Question about Xerox WorkCentre Pro 232 245 255 Fuser Module 109R00751
XEROX PRO 245 HEAT ERROR FAULT - Xerox WorkCentre Pro 232 245 255 Fuser Module 109R00751
3 Suggested Answers
pineworks
  • 4041 Answers
SOURCE: xerox phasor 8400 - fault 37,004,40:157517"
Hi I can gave you some error codes but this all I can do hope it be of help to you.
8,009.4x:CAP_FAULT_MP_NO_ CLUTCH_STALL:
  • The media path motor has stalled while moving without the clutch engaged.
33,001.4x - TM_DEV_FAULT_MPT_WIDTH_VALUE_TOO_LOW
  • Tray 1 status:
1. Check the wiring and connectors from the front door to the I/O board.
2. Run the Test Tray 1 Width Sensors.
3. If the test fails replace the front door.
4. Replace the I/O board.
08.055.44:
  • The media path drive module has stalled while engaging the head tilt.
37,008.44:
  • The Preheat preheater is not drawing the expected power from the supply.
Run the Preheat Heater test, check the wiring. If test fails and no apparently problem is evident, replace the preheater.
05,002.42:
  • Problems with the Y-axis. It could be the belt,motor or the drum.
7,008.4x: PM_FAULT_HEADTILT_NOT_ ENGAGED
  • The printhead tilt is not engaged, so it didn't tilt back properly or the printhead is stuck in the tilted position by the tilt lock arms. The process motor gear train getting out of sync can also cause this error.
1. Try rebooting the printer.
2. Check for an obstruction or damage in the process gearbox.
3. Ensure the gears are correctly aligned and homed. If faulty replace the process gearbox
assembly.
4. Run the Tilt Axis Drive test to test the headtilt.
5. Run the Head Maintenance Wiper Clutch test. If the test fails, replace the wiper drive clutch.
6. Run the Wiper Axis Drive test.
7. Replace the exit assembly.
7,010.4x: PM_FAULT_HEADTILT_HOME_ERROR
  • The printhead is stuck in the tilt position by the tilt arms. The process motor gearbox being out of sync can also cause this error.
1. Reboot the printer.
2. Verify the lock arms rotate correctly.
3. Check for spilled ink around the printhead.
4. Check the process motor gears for damage. Ensure the process gears are correctly aligned and homed.
5. Verify the process gear box, process shaft, and drive module shaft are at home position.
6. Verify the headtilt gear will engage, see the home positioning procedure on page. You can manually engage the headtilt gear.
7. Run the Tilt Axis Drive test.
8. Run the Process Motor test.
9. Run the Head Maintenance Clutch test, if the test fails replace the clutch.
10.Run Wiper Drive test. If this fails inspect the wiper drive system.
All The Best: Pineworks
Posted on Jan 30, 2010
  • 258 Answers
SOURCE: how to remove hard drive in xerox pro 245 copier
Hard drives in printers? Never heard of such a thing. Memory maybe but not hard drives. Go to the Xerox website and enter your model and they should be able to help you. Unable to help with this one. Good luck.
Posted on Jul 06, 2014
HOW TO RESET ERROR CODE 04-562
Not a copier guy here BUT came up with this
1) From here
http://www.copytechnet.com/forums/xerox/43094-error-04-562-workcenter-pro-c3545-print.html
It sounds like 'Image Belt Transfer' whatever that is.
'you can enter in serice mode on this model only with laptop and xerox wcp diagnostic navigator'
2) from Zerox here. http://www.support.xerox.com/support/workcentre-pro-c2128-c2636-c3545/support/enus.html click on fault code search , put in code.and......
'Needs further customer support.'
Sounds like a 'belt' inside the machine broken or faulty.
Hope this assists you.
Sep 16, 2014 | Xerox Copier Toner, C2128, 2636, 3545...
How to remove hard drive in xerox pro 245 copier
Jul 06, 2014 | Xerox Office Equipment & Supplies
My Copise Xerox work center pro 423 are showing on display this error (U4-2) how i can clear this error please please tell me any body if knows
my copise xerox work center pro 423 are showing on display this error (u4-6 @ reboot) how i can clear this error please tell me
Mar 18, 2011 | Xerox WorkCentre Pro 423 Copier
Workcentre Pro 245 shows an "Internal Power Supply Failure". We just got the machine and it tested OK. We moved it carefully and tested it again OK. But an hour later, it showed this error...
There are 4 solutions to try and they don't fit in their entirety so I included links to each one. Please be sure to read the instructions entirely AND ensure you need to perform each one.
1. Power machine on and off http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=269,E=0000000002703128583,K=4118,Sxi=8,Solution=obj(4322)
2. Clean the Charge Scorotron and the Transfer Corotron: http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=269,E=0000000002703128583,K=4118,Sxi=8,Solution=obj(4186)
3. Perform a Software Reset at the Printer: http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=269,E=0000000002703128583,K=4118,Sxi=8,Solution=obj(5315)
4. Replace the Xerographic Module and Transfer Unit: http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=269,E=0000000002703128583,K=4118,Sxi=8,Solution=obj(3362)
If none of those fail to resolve it call for service.
Hope it helps!
Mar 08, 2011 | Xerox Office Equipment & Supplies
I have a Xerox, Workcentre 580 and I am getting a fuser error
On this model, the heat roll has a temperature sensor. If the heat roll is worn and coated with toner, this will damage the sensor. Most common problem is this sensor goes out when a heat roll is badly worn. Circuit boards on this model are pretty reliable.
This sounds like a fuser rebuild.
Feb 16, 2011 | Xerox WorkCentre Pro 580 Plain Paper Laser...
Xerox Docucolor 12
Error in the Fuser. The description for this fault code is: External Heat Roll Contact Failure. Generally the external heat roll retract motor is defective. The xerox part number of this motor: 127K21350
Aug 20, 2008 | Xerox DocuColor 12 Color Copier
Xerox workcenter pro 765 error 22
That is a fuser not reachine tremperature fault.
Most likely the fuser will need replaced.
Go to google and type in "the parts drop".
Call Britt and he should be able to fix you up with that part for a fair price.Just tell him the model number and code.
Aug 18, 2008 | Xerox Office Equipment & Supplies
Error mesage
NOTE: Some Status codes will not clear even though the problem has been fixed. Status codes that will not clear must be manually reset using the 'Fault Reset 14 Procedure'.
  1. Locate the [C] (Clear) button on the Control Panel, at the far right.
  2. Locate the Image Quality button, below the Auto on the Control Panel, toward the left side.
  3. Press the buttons in the following sequence within 4 seconds. Press [C] (Clear), press [Image Quality], press [C] (Clear) again, press [Image Quality] again.
  4. The error code should disappear. If the Status code does not clear, repeat step 3 until the status code clears; but no more than five times.
  5. Use the [10] and [1] buttons to enter 14 on the Display Screen, as if you were to make 14 copies.
  6. Press the [Start] button. The machine should be ready to use.
  7. Make a copy, to check that the machine is working properly
IF these steps do not work you will have to replace the fuser or fuser heat rod then perform the reset.
May 15, 2008 | Xerox WorkCentre Pro 16fx Laser Printer
Xerox WorkCentre Pro 232 245 255 Fuser Module 109R00751 Logo
18 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
