Question about Saeco Syntia Espresso Machine & Coffee Maker
Water circuit symbol in red - Saeco Syntia Espresso Machine & Coffee Maker
My refrigerator is a double door and top portion is not cooling yet it reads 38 degrees. Why is it not cooling?
unplug the power cord for 10 minutes, then set again the thermostat at your temperature required.plug it again and wait for two hours.
Dec 31, 2014 | Refrigerators
My h20 symbol is lit up red
Sounds like the water filter needs changing only. What is your model number located around the fresh food section door frame? I will try to locate a user manual for you, Thanks Sea Breeze
Feb 04, 2013 | Whirlpool Refrigerators
DeLonghi (W160B) Portable Air Conditioner "No Water" symbol is still on despite the water tank being full
Tank hols 14 litres water where you fill there is a indicator if that is clear the tank is not full has to be red to be full. The water fill symbol will then go out.
Dec 23, 2012 | Heating & Cooling
Red symbol washing machine water light
I would check to see if the water pump has not become blocked as it needs to empty the water out before it can advance to the next cycle mabe a wire has come off the pump ,please unplug the machine first eric
Dec 25, 2017 | Washing Machines
I purchased the lux tx9000ts and the 4 wires i have are red,blue,green,white how do i install plz help or the wife will kill me
We will try to keep you alive here... :-)
Red wire on the R terminal
Green wire on the G terminal
White wire on the W terminal
Blue wire on the C if no A/C and on the Y if you do have A/C
Thermostat Wiring and Terminal Designations
heatman101
Oct 13, 2010 | Heating & Cooling
With a new set of batteries in camera the red battery low symbol
Try cleaning the contact points in the battery compartment. If one or more of the contact points are soiled, the camera will react like that. If the problem is due to a short circuit, the batteries will get very hot, if they are discharged after a few seconds.
Mar 02, 2010 | Fuji FinePix S7000 Digital Camera
Delonghi pac w160a...''no water symbol'' stops on in airconditioning mode even though water tank is full
In the back of these units where the cord pulls out, there is usually a red reset button, try pushing that to reset the unit, also make sure the filter is clean, pulls from the top out of the unit. Make sure the coils are clean as well behind the filter.
Good Luck!
Nov 12, 2009 | DeLonghi Air-To-Air Portable Air...
The symbols on the dashboard: what do the red and blue symbols
This is Letting you know that your Windshield Washer Reservoir is Low or empty. Please Rate My Response! Thanks!
Feb 04, 2009 | 2004 Suzuki Aerio
Saeco Syntia Espresso Machine & Coffee Maker Logo
24 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
