Renault fault code df072 - Computers & Internet
I have a Renault loloader and need code for radio
contact renault with your vin number
and they can get the code
or with a fault diagnostic reader ....show the code
Jun 29, 2016 | Renault Cars & Trucks
Fault code DF066 renault megane 1.6
That is not a valid fault code, what kind of scanner was used? What is the problem with the car, stalls out what?
Jun 21, 2016 | Renault Cars & Trucks
Renault fault codes
check connector on injector 1 and check resistance of the injector
Jul 08, 2014 | 2010 Renault Megane Grandtour
Megan 54 1.6 petrol 16v code Df071 df072
where did you get these codes as OBD codes start with P and then four digits .
May 14, 2014 | Cars & Trucks
Renault fault codes
hi there i have a renault clio 57 plate 1.6 auto. it keeps going into safe mode on the gearbox intermitantly. i have read auto trans fault codes which are df241 df240 df242 df243 and df231 which relate too abs sensors.have you any ideas thanks
Apr 29, 2014 | 2002 Renault Clio
Renault OBD fault code 4103
Your trying to read a fault code on a renault ?? better man than me gunga din ,dont you know that this year renaults all use encrypted software??
May 13, 2013 | 2003 Renault Renault Scenic 1.6
Hi fault code cam to crank sincro out but timming spot on engine does evrything but start from key bumps easy starts with a sniff of carb cleanner but no otherway weather hot or cold thanks phil
well forget the fault code reading this is a renault remember and you are lucky if you can get the vin number up ,now i had this fault before with a renault ,and i cant remember what i did ??? i think it was the vacumn pipe on the shut off valve on the fuel rail ,it was perished or split or something stupid
Sep 15, 2010 | 2004 Renault 181
Renault megane 1.4 16v
could be a sensor will need to hane a fault code read to detrmine where the fault is
Jan 13, 2009 | 1986 Renault Sport
Computers & Internet Logo
97 people viewed this question
David Payne
David Payne
