Question about Select Jazzy Used Electric Wheelchair
Batteries are charged disconnected and used seperate charger thet had 3/4 charge to start with push start button nothing wheels locked but when charger is plugged in controller lights light up showing
Batteries are charged disconnected and used seperate charger thet had 3/4 charge to start with push start button nothing wheels locked but when charger is plugged in controller lights light up showing full charge..... checked 50 amp fuse and it is good....the controller only lights up when its plugged in but nothing shows on charging meter.... JAZZY SELECT SCOOTER
  • Barry Nixon May 11, 2010
    First you need to have the batteries load tested.
  • 32 Answers
It sounds like dead cel in one of the batteries, try having batteries loaded tested.
Posted on Jul 13, 2009
How can I change the battery in m9100 kocaso
Try the follow to see if it will fix it:
There is a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
If your tablet does not have the reset button: With the tablet plugged into the charger, hold the power button for 10 seconds then click the volume up once. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
After performing the power reset on the device the device will behave in one of the following ways:
1. The tablet will turn on like normal.
2. The tablet will show the battery icon only.
3. The tablet will show nothing on the screen at all.
All of these are normal for the device and should not be cause for alarm. If the device still fails to power on after being left on the charger for 4-6 hours,
Then most likely the battery will need replacing.
Here is a link to where you might be able to get a new battery:
Replacement 4000mah Battery for Kocaso M9100 M9000 9 MID All Winner A13...
Jan 23, 2015 | Kocaso M M9100 9-Inch 8 GB Tablet
Wont start up
Please make sure the tablet is charged for at least 4-6 hours. Also, make sure the correct button is being used, oftentimes we hear the back or home button has been used in error. If the issue persists, you can try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
Support Troubleshooting Guide
Mar 23, 2014 | Kocaso M M9100 9-Inch 8 GB Tablet
Scooter batteries are completly discharged for a long time. the red light on. while connected to the 220v. All fuses are checked OK. the charger outlet is round 3 poles connector. you said it will not...
Use an automotive NON automatic style to charge the batteries individually. This may tale up to 72 hrs. to get the voltage up tp at least 10 volts. When that happens, the regular battery charger made for the scooter will finish off the charge. If the battery won't take a charge, then they're history.
Feb 09, 2014 | Pride Travel Pro 3-Wheel Mobility Scooter
Micromax x272 charging show but not charging
Hi, so it telling you it's charging however the scooter shows no charge once the charger is disconnected ???
1. First of all , is it possible to try another charger ? or test on another scooter.
2. If the charger proves to be okay, it's starting to look like the fault is with the batteries themselves, batteries can fool certain chargers into thinking they being charged when it fact the resistance inside the batteries have become too great.. They need replacing,...
3. Another issue could be the charger socket or the charging circuit to the batteries..
( is there a fuse ? )
Regards
Rob
www.gewizrepairs.co.uk
Jan 09, 2014 | Pride Line Rally Scooter 3 Wheel Viper
Just bought my dad a second hand go go 3 wheel elite scooter
Hi Linda. Sometimes if there is a blown fuse or faulty connector on the battery leads, the charger thinks the batteries are charged as the voltage coming out of the charger rises to the high level. Some chargers will cut out if this happens. It is probably not the charger.
Make sure the batteries are plugged in correctly, sometimes during transport they will get knocked and become disconnected.
Also make sure that the battery terminals are not loose where the wires connect to the batteries.
Good luck. Neil.
May 21, 2010 | Pride Mobility Products GoGo Ultra X...
When i push the power key it beeps and two lights appear then it shuts off its been a while since ive charged it
Visit:Peeplo.com/Free+Repair+Manual & im almost sure as i have a disability scooter when its not in use use a decent trickle charger they can be left plugged in for up to 3 months,so your batteries are fully charged all the time & plug back in even if you do a 100 yards trip,lets be honest the batteries are not cheap,so get the most out of them.or if not in use for any period after they are fully charged disconnect them.
May 11, 2010 | Pride Jazzy 1113 ATS Indoor Power...
My quickie aspire wont turn on
3 months is too long for gel batteries to sit off-charge, without being fully charged first, then disconnected before storage.
Your charger is trying to charge, but the batteries aren't cooperating. This chair accepts either the Group 22 or Group 24 gel-sealed batteries. 22 are about 50 amphour, and 24 are about 74 amphour, and will give you greater range. Cost for a set of two of either is going to be about $350 and $450 respectively. Ouch!
Jul 07, 2009 | Quickie Wheelchairs Quickie Aspire...
Low Battery, Connected car charger, now is dead
May be the battery won't have charge, keep 1 or 2 hrs continues charges, and if it is not working then you have to replace the battery set full.
Jul 04, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
Scooter will not charge
Check the fuses may have a Blown fuse
Check to see if power supply witch charges the scooter is not faulty
Regards; Aaron
Sep 13, 2008 | Pride Sonic 3 Wheel Portable Scooter
My sidekick 3 won't turn on
Jake-
That is the right button. The charging port is probably bad. This is a common occurence on sidekick 3's. Does the orange light come on but it nevers seems like it is charging?
The best thing to do is get a edocking cradle that has an external battery charger. It will allow you charge the battery seperate form the phone.
See link below
http://fixmysidekick.com/shop/repair-replacement-parts-for-sidekick-3/Sidekick-3-Spare-Battery-Charger
Sep 10, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Select Jazzy Used Electric Wheelchair Logo
377 people viewed this question
Top Select Health & Beauty Experts
wcdoc1953
wcdoc1953
Scooter Doctor
Scooter Doctor
gnshome
Level 1 Expert
Are you a Select Health and Beauty Expert? Answer questions, earn points and help others
