Question about Goldstar Microwave Ovens
How to replace fuse for MV1604ST - Goldstar Microwave Ovens
Where do i locate the fuse
Although you have not mentioned the model/make, take a look at the video here for replacing a Thermal fuse. Microwave Won Work GE Microwave Thermal Fuse Replacement part WB27X1127
on traditional fuse see
How to Fix Microwave Oven Simple Fuse Replacement
Mar 08, 2016 | GE Microwave Ovens
How do I fix a blown microwave fuse?
How to Fix a Microwave Oven - Simple Fuse Replacement ...
? 18:04
https://www.youtube.com/watch?v=IN0BqiVX5ds
May 21, 2013 - Uploaded by GuruBrew
How to Fix a Microwave Oven - Simple Fuse Replacement. GuruBrew .... I'm hoping it's just a blown fuse ...
Whirlpool Microwave Keeps Blowing Fuses - YouTube
? 2:35
https://www.youtube.com/watch?v=KGQgendKTR0
May 7, 2013 - Uploaded by AdamDIY
Whirlpool Microwave Keeps Blowing Fuses ... MicrowaveThermal Fuse Replacement - GE Microwave ...
Microwave Oven Repair 101 ' DoItYourself.com
Dec 06, 2015 | In Microwave Ovens
How do I replace fuse
Well you need to find where the fuse is located, And determine what type of fuse is being used. So you know what fuse you need to buy to replace it.
How do you know you need to replace the fuse?
Aug 30, 2014 | Microwave Ovens
Blown HV fuse
I would replace it with a fuse of the same 5kv.09 as replacing with another may overload the microwave and cause a fire.
not recommended to replace with a higher fuse rating or kind
Feb 14, 2014 | Microwave Ovens
Replace fuse Kenmore 40188523011
If you know that a fuse is open, you need to find out why it went out before replacing it. There are typically three fuses in any given microwave oven. Line or monitor fuse, cavity temp fuse and magnetron temp fuse.
Oct 07, 2013 | Sharp R-1750 Microwave Oven
I have a MV1604ST over the range microwave oven. After I made my daughter's breakfast this morning, the fan kicked on and will not shut off. It has been running for hours. The microwave still works and...
There si a sensor on the bottom of those Micros that is supposed to turn the fan on when it closes, meaning it is hot, then opening when it cools back down. I expect you have a bad thermal sensor. I have very seldom found these to go bad. Another thing that can cause it is a bad door switch back feeding voltage where it is not supposed to. It will make the fan that cools the magnetron run until the bad switch is replaced.
Aug 15, 2017 | LG MV1604ST 1000 Watts Microwave Oven
The food in the microwave is not heating up I have tested the fuse (F8AH250V) and found that it has blown. Is it safe to replace this fuse (F8AH250V) on my microwave.
Fuses seldom just go bad on their own, but it's safe to replace. Before you replace the fuse, squeeze the tabs of the fuse holder clips together a bit. Sometimes they don't grip the fuse tightly enough, and this can cause heating which damages the fuse. If the fuse blows again there is a bad part in the oven that will need to be located and replaced. For a small countertop oven, it's probably more economical just to replace the oven than to repair it.
Jan 02, 2011 | Sharp Microwave Oven Microwave Oven
Our microwave just stopped working one day. Wondering if the fuse is out.
If you have power to the front of the unit then most likely the fuse is good. If you have no power then it's possible that the fuse is blown. Should warn you that IF YOU open the case up to change the fuse, be very careful. there is enough voltage in there to do you some serious harm if you play with the wrong thing.
Apr 26, 2010 | LG MV1604ST 1000 Watts Microwave Oven
Gold star mv1604st/01
Dear friend,
ngfam at you service! happy to assist!
If there is no power at all then perhaps the fuse is blown in the microwave.
How old is it?
The magnetron tube could be burned out! and its cheaper to buy a new one usually!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Aug 29, 2008 | Goldstar Microwave Ovens
Microwave Ovens Logo
23 people viewed this question
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
