHINES 46 CUT RIDING MOWER DECK BELT INSTALLATION REPLACEMENT
Yard Man 604 Operator Manual
Aug 06, 2016 | Garden
Should the deck belt be loose on the puuleys or tight like the drive belt
loose is a subjective term. As long as it is not flopping around or slipping on the pulleys it should be ok. You don't want it so loose it will fly off.
Aug 09, 2011 | Mtd 46" Dozer Blade, Fits All & Yard -...
Yard Machine tractor drive deck belt failure
i need a diagram of tensioner springs on yard machine deck 1998 42inch
Aug 11, 2009 | Yard Machines Red Edger
G-110 deck belt keeps jumping off pulleys
check for a broken belt tension er or maybe grass clippings under belt area, check for a broken or loose pulley bearing, even a bent shaft on the deck.
Aug 07, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
I need a diagram for the deck belt on my Cub Cadet 2160 mower.It has a MTD 46" deck model #300190
go to partstree.com put in your make &model #.then clickdeck assembly.hope this helps
Jul 16, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Yard man mtd 20hp 46"cut hydrostatic drive lawn tractor,model"13AU69H401 deck belt need diagram to put it back on?
go to the online web site for the yardman this will give you the guide on how to replace the belt.
Jul 12, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Drive belt diagram for mtd rideon
hi;go to partstree.com.put in your model # and make.then click on deck assembly.it will be what your looking for.hope this helps.please rate this;Thank's
Jul 04, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Engine Pulley 660 MTD Yard Machines
make sure the narrow side of the belt goes in the pulley; you may have the wrong belt; make sure all the pulleys for that belt are the same height , if one is higher than the others that may be the problem
Jun 12, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Yard Man 46" tractor mower driver belt
I had one belt come off and not sure of the positioning of the belts
May 21, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Mtd 46" Dozer Blade, Fits All  & Yard - Man Lawn & Garden Logo
108 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
