Question about Car Audio & Video
Unfrotunately i disconnected my battery terminal. and i connected it. after a while, when i opened the radio, it asked me to enter a code. but i didn't know the code and also i haven't any manual or other things to refer it. if it helps you the following are detail information of the radio. model no.22DC259/62, Product no.FD0401050142416, and its seriel no. is RN259F10142416. Thanks in advance for your help.
    Top Expert:
  • Car Audio & ... Master
  • 77,499 Answers
That info is not free, you can get it from the dealer or try this website. https://www.radio-code.co.uk/
Posted on Jul 06, 2017
Remove starter acura 2000
  1. Make sure you have the anti-theft code for the radio, then write down the frequencies for the radio's preset buttons.
  2. Disconnect the battery negative terminal first, then the positive terminal
  3. NOTE: The PCM memory setting is needed after reconnecting the battery.
  4. Raise the coolant reservoir, then remove the battery and battery base.
  5. Remove the alternator belt and alternator.
  6. Remove the left exhaust manifold cover.
  7. Remove the left damper fork.
  8. Disconnect the left suspension lower arm ball joint.
  9. Remove the left driveshaft.
  10. Remove the transmission stop collar, then remove the exhaust pipe A.
  11. Remove the front mount mounting bolts.
  12. Attach the chain hoist to the engine
    1. Remove the left engine mount bracket
    2. Disconnect the starter cable and BLK/WHT wire, then remove the starter.
    3. Install in the reverse order of removal.
  13. NOTE: When installing the starter cable, make sure that the crimped side of the ring terminal is facing out.
    1. Enter the anti-theft code for the radio, then enter the customer's radio station preset.
Nov 29, 2016 | Acura Cars & Trucks
How can I enter my car radio's Code number (see details below)?
I would say some one has tried to enter the wrong code, remove the + terminal on the battery for a minute and replace this should reset the code.
Sep 24, 2014 | Cars & Trucks
I have a mercedes benz year 2000 320 and my radio needs its code please help
contact your dealer for radio code if your screen goes blank and the fuses are good usually when adjusting settings this occurs or a cd is acting up, disconnect the battery terminal for 2 minutes and reconnect screen should then ask for code enter and should be good make sure you write code down for future
Aug 08, 2013 | Mercury Cars & Trucks
System not programed
At R/H side of boot/trunk disconnect car battery neg terminal. Leave for up to 5 mins and reconnect. Its just like re-booting a computer, and will clear this 'fault'. Make sure you have Radio's 4 digit code and re-enter. If the fault was the result of a flat battery always re-charge battery with cars neg terminal disconnected, never re-charge with battery connected to cars elect system.
Mar 05, 2013 | 2007 Maserati Quattroporte Executive GT...
My radio is locked. Have code but radio is off
Try to disconnect the battery negative terminal, then the positive terminal. Leave the terninals disconnected for about .30-minutes to clear the radio's memory.
After thirty minutes, connect back the negative terminal of the battery, then the positive terminal.
Then enter the radio code and see what happens. If it still fails to turn-on, then repeat the procedure.
Dec 18, 2009 | 2003 Mitsubishi Eclipse Spyder
How do i unhook the battery
You disconnect the negative side of the battery first, that's the black terminal. The you disconnect the positive side which is the red terminal. After you have done that there should be a bolt towards the bottom of the battery on one side that holds the battery to the battery tray. Be fore you disconnect the battery, make sure your radio is off or you'll end up locking the radio and will not work till you re enter the activation code to have your radio work again. Good luck and hope this helps, Keep me posted,be glad to help.
Jun 09, 2009 | 1997 Cadillac DeVille
Location of start motor
Looks like it is on Passenger side @ Junction where transmissiom& Engine meet
2001 Acura 3.5RL V6-3474cc 3.5L
  2. Disconnect the battery negative terminal first, then the positive terminal. NOTE: The PCM memory setting is needed after reconnecting the battery.
    1. Raise the coolant reservoir, then remove the battery and battery base.
    2. Remove the alternator belt and alternator.
    3. Remove the left exhaust manifold cover.
    4. Remove the left damper fork.
    5. Disconnect the left suspension lower arm ball joint.
    6. Remove the left driveshaft.
      1. Remove the transmission stop collar, then remove the exhaust pipe A.
      2. Remove the front mount mounting bolts.
      3. Attach the chain hoist to the engine
      4. Remove the left engine mount bracket
      5. Disconnect the starter cable and BLK/WHT wire, then remove the starter
      6. Install in the reverse order of removal. NOTE: When installing the starter cable, make sure that the crimped side of the ring terminal is facing out.
      7. Enter the anti-theft code for the radio, then enter the customer's radio station presets
Mar 04, 2009 | 2001 Acura 3.5RL
Car Audio & Video Logo
23 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
