Question about Samsung Washing Machines
3e code on wf419aaw
Machine wont spin
3 Suggested Answers
kevin_getz
  • 1031 Answers
SOURCE: code 3E not spinning, just draining water. nothing in the "catch" compartment at the bottom.
A "3E" error in a Samsung washer indicates that there is an issue with the motor. Restarting the cycle may clear the error, but a service technician should be consulted if the error code appears again.
Posted on May 25, 2012
57 varieties
  • 1653 Answers
SOURCE: Samsung Model WF220 won't spin after it fills with water. It displays Error code 3E.
Posted on Sep 08, 2012
My Samsung washing machine, front load, showing E3 error, can you help? Thank you
Samsung Washing Machine Error Code 3E = Motor Drive Error or Hall Sensor ErrorWhen your Samsung Washing Machine shows the error code 3e, the most common reason is because of a "wire harness or wiring connection is loose, not connected, or wiring is damaged". Checking the wire harnesses on the motor, hall sensor, stator, control board etc, will usually result in finding a faulty wiring connection or bad wire hareness. Reconnecting or replacing the wire harness or wiring will fix the washer and clear the 3E error. See more troubleshooting info below...
how to fix error code 3e on samsung washing machine Google Search
Mar 23, 2018 | Samsung Washing Machines
I have a samsung front loader WF7700N6W1 WHICH KEEPS COMING UPWITH THE ERROR CODE 3E IVE checked the drainage plug and cleared that but mavhine still not working.
The 3E error code to indicate a drive motor tach fault.
Here's a good website that discusses how to troubleshoot and possibly repair. (Could be as simple as unplugging the machine for a few minutes).
How To Fix 3E Error Code On Samsung Washing Machine
Here's an EXCELLENT YouTube video on removing the motor and replacing the brushes (if equipped).
Samsung Washing Machine 3E Error Code not spinning or turning
Jun 15, 2017 | Samsung Washing Machines
What does the E3 code mean on the 540 model and is there a fix?
Troubleshooting the "E3" error code in Maytag MAH6700 ...
fixitnow.com/.../troubleshooting-the-e3-error-code-in-maytag-mah6700-...
Feb 20, 2011 - These codes in your (made-by-Samsung) Maytag washer might pop up during the ... In fact, the E3 error code means that the Machine Control wants to make the motor spin but won't do it because it's getting a weird reading from the tachometer.... MAH6700 and MAH8700 models (they use the same motor).
I have a samsung frontload washing machine. A code E3 is ...
www.shopyourway.com > Denise LaGrasse > Questions
Mar 15, 2014 - My samsung front loader is not working. do not no what E3 means. ...code F26 mean on a Kenmore Elite model 110.4708 washing machine?
How To Fix 3E Error Code On A Samsung Washing Machine
www.appliancerepairlesson.com/.../how-to-fix-3e-error-code-on-a-samsu...
May 15, 2015 - Samsung uses the 3E error code to indicate a drive motor tach fault. ...If you're handy, you can fix your Samsung front load washing machine error code ....My samsung frontload washer shows e3 and the drum does not turn ...
Jan 06, 2016 | Washing Machines
Mu Samsung wa400pjdwr top load is not spinning out code is 3E
3E Motor tacho fault detected Can also be caused by main PCB
If the motor tacho signals are inputted less than 2 for 2 seconds after main drive motor started, this error will occur.
  • Check motor
  • Check motor tacho
  • Check all connections and blocks to the motor
  • Check connections on the main control module
  • Check main control module
Apr 05, 2015 | Samsung Washing Machines
This video will help you diagnose the fault on Samsung Model WF220 3e error codes and the video will help you solve the problem
Sep 08, 2012 | Washing Machines
Maytag washer 3e fault code
3E == overcurrent detected at the motor.
Open the control panel, there you will find a tech sheet that explains how to put the machine into service mode and what to do while in service mode to track this down. Once on service mode, you can cycle through and retrieve all diagnostic codes. You will also find serveral other diagnostic service notes. Read them and follow the instructions to test the motor, motor control, and main control board.
Jan 14, 2008 | Maytag MAH6500 Neptune Front Loading...
Washing Machines Logo
13 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
