Question about Frigidaire ATF6000ES Front Load Washer
Need to secure for moving
How do I secure my front load washer for moving.
  • 90 Answers
You should have some bolts that came with the machine. They are fitted into the rear casing and screw into the drum to hold it steady. If you dont have the bolts then you can try packing some towels around the outside of the drum ( from underneath ) to hold it steady.
Posted on May 21, 2009
I have an LG WM-0532HW Front Load Washer. upon trying to fix a diffierent problem, something popped. I couldn't find anything broken. However, the inside metallic tub is not longer stable. During the...
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Jun 26, 2011 | LG WM-0532HW Front Load Washer
Washer is making a rapping noise on all cycles
The drum may have become damaged if it was moved without securing the drum.
Your washer probably came with drum "bolts" to hold it securely while moving it.
http://www.ehow.com/how_6731367_transport-front-load-washer.html
Mar 01, 2011 | Kenmore HE3T Washer
Door won't lock on top loading kenmore elite oasis washing machine
1. Disconnect the electrical cord from the wall.
2. Move the washer forward about 12 inches.
3. Lift the lid and grasp the front of the washer top with both hands.
4. Place your knee on the front of the cabinet and pull the washer top forward and up.
The lid lock mechanism is secured to the bottom of the washer top with two screws. Remove those screws and the wiring will be exposed. Unplug the harness from the old mechanism and connect to the new one.
Secure the new mechanism to the washer top and let the top down.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 16, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Do I need to secure the tubs inside Kenmore Elite Washer & Dryer?
Not the dryer but you do for the washer ... there is bolts that go in the back to hold the tub ... the bolts came with the washer went it was new... you may be able to get a set from sears...
Oct 03, 2009 | Kenmore Elite 45986 Front Load Washer
New front load washer dryer is vibrating badly when drying
Q - My washer keeps moving around n the floor, is there any simple things that I can check ?
A - Yes, there is...The legs on the washer are adjustable, the rear legs are often ( not always ) self adjusting, make sure the legs are not stuck and that they can move freely. But the front legs can screw in and out to move the washer depending on the floor the washer is sitting on. Make sure the washer is as low to the floor as possible. When the legs are screwed out too far the washer becomes wobbly. Often on the metal style legs there are lock nuts that can be tightened to secure the legs so they don't move on you. washers where really meant to sit on a cement floor, if your washer is on a wooden floor look carefully at the strength of the floor. If the floor is moving up and down when the washer is running, the floor may not be strong enough to support the washers weight. Most main floor laundry rooms floors are nailed down, the sub-floor is more secure if the sub-floor has been screwed down. Sometimes extra support may have to be added under the flooring to add some strength
Mar 14, 2009 | Samsung B1245 Front Load Washer
How to secure front loading drum for moving????
transit bolts vary with machine. pack polystyrene blocks tighty between tub and cabinet and that will do the trick
Sep 25, 2008 | GE WCVH6260F Front Load Washer
LG Front Load Washer Problem
The washer is not leveled correctly.  You will need to adjust the front feet to level the machine.  Run a load of clothes in the washer.  When it gets to the spin mode, check the level of the machine by pushing the front left corner and the front right corner.  If the noise quiets down on either corner of the machine, adjust the legs on that side.
Jul 22, 2008 | LG WM-1832C Front Load Washer
Banging tumbler during spin cycle
Be certain that nothing got under the rubber skirt, pull it back and look /feel under it .
inside the tub are the large wiper arms solid and not come loose.
open the top access panel (3 screws in top rear )
and open the bottom access Panel (3 screws in bottom front)
Dissconnect power .
Look at the springs and arms that attach to the tub are they secure.
is the large stone concreate slabs secure.
move all these items and push at them all secure?
you can run it while open but the bottom has a switch on front right that has to be closed.
look watch listen.
Feb 03, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Front load washers
Not advisable to bolt down; for if there is a problem with springs, etc you will not know - for the machine is secure. And serious damage will occur while the machine remains bolted down. Your friend has a problem with her shocks or springs and requires to be looked into.
Apr 11, 2007 | Asko W600
Frigidaire ATF6000ES Front Load Washer Logo
154 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
