Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Frigidare Gallery Heavy Duty Stackables- Brown stains and little holes in clothes after being dried Dryer number FLSE726CSA
#FLSE726CSA
bcroydon
  • 9 Answers
SOURCE: washer and / or dryer causing stains
Bad news... chances are the seal is gone from the tub on the washer and grease from the transmission is getting into the tub. It's new enough you may want to go to the expense of the repair unless you are very handy and want to attempt it on your own. If my diagnoses is accurate there has been a trade of soapy water for grease and this means total tear down of the transmission to regrease. Hope I'm wrong or you are very handy. I replaced mine but it was older.
Posted on Jan 01, 2008
SearsTechToo
  • 261 Answers
SOURCE: WHIRLPOOL ULTIMATE CARE II MAKES YELLOW BROWN STAINS ON LIGHT COLOR CLOTHES
Grease will not come from the interior of the washer, as the machine ages build up deposits under the basket and it is oily, greasy and full of mildew. If can get a spanner wrench from a appliance parts house and remove the basket you will see on machines older than three years a build up starting. I pulled 15 lbs from a 25 year old machine and I had to go get sick outside, it was bad.
Posted on Oct 06, 2008
honeymokey
  • 3113 Answers
SOURCE: washer whining when washing and spinning leaving brown stains on clothes
Turn water off. Remove hoses and clean the rust out of the strainers at hose end. If they are clogged they will sound funny when water goes through them.
Posted on May 16, 2009
canbruce75
  • 1776 Answers
SOURCE: starting to leave brown oily like stain on clothes
The first place that I'd check would be the small metal screens inside the openings on the water inlet valve. They can get really rusted, epecially in areas with hard water, so I would recommend removing the water supply hoses and take a gander at the screens. They can sometimes release the iron oxide into the wash water and cause brown stains or blotches on clothing. Hope this helped and best wishes.
Posted on Sep 07, 2009
blueextc3221
  • 15935 Answers
SOURCE: Duet GHW9150P Front Load Washer: REDDISH BROWN STAINS FROM WHIRLPOOL GAS DRYER...
This is from not enough HOT loads.
Fatty deposits gather between the basket and tub during COLD washes.
Then they are being released in large numbers when you do your whites on HOT.
It is recommended to do 1 HOT load per week.
Do an empty load with some degreaser added (like Goo-Gone) on the fullest/hottest setting you have.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
My frigidare heavy duty crown series gas dryer is n0t heating and barely able to dry my clothes--what could be the problem and how can i fix it
Hello Chuck, thanks for your inquiry
Based off the information you have provided I have identified a few possibilities as to why your dryer is not heating could be the element, thermostat, or control panel. Each component controls the heat within your dryer and if one goes out it is possible that can cause the rest to not function properly. To accurately find out the reason to why your dryer is not heating I would recommend having a professional come out. Hopefully this is helpful. -Matt
Sep 28, 2014 | Frigidaire Dryers
Frigidaire gallery heavy duty dryer
Good Afternoon Friend, thank you for your question!
I understand you are seeking a replacement dryer belt for your Frigidaire laundry center, GLET1031FS. The replacement dryer belt part number that you would need to order is 137292700.Most parts can be purchased directly from the manufacturer or through a parts distributor in your area (part numbers may vary based on distributor). Hope this helps! - Z
May 19, 2014 | Washing Machines
Brown Burn Stains and little holes from FRIGIDARE GALLERY HEAVY DUTY STACKABLE DRYER
If you are using LP gas make sure the dryer is set to LP on the regulator. If a natural gas dryer is run on LP you will get way to much flame.
Jan 02, 2014 | Dryers
I have a Frigidaire Gallery Heavy Duty electric dryer, the dryer run non-stop even on auto-dry mode (timer doesn't advance) but the clothes aren't drying either.
Timer will not advance unless the element is working. Suspect bad element or bad thermal fuse on element housing
Dec 11, 2013 | Washing Machines
My Kenmore heavy duty tumble washer is leaving a light brown stain on white or light clothes. It is likely staining dark clothes but of course they are too dark to see a light stain. It is definitely...
The brown stains are likely coming from the felt drum seal. The OEM adhesive is tar based - and after time and use - breaks down.
You'll need a new felt seal - and the adhesive that is used should be silicone based... eliminating the brown streaks.
Jun 06, 2009 | Kenmore 44102 Front Load Washer
The clothes get stained with brown burn marks while in the dryer.
The rear drum support needs replacing.
The front glides and felt seal needs replacing.
May 25, 2009 | Frigidaire FLEB8200DS Top Load Stacked...
My frigidare heavy duty crown series not heating
sounds like you have a cloged vent i normally get a few calls in the winter timer for this problem because the vent is clogged outside due to the snow remove your vent try the dryer to see if it dries if yes check your vent
Mar 15, 2009 | Dryers
Clothes dryer squeaks when running
Fixing Frigidaire model # FER641FSO, not stacking, but had similar problem. turnsout one of the coils came off. might try that...
Mar 01, 2009 | Frigidaire GLER331A Electric Dryer
I have a Frigidaire Gallery Electric Dryer Model #GLER642AS3
The identification label from a Frigidaire Gallery Commercial Heavy Duty Moisture Sensor drier has come off. I need to download operating/user manual. How can I get the serial no. or model no. The drier is 4 years old.
Dec 20, 2008 | Frigidaire GLER642A Electric Dryer
Kenmore heavy duty dryer
You didn't mention if the motor runs or if it heats. If it does both of these, you'll need a new belt.
Mar 09, 2008 | Dryers
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
