Question about Cobra 19 DX IV CB Radio
Cobra 19 dx iv cb tries to come on but wont - Cobra 19 DX IV CB Radio
    Genius:
  • Cobra Master
  • 1,795 Answers
Crack in the pcb board ?bad wire somewhere.? main IC not powering things up.
Posted on Sep 01, 2014
SOURCE: Cobra 19 DX IV CB Radio Gets no signal at all
my only idea is the frequency that Canadians transmit/recieve on is different than us down south (in the USA). I know Europe and the UK use a different frequency range so my guess is that Canada uses a different radio frequency range than the U.S. making you unable to communicate with fellow radio users. You may be able to search the frequency range for Canada vs. the U.S. and see if there's a difference. Hope this helps...and again, it's just a thought.
Montana, USA
Posted on Jul 17, 2008
  • 16 Answers
SOURCE: Cobra 19 DX IV out of frequency
I would definitely take it back for a re check. If the radio took a good bump perhaps it can cause it to drift off frequency. Turning the channel while holding his mic keyed does nothing but just throws a dead carrier. No value what soever. RF Gain is just to improve his reception by either lowering or raising the sensitivity of the receiver of the radio. Squelch is to silence the hissing sound you hear when no one is talking. Care must be taken to not to adjust too much or you wont hear anybody. It wont help his transmit audio at all. Recommend you get another Radio Check from someone else. He could be pulling your leg saying you don't sound good. Best regards and hope this helps some......................John.
Posted on May 27, 2009
  • 773 Answers
SOURCE: My cobra 19 dx
Some times knobs go bad. I have a funky knob on one of my radio's. When ever you wiggle the knob it just makes awful noise.
If this is a similar problem, you can try to clean the knob with electrical contact cleaner.
If that doesn't work you my have to replace the knob.
As for the switching to 19, it could be a byproduct of a short in the knob.
Posted on Oct 03, 2009
riceski
  • 1851 Answers
SOURCE: my cobra dx 19 CB does it have to be grounded
YES you must have the power plug for ground at a minimum. The antenna must also be working properly. The out side of the CB case doesn't HAVE to be grounded but it is better over all if it is.
Posted on May 08, 2010
  • 773 Answers
SOURCE: how to set up the cobra 19 DX IV CB Radio
first keep the manualhandy for the radio and antenna you are using. start by finding a good mounting point for the radio. install the bracket and cheeck the fit with the radio. next run the included power cord from the back of the radio to the fuse box. don't plug it into the radio yet. take the black wire and ground it to metal. try to find a screw goofyinto the metalof the car and loosen it, wrap the wire o. it and tighten it. next find thefuse for the stereo. pull it out and press I back inwith the red wire getting pushed into the fuse socket with the fuse. now you can plug in the radio. IMPORTANT! do not plug it in backwards. if you do you will blow out a diode in the radio and it will not turn on until repaired. turn the key on and then the radio. make sure it powers up BUT DO NOT KEY THE RADIO YET or you will damage it. the radio must never be keyed withough an antenna connected. mount the antenna as close to center of the car as possible le and according to theantennas instructions. run the coax to the radio and connect it tightly. now you need to tune the antenna for best SWR. there is a section in the radios manual and the antenna.manual that explains how to do this. rather then me type it all out you should have detailed I.structins already. if not let.me know and I will ppart it. after the swr is tuned for lowest you are ready to talk on the radio. enjoy.
Posted on Aug 01, 2011
My cobra 19 dx Iv has no volume
adjust the SWR and you may just find your volume
Feb 05, 2014 | Cobra 19 DX IV CB Radio
Way over modulated on my cobra 19 dx iv
check the frequency,these radios are good for the money,but drift off frequency,try different channels and see if that helps
Mar 10, 2012 | Cobra 19 DX IV CB Radio
How to peak and tune Cobra 19 DX IV
L 5 , L 6 , L 801 for power and RV2 for modulation.
Feb 07, 2012 | Cobra 19 DX IV CB Radio
High SWR
the problem is in the antenna cable. the lenth of a antenna cable must be divisable by 3. try replaceing cable with a 18 foot cable that should fix the problem.
Apr 11, 2009 | Cobra 19 DX IV CB Radio
Need more power
not impossable but if you have to ask then you are not qualified to do it.
Apr 09, 2009 | Cobra 19 DX IV CB Radio
Cobra 19 DX IV CB Radio Logo
80 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
