Question about Sole Fitness Sole F85 Treadmill
Sole f85 error e2 - Sole Fitness Sole F85 Treadmill
Sole f60 incline error E2
does the incline work at all. if not try to calibrate the incline. if this fails something could be wrong with the incline motor
Oct 20, 2014 | Sole Fitness Sole F63 Treadmill
Fan not working
Your display pcb board needs replacement.....call sole for service
Dec 24, 2013 | Sole Fitness Sole F85 Treadmill
Electronic display in rotation
If youre meaning that the buttons do not function this could be caused by sweat getting inside. Replace electronics inside or entire console.
Sole F85 Hand Rail Incline Adjustment Switch is not working
The hand rail switch contacts can be worn out. The more likely problem is a broken wire by the arm. Remove the cosmetic covers by the hand rails and check for broken wire. If wires are not broken replace the switch.
Aug 12, 2013 | Sole Fitness Sole F85 Treadmill
Sole F85 treadmill fan and hand controls not working
There may be two problems, however, I would suggest you replace the main display pcb. That will fix the fan problem. If the handle bar switches still do not function replaces the switch and wiring.
Jan 30, 2013 | Sole Fitness Sole F85 Treadmill
F85's "low speed" error
Dear Sir:
1) Lube the deck belt very well, as your instruction manual indicate for maintenance.
2) Try to Run software calibration after you fix it. For easy diagnose and troubleshooting.
3) The elevation motor can be faulty for lack of maintenance too, again Run the software calibration.
sincerely. God bless you
Apr 13, 2012 | Sole Fitness Sole F85 Treadmill
Operating manual sole e35
go to www.iconservice.com for free download
or http://fitness.manualsonline.com
Good luck,sincerely. G-d bless you
ERNESTO CUADRA
MANAGUA,NICARAGUA
Dec 12, 2011 | RTO Sole Fitness Package F85 Treadmill &...
Sole Fitness Sole F85 Treadmill Logo
50 people viewed this question
Top Sole Fitness Exercise & Fitness Experts
Art Wilson
Art Wilson
Level 1 Expert
Electro Med Services...
Ross Metcalfe
Ross Metcalfe
Are you a Sole Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
