Question about Garden
M48a wont rev
My 12 month old mcculloch lawn mower starts easy and idles fine put lacks power and wont rev, stalls out when mowing thicker grass
    Habit-Forming:
  • 25 Answers
Check cable that is not loose when you adjust power or check that there's nothing rapped around the blades could decrease the power it's supposed to give when blade is spinning
Posted on Jan 07, 2014
SOURCE: Problem mowing my lawn.
I had the same problem and I already found those recommended solutions\ causes on the web:
1. The motor isn't on full throttle.
2. The blade is upside down.
3. The grass is too high when cutting it.
4. Overlap your cuts.
It helped my problem/ I hope it will help yours too!
Posted on Sep 01, 2008
nobby63
  • 10 Answers
SOURCE: lawn mower stalls when engine is hot
first thing is to check that plug is not fowling up when hot due to motor burning to much oil.
Posted on Jul 26, 2009
  • 143 Answers
SOURCE: 4.5hp B&S engine on a bolens mower..won't idle steadily
This is called hunting, your fuel-air ratio is not right. Your carb. jets need cleaned
Posted on Sep 05, 2009
Testimonial: "Thanks...always get great advice on here...."
Dolfoff
  • 148 Answers
SOURCE: Poulan 550 mower idle problme
Check air filter, replace if needed.
Check engine oil level and condition. Add/change as needed.
Check spark plug. Clean and re-gap if needed (.030 gap)
Drain the fuel and replace with fresh premium grade gasoline. If your local station has a notice on the pump regarding Ethanol content, drive to another station!
Most owner's manuals specify 89 octane or higher and most warranties become void if E85 fuel is used.
And finally, Oxygenated fuels are not your mower's best friend. :-)
Hope this helps.
Posted on Oct 05, 2009
  • 52 Answers
SOURCE: Stopped. Black and Decker Lawn Hog 18-Inch Electric Lawn mowe
you could check the brush connection on the motor or your switch mat not be making contact
Posted on Apr 15, 2010
It ran mowed a hard lawn of grass now it wont start to moe soft blade grass
while unplugged try turning the blade by hand . it should turn easily . then check to see if grass or string has gotten wound around the shaft.
Oct 17, 2015 | Greenworks 20" 12 Amp 3-in-1 Electric...
John deere instructions
Your mower doesn't have enough power to handle very thick grass at high speed. You need to go slower across the lawn. That's easy to do if this is a push mower (just don't walk so fast) or if it's a self-propelled model with a speed control. But if it's a single-speed model you'll have to mow the lawn in fits and starts: squeeze the lever to move it forward; release it when you hear it bogging down; wait for the motor to reach full speed; squeeze the lever to move it forward again; repeat. Also, is the grass very high? If so, try setting the cutting height higher on the first pass, then lower it for a second pass. Finally, make sure the blade is sharp.
Aug 06, 2014 | Briggs & Stratton 190cc 875 Series OHV...
Bits of burnt stuff coming out of lawn mower
that was burnt carbon coming out and you did overwork that lawn mower not dangerouse but keep mowing long grass you will end up buy anew one soon
Dec 04, 2011 | Briggs & Stratton Briggs Stratton...
Craftsman Platinum 190cc 22" Briggs
hi there
danielburgi
1 almost sounds like you may have a restriction in the main jet of the carburettor or idle circuit transtional holes or idle air bleed holes , also check emulsion tube
2 then if these are all ok try adjusting governor - as soon as load exceeds power output - unit will try and stall- once governor adjusted re-try -
3 the only other thing it may be is too low compression which ia major concern
try 1 and 2 options 1st
3 is the last option which means a leak test to check compression loss or worn rings
cheers pauly46
hope it helps
May 27, 2011 | Garden
Was mowing the lawn the other day, when over some thicker grass and it shut off. When I pull the starter cord it gets stuck; the flywheel won't turn. I checked the ratchet pawls and they seem to be fine....
Unless some tough grass blades got wrapped around the blade spindle (which would stop the blade from turning anyway) the motor probably just stalled because it wasn't powerful enough to shred up the thicker grass so that, in itself, may not be directly related to the problem you are experiencing. These mowers are relatively simple creatures so there are not many things to go wrong. If you lay the mower on its side and rotate the blade by hand you should be able to see the flywheel turning through the air intakes on top of the mower. If the blade is turning but the flywheel isn't it would seem to indicate that something has sheared off in between the two and/or the engine has seized up. As you turn the blade can you hear the piston sucking and blowing? If you can then the engine has not seized and the problem lies in the flywheel assembly.
Jan 30, 2011 | Craftsman 675 Series 190cc 22" Briggs ...
Lawn mower stalled while cutting grass and cord
Check under the mower to see if anything is lodged in the blade, preventing it from turning. It that is clear, then the motor may have siezed up. possibly due to lack of engine oil
Sep 20, 2009 | Toro Garden
Mower bogs down in medium high gras
what is happening is there is tomuch grass in deck & not discharging as fast as it cuts it if deck is ajustable put it on high setting then try if it works then got back over it with a lower setting this is most likely the case to much grass in deck while mowing blade gets cought up alot with alot of grass in deck
Jun 05, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
106 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
