Question about Minolta EP4000/5000 CS/PRO Copier
C200 code my copier doing the problem is mis print and c0040 code show the screen again by again plz you help me for solve this problem
  • temoor_hassa May 21, 2009
    plz kindly you open your branch in karachi pakistan for technical problem
  • 469 Answers
C0040, Suction Fan, failure to turn.
The fan under the transport belts is not working.
The fan will likely have to be replaced.
Hope this is of some help.
Ed
Posted on May 22, 2009
How to solve canon ir2870 copying problem ?
Welcome.
If you copying on top glass plz use offset function and then do job done with multi job.
Jul 21, 2014 | Canon Office Equipment & Supplies
My printer will print one page and stop printing in the middle of the second page.
I think you are seat only one print one time so plz check it. Go to printer option and setting. One time you check printer after your printer which mode show like active print mode, print error, hold print mode etc.
I suggest you Full uninstall printer driver and re-again install printer driver. If not solved then change printer cable.
If more help contact Dell printer Support Technician. and TechSupportPrinter expert team.
Thanks.
Jan 11, 2014 | Dell Photo 926 All-in-One Printer
I have a blackberry 8310 i forget the passward plz help how can i open it now
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Aug 21, 2012 | Computers & Internet
Malfunction code C0040
Minolta copier show error code c0040. Please show me the picture that point of problem. The second problem. What is the way we could what kind of minolta di ...in the machine?thanks in advanced.
Apr 12, 2012 | Konica Minolta DiALTA Di200 Copier
My zebra gk420d printer stops printing.
You can ask a printer Maintenance Technician to solve the problem for you.
Feb 23, 2012 | Zebra GK420D Direct Thermal Label Printer
Am not able to print anything and on the screen popup a window that shows ERROR B200. how can I solve the problem?
this means that you have print head monitor error, it is also shown as 11 blinks of orange LED.
To solve the problem you need to replace print head! Code: Print head (QY6-0061)
Hope that helps!
Apr 27, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
C 0040
C0040 is a cooling fan failure code. Opening and closing the front door wil reset the code. Doing this while "bumping" the machine will restore the machine to operational MOST of the time. Cooling fan replacement will eventually be required. Resetting though can be accomplished in most cases.
The part number for the fan is 9313-1310-61 and here is a picture of the fan which is located behind the rear cover.
Jun 12, 2010 | Minolta EP4000/5000 CS/PRO Copier
Toner exhausted replace toner in Laser Printer SCX-4300
My laser Printer shows a message and do not prints any document. When i try to print any document. My printer shows a message "Toner Exhausted, Replace Toner". Plz tell me how can i solve my this printer's solution.
Mar 25, 2009 | Samsung SCX-4300 Monochrome Laser...
2h flashing on screen,won't print
heat roller problem , enter # ,interupt, c , interupt machine goes off and enter 14 then press print buttom. this might clear ur problem. if it repeat same h2 code. need to change thermister and enter above code 14 again
Dec 02, 2008 | Sharp AR-5316 Advanced Digital Imager...
EP3050 error code C0040
A C0040 error code indicates a problem with the suction deck fan. It has nothing to do with the paper lift motors.
The fan is accessed by removing the rear cover of the copier. It is right in the center. These are readily available (p/n 9313-1310-61) although they are not cheap (around $200 retail).
Nov 15, 2008 | Minolta Office Equipment & Supplies
171 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
