How do I remove speaker grill on psb speakers
  • 1861 Answers
SOURCE: replacing front door speakers
You need to pull the door panel to get to the speaker. It is bolted to the door shell, not the door panel.
Posted on Sep 19, 2008
SOURCE: need to remove speaker grill on pioneer speaker
If it is a 95-97, the speaker grills are not designed to come off by themselves. You have to actually take off the door panel. There should be screws all the way around the outside as well as 2 larger screws in the middle of the door covered by plastic caps. Remove all of those and you can finally get access to the speakers themselves. Hope this helps....
Posted on Jan 14, 2009
sg1972
  • 225 Answers
SOURCE: How do I remove the cloth grill cover from the front of speaker?
Some speaker manufacturers design their boxes with non-removable front grills. Be thankful that you can remove the back because I've seen these sealed as well. Once inside, the speakers should be mounted from the inside (mounting screws on inside) compared to front mounted. IF they are not then either you're not using the proper method to remove the grill OR it's glued in place and will require breaking the glue bond to release the grill. One note to remember...non-removable grills can mean the manufacturer has something to hide.
Posted on Mar 23, 2009
askjhuber
  • 59 Answers
SOURCE: how do i replace toyota camry 2000 rear speakers?
These grills just pop off then there is a few scres that hold the speakers in.
Posted on May 17, 2009
emmetmyers
  • 37 Answers
SOURCE: how do i remove the rear speakers in a 2004 kia spectra?
did you check in the truck ?
Posted on Jun 19, 2009
I need leads to connect my NAD C320 BEE amplifier to PSB T45 speakers. Not sure which plugs are needed to fit into the speakers.
From the C320 manual, Page 5...
11. SPEAKERS
Speaker terminals for speakers with an impedance of 4 ohms or more. Connect the right speaker to the terminals market 'R +' and 'R-' ensuring that the 'R+' is connected to the '+' terminal on your
loudspeaker and the 'R-' is connected to the loudspeaker's '-' terminal. Connect the terminals marked 'L+' and 'L-' to the left speaker in the same way.
Always use heavy duty (16 gauge; 1.5mm, or thicker) stranded wire to connect loudspeakers to your NAD C320. The high-current binding post terminals can be used as a screw terminal for cables
terminating in spade or pin sockets or for cables with bare wire ends.
BARE WIRES AND PIN CONNECTORS
Bare wires and pin sockets should be inserted into the hole in the shaft of the terminal. Unscrew the speaker terminal's plastic bushing until the hole in the screw shaft is revealed. Insert the pin
or bare cable end into the hole and secure the cable by tightening down the terminal's bushing.
Ensure bare wire from the speaker cables does not touch the back panel or another socket. Ensure that there is only 1/2" (1cm) of bare cable or pin and no loose strands of speakers wire.
Register and download the PSB manual for free at retrevo.com
http://www.retrevo.com/support/PSB-T45-Speakers-manual/id/23107ag412/t/2/
If you're pondering those jumpers on the back of the speakers, my advice is to leave them in place and ignore them. Connect the speaker cables to either plus or minus.
Bi-wiring does nothing but make you use twice as much speaker wire for the same electrical effect. Bi-amping assumes there are deficiencies in your electronics that must be worked around, again by using more speaker wire and separate amps.
Apr 15, 2011 | PSB Century 600i Speaker
Need instructions to replace the passenger side mirror and the driver side tail light on a 1999 Ford Taurus 4-door sedan. Thank you, Gary S.
Section 01-09: Mirrors, Rear View 1999 Taurus/Sable Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 06/25/1998 Mirror, Power-Outside Rear View Removal
  1. Disconnect battery ground cable (14301).
  1. Remove front door trim panel (23942). Refer to Section 01-05.
  1. Remove radio speaker grille from cover assembly by squeezing or pinching between thumb and index finger.
  1. Remove two screws from cover assembly.
  1. Disconnect outside rearview mirror wiring connector (C515-LH; C615-RH). Remove wiring guides as necessary.
  1. Remove three outside rear view mirror retaining nuts. Remove outside rear view mirror (17682) while guiding wiring and connector through hole in door.
Item Part Number Description 1 17682 Outside Rear View Mirror 2 N621906-S36 Nut (3 Req'd) 3 F8DB-17D699-
AAW Cover Assembly Rear Substrate-LH 3 F8DB-17D698-
AAW Cover Assembly Rear Substrate-RH 4 N808968 Screw 5 F8DB-18B984-
AAW Speaker Grille-Standard (No Badge)-LH 5 F8DB-18985-
AAW Speaker Grille-Standard (No Badge)-RH 5 F8DB-18K901-
BAW Speaker Grille-Mach-LH 5 F8DB-18978-
BAW Speaker Grille-Mach-RH 5 F8DB-238A35-
AAW Speaker Grille-Blank (No Speaker)-LH 5 F8DB-238A34-
AAW Speaker Grille-Blank (No Speaker)-RH A - Tighten to 6-8 Nm (54-70 lb-in) ------------------
Trim Panel, Door Front
Removal
  1. Remove cover behind inside door handle.
  1. Remove screw from bottom of pull cup retaining front door trim panel to front door (20124).
  1. Remove three screws retaining front door trim panel to front door.
  1. NOTE: Do not attempt to remove more than one pushpin at a time.
    Using Rotunda Windshield and Molding Trim Removal Kit 107-R0401 or equivalent, remove the door trim panel by pulling one door trim panel pushpin at a time from the inner door skin.
  1. Disconnect electrical connectors as necessary. Refer to Section 01-14A.
Installation
  1. Follow removal procedure in reverse order.
  1. Replace all pushpins with new pushpins (N808994-S).
Front Door Trim Panel
Jan 14, 2011 | 1999 Ford Taurus
Removing grill covers of Clarion 6.5" marine speakers
Put a piece of cardboard next to the speaker to protect your boats finish. Then use a flat bladed screw driver to gently pry the grill covers off. you may need to work your way around the perimeter, with a little bit of effort it will pop off. There will be 4 screws under the grills holding the speaker to the boat which are easy to remove.
May 04, 2010 | Clarion Coaxial Coaxial Car Speaker
How to replace rear speaker grills on 2004 Toyota Camry
Remove the rear seat, pull up and out on the bottom half, remove the sides of the back- one bolt on bottom of each side,remove the backrest, then remove the whole deck lid with speaker grills in it , then you can replace the speaker grills.
Mar 17, 2010 | 2004 Toyota Camry
How to i remove the rear speaker grille on my 1989 astro van
In order to remove speaker grill, you will have to remove the whole panel. The speaker grille is actually held in place with metal tabs tabs.
Mar 10, 2010 | Visonik V117SX Car Audio Amplifier
Can I pull the grill off the speakers to put them
NO' YOU DONT NEED TO REMOVE THE ENTIRE DOOR PANEL, TO REPLACE SPEAKERS CONNECT WIRING CONNECTOR TO SPEAKER FIT SPEAKER BACK IN GRILLE AND REPLACE RETAINING SCREWS.
Oct 26, 2009 | 2002 GMC Sierra 1500
Mar 22, 2009 | Philips Audio Players & Recorders
There are no screws on the speaker grill of this particular model
If it is KP-51HW40 Sony TV
Speaker grill has 2 caps covering 2 screws at bottom of speaker grill.
Below is an image showing caps of speaker grill that might help you to open it.
Feb 13, 2009 | Sony KP-51HW40 51" Rear Projection...
Csi sp-6c removal
Your speaker cover should either twist and gently pull off or may just need gentle prying with a small screwdriver. Before attempting is your speaker grill foam or metal. Some like my pioneers, you must gently remove the actual grill and not the entire facia itself to access the speaker removal. If you need to remove the grill, i recommend using a tiny screwdriver and gently work around the edges evenly. Steve
Dec 15, 2008 | CSi Speco SP-6C Main / Stereo Speaker
Replacing front and rear speakers in a 1999 Mazda Protege
Whats the problem?
Back - Remove speaker grill, unscrew, climb in trunk, unplug - remove.
Front - Remove speaker grill, unscrew, pull out, unplug. If you have problems remove window winders and door skins
Dec 15, 2007 | Car Audio & Video
76 people viewed this question
 Grubhead
Grubhead
