Question about Dell 2335dn Multifunction Laser Printer
2335 System Default Initializing wont print - Dell 2335dn Multifunction Laser Printer
My system wont pass system initializing stage please help do you think is dvr problem or hard drive
What it shows on screen after system initializing? It goes black or?
do you have a manual for it? I think it has a "like computer" options that allows you to click on the start prompting you to an internal menu. Can you try to find this?
let me know,
by Cris,The best on FixYa
Jul 06, 2014 | QPS Q see QT426 Video Surveillance System
Firmware required
If the the printer will only print 80 column rather than 136, and you know your print job is 136 columns, firstly check the menu settings to ensure the printer is not set to 8inch width. If the printer is set to 8inch width you will not be able to print more than 80 columns.
If you are printing from a Window application you will need to ensure you have the correct paper size (ie 13.6 inch wide) selected in the Application AND the printer driver.
If you are sure the print data is wider than 80 column and the printer menu is set to 136 column and you still are not able to print wider than 80 column it may be necessary to reset the device back to factory settings. (Before doing this I would recommend printing the current settings or make a note of the current settings as you will need to set the device back up again)
To reset the device to factory default;
  1. Start with the printer powered off
  2. Hold down the four grey buttons under the LCD
  3. Keep the four grey buttons held down and power the printer ON
  4. Keep the four grey buttons held down until you see 'Loading Default' of the printer has finished initializing.
Once you have done this you should be able to print 136 column prints.
If you can not I would suspect the data is not greater than 80 columns in width and you would need to check the computer system set up.
Apr 24, 2014 | Tally T2250 Matrix Printer
System Initializing
Have you tried unplugging the monitor from the 120 volt supply for a minute or two then replug and turn on. Like computers and some flat panel TVs they can freeze-up after an unplanned power loss and need rebooting
Jan 12, 2014 | Samsung SMT-190 19" Flat Panel TFT LCD...
Dell 2335 problems
There is a Brother Solutions Page for that
Nov 06, 2013 | Brother MFC-5840CN All-In-One InkJet...
My HP LaserJet P2055dn just writes initializing and doesn't print. If i restart it just makes some boot up noice and then writes initializing on the LCD
My HP LaserJet P2055dn just writes initializing and doesn't print. If i restart it just makes some boot up noice and then writes initializing on the LCD so what can i do please help me?
Aug 14, 2011 | Office Equipment & Supplies
Meri phone memory full show kr raha hai..but there is no data ,how can format phone memory..plz say something
Type in *#7370# in the main menu, means in the same way you type in numbers before dialing. It will ask you for the default security code, and then the phone will restart itself. Please note that all data saved on your phone will be completely wiped out including Contacts, Sms, etc..
"????? ???? ???, *#7370# ???? ???? ", ????? ?? ???? ?? ???????? ??? ???? ????? ?????? ??. ?? ?? ???????? ??????? ??? ?? ??? ?????, ?? ??? ??? ?? ???? ???? ?????. ????? ????? ??? ?? ??? ???? ??? ?? ????? ?? ???? ?? ???? ??? ?? ??????, ?????? ??? ???? ?????? ?????." (I can't guarantee the translation, it's only google translation,)
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Jun 01, 2011 | Nokia 6120 classic Cellular Phone
Can't get past initializing
You can try to reset the device by pressing the power button for about 15 to 20 seconds..if that doesnt work I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Jan 28, 2009 | SanDisk Sansa Clip MP3 Player
Hello, I have characters printing trouble, so that I would like to restore the factory default settings for my printer Tally 2280. But I do not know the procedure to do so. I need Helps, very...
You can reset the menu on the 2280 to factory default settings, but I would strongly recomend first printing a menu print to ensure you know how the menu is currently set up.
The menu can be printed in the follwoing way;
Switch the printer power on.
Press the Setup key to enter the menu settings.
Press the key under "Menu",
Then press the key under "Print" and your current configuration will be printed.
If the menu is locked power the printer on holding down the setup button, this will unlock the menu.
To restore the factory defaults within the printer,
switch the printer off.
Press all four keys beneath the printer display and switch on the printer.
Keep the keys pressed until "Initializing" is seen in the printer display.
Your printer is now set to the factory default configuration.
Jan 27, 2009 | TallyGenicom 2280 Matrix Printer
Samsung SHR-1040 DVR
try resetting the system and reprogramming if that does not work you may nee to find a factory authorized repair facility in your area.
•Factory Reset Hidden Key :
Mode Key + CH 2
•The Password and all setting
value will return to the initial
default value.
•Default Password is ‘4321’ .
mj
Feb 10, 2008 | Samsung 4 Channel Dvr
Dell 2335dn Multifunction Laser Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
