Question about Brother VX808 Sewing machine
How do I adjust the tension?. Bottom thread is loopy and top thread is loose and almost looks zig zag.
SOURCE: Brother LS-2125 Upper Thread Snapping
I had the same problem and it was so frustrating! It was happening to me because I wasn't using the right size needle. Go up a couple of needle sizes and see if that helps.
Posted on Mar 09, 2009
SOURCE: Tension problem Bottom thread is loopy and sloppy
SALUDOS, MI MAQUINA HACE ESACTAMENTE LO MISMO UN DIA DERREPENTE DEJO DE BORDAR Y TIRA TODO EL HILO, LO HACE BOLAS POR LA PARTE DE ABAJO, Y DESCUBRI QUE SE ROMPIO UNA LAMINITA QUE LLEVA FRENTE A LA LANZADERA DONDE SE COLOCA LA BOBINA.
TAL LAMINITA SE LLAMA RESORTE PERO NO TIENE NUMERO NO LA HE PODIDO ENCONTRAR, DICHO RESORTE VA INSTALADO AL LADO DERECHO EN EL MISMO LUGAR DONDE ESTA INSTALADO EL LASER. AGRADECERIA ME DIERAN EL NUMERO PARA PODERLA COMPRAR. MIL GRACIAS.
Posted on Aug 15, 2008
Michaelle
  • 65 Answers
SOURCE: No "Zig" to my "Zag"
I Love the support Brother gives!
Here's what Brother says about the Zig zag issue.
http://welcome.solutions.brother.com/BSC/public/us/ca/en/faq/faqh/000000/000000/000018/faqh000018_000.html?reg=us&lang=en&c=ca&prod=hf_xl5130eus&page=FaqEndPage
your manual (download)
http://welcome.solutions.brother.com/BSC/public/us/ca/en/model_top/HomeSewingMachine/hf_xl5130eus.html?reg=us&c=ca&lang=en&prod=hf_xl5130eus
Posted on Jan 27, 2009
Mimito7
  • 128 Answers
SOURCE: thread loopy on top
General rule of thumb::
loops on the bottom, problem on the top.
loops on the top, problem on the bottom.
It sounds like your bobbin thread is not thru the little tensioner in the bobbin compartment.
Posted on May 28, 2009
  • 36 Answers
SOURCE: lower thread tension very loose
is the bobbin threaded correctly? the screw on the bobbin case is the point to adjust its tension.
Posted on Jun 02, 2010
Doing zig zag the bottom thread is so loose - what is wrong?
the needle thread tension is too loose
tighten it up so that it pulls the bottom thread up into place
Sep 26, 2016 | Sewing Machines
Need to now where to put tentions to sew sweat pants.
use a couple of pieces of waste material the same as the sweat pants material and sew about an inch long
adjust the needle tension and do it again
repeat the exercise until the top and bottom thread joint at the middle of the two pieces of the material
tension settings on the machine are a loose guide as the thread thickness, material thickness and needle size all have a bearing in the tensions of the thread
so practice and adjust prior to sewing is the way to go
Nov 07, 2015 | Sewing Machines
The bottom stitch is very loose. I've tried tightening and loosening the screw and the problem remains...HELP!
The bottom stitch is affected by the TOP thread tension :) First go back and make sure your bobbin tension is correct since you adjusted it. It should drop slightly when held suspended by danging it by the thread. If it reels out to the floor it is too loose. If it doesn't drop at all it is too tight.
Now that you have that adjusted look at your top tension. If it is loopy on the bottom side of the stitch the TOP tension is too loose. Increase the top tension.
Now take some scrap material and set machine to a wide zig zag, medium length stitch and sew a bit. Compare the top and the bottom sides of the stitch. They should look identical. Remember the TOP side effects the bottom and the BOTTOM tension effects the top side. Adjust accordingly until they look identical with no loose threads or loops and no puckering (puckering means it's too tight).
May 03, 2011 | Brother LX3125 Sewing Machine
I cannot get the tension right on my 2600 Brother machine. I am stitching in the ditch with three layers of material. Can you please help?
Make sure you have the right size needle...not to small. Then do a simple seam through three layers (doesn't need to be a seam just sewing through 3 layers of scrap) using a wide zig zag stitch. Examine the stitch looking at both sides. Do they look even, identical?
Think in opposites, ie the bottom thread tension affects the stitch on the top side and the thread tension on top affects the stitch on the bottom side. If one side is loopy then the opposite side tension is too loose (or, sometimes that side's tension is too tight). Adjust until both sides are identical looking. Then try stitching in the ditch like you wanted to.
Mar 30, 2011 | Brother XL-2600
The tension seems to be loopy on the underneath of the fabric just can't get it right
Tighten the top tension. To check the bobbin tension take the bobbin out and dangle it by the thread like you would hold a yo yo. A gentle flick of the wrist should cause the bobbin to drop down some but not just spin out to the floor, ie there should be some tension. If it hits the floor it is too loose. But if it doesn't release, fall, some it is too tight.
When you stitch a broad zig zag if the tension is correct it will look identical on the top as it does on the bottom. If it is smaller on the top then the bobbin is too tight. If it is smaller on the bottom than the top tension is too tight etc.
Mar 26, 2011 | Sewing Machines
The thread underneath when sewing is too loosed
Usually thread too loose on the bottom is caused by the upper tension being too loose. The top and bottom tensions work together with the top thread making the underside of the stitch seem too taunt or too loose and the bobbin thread causing the top side of the stitch to be loopy or too tight. Select a large zig zag stick and sew a couple of inches. Then examine the stitch. It should look identical on both sides. Look to see which side is drawn too tight, the zig zag being smaller on that side with threads from the bottom threads pulled through. Then adjust the two tensions so that they make a uniform, identical stitch.
Also, when the bobbin tension is right you can hold the bobbin dangling by the thread and it won't spool out to the floor but will let loose a bit with a slight flick of the wrist. Too loose it will just spool out. Too tight and it won't drop at all. When you get that set right then do the above zig zag test to see where the top tension should be set.
Mar 02, 2011 | Sewing Machines
How do i set thread tension on a 306W Singer Zig-zag? Bottom thread all loopy.
Top tension about 4 or 5, make sure the presser foot is up when you theread the machine, make sure you can just pull the bobbin thread through with some slight resistence, if it is too tight slacken the screw on the bobbin case a quarter of a turn at a time anti clockwise.
May 05, 2009 | Singer 8280 Mechanical Sewing Machine
Zig zag stitch
If your stitches do not look good on the top side you have a problem with the bottom thread. make sure you have the correct bottom tension: Is the thread under the bobbin tension plate and when you hold the bobbin and case lightly in your hand the tension should be set in a way that there is little resistance , yet still some, when you pull the thread. After you set your bobbin tension, you may have to adjust your top tension to balance. Also make sure the thread comes off of your bobbin the way your manual tells you, clock or counter clock wise.
Make sure your bobbin (plastic) is not sooooo old, buy a new one.
Jan 14, 2009 | Necchi 6011
Suddenly zig zag stitch not working?
Because it is almost a straight stitch but the needle continues to move in a zig zag fashion is reason to believe it is in a long stitch. By changing the number of stitches per inch there will be a very noticeable looking zig zag stitch.
Mar 25, 2017 | Brother XL-2610
Brother VX808 Sewing machine Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
