Question about Kenmore Elite Oasis 27052 Top Load Washer
LG WASHING MACHIN T6515TDCTO TRUBBLE SHUTTING
What do we do after replacing the pump on an LG frontload washing machin, yet still get error message OE?
Assuming you cleaned the pump strainer?
Likely the drain hose leading from the pump to the drain, the section
inside the cabinet that "u-turns" back down is plugged up with
junk.. I had to remove the hose from the machine and force water
thru it at a outside faucet to clear what looked like a turd from the
inside of the drain hose..My shop vac could not dislodge it..
Aug 16, 2014 | LG Washing Machines
LG wash machin have error code "EU"
There is no such error code. The closest error code would be UE which means that it's a unbalanced load error. If you have a light load, or you are washing a large bedsheet or bedspread, that will cause it to not spin properly because the machine cannot balance the load. The best thing I can recommend is adding about 4 to 5 large bath towels so the weight can be distributed more evenly.
Good luck
Jun 12, 2011 | LG WM-2277HW Front Load Washer
My wiring diagram is missing, where can I get a new one?
You Can Get a Graet Washing Machin And Chip From Lg Or SamSung
May 10, 2011 | Washing Machines
The washing machine will spin and drain but makes a noise the faster it gets
This is very common in top loaders as the weight of tub n cloths combined cause the shaft of the machin to be frictinious.
This can be solved by pouring some machin oil or kerosin in the tubwalls from sideholes.
Hope this helps.
Jan 12, 2011 | Whirlpool LSQ8000 Top Load Washer
LG Washing machin model : LG-WFF734PC Top Loading having problem , water keep coming out through the drain hose when the the water flow in the tub for the first process of washing. Every time i selected...
you will need to take the back off the machine to access the small 5mm pipe that Leeds upward to the water sensor and take it off and blow gently into it when you do you will hear a click and one when you release the air that means that the sensor is ok but the tube where you took it from is blocked with soap goo unblock it and the problem should be gone eric
Dec 27, 2017 | LG Washing Machines
I have LG WFT70A37ECT top loading washing machin. getting dE error even though door is close, what is the other reason
How many years is yoru washing machine? I suspect bthe magnet on the lid of the washer has probabkly come off which causes the washer not to identify that the door is closed. U need to replace a magnet on the lid.
Oct 17, 2010 | LG WM-1480FHD Front Load Washer
I need a user manual of whirlpool semi-automatic washing machine
whirlpool semi automatic washing machin motar is rotating in only one direction (clock wice direction) ho to solve the problem?
Sep 22, 2010 | Whirlpool Washing Machines
What is the AE error code on LG steam direct drive washing machin
the AE code means that there is water in the base I found that the steam heater element in mine was leaking so after a quick repair using silicon and a good clean after drying the water out of the base it now works again
PS I used to be a washing machine repair engineer! I wouldn't suggest that you start opening up your washing machine!!!!
Dec 29, 2009 | LG Washing Machines
Code on display OE
Just got the same problem. Found out there is a filter on the bottom of the machin that collects everything. It was plugged bad. There is a door on the front bottom left open door unscrew filter (the bigger object in the door.) Clean filter and wala.
Oct 24, 2008 | Washing Machines
Kenmore Elite Oasis 27052 Top Load Washer Logo
48 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
